jezhall
(Jez)
September 11, 2023, 9:58am
1151
Ive copied everything you have to be honest haha. And thank you massively in advance.
I found the automation was disabled and only me pushing the internal button changed it after smashing it.
Now its displaying a little better but very odd data
alias: EMHASS MPC optimization
description: ""
- platform: time_pattern
minutes: /1
condition: []
- service: rest_command.naive_mpc_optim
data: {}
- service: shell_command.publish_data
data: {}
mode: single
Thats my dashboard coming together from your help and robert in the sonnens forum.
jezhall
(Jez)
September 11, 2023, 10:02am
1152
I Have checked over my solar sensor and i cant find why the EmHass is predicting such high measurments
The last image shows 17k of generation.
I cant find were that value is coming from
markpurcell
(Mark Purcell)
September 11, 2023, 10:28am
1153
You should copy your rest command into developer tools templates to see what the values expand to.
SolCast has recently changed its values so you should change your multiply statement from 2000 to 1000.
For anyone using the Solcast Custom Integration , please be aware it has breaking changes in v4.0 and you will need to change your template for pv_forecast. Thanks to @oziee for maintaining this integration which gives EMHASS access to great solar forecasts.
Here is my updated template:
"pv_power_forecast": {{
([states('sensor.solcast_pv_forecast_power_now')|int(0)] +
state_attr('sensor.solcast_pv_forecast_forecast_today', 'detailedForecast')|selectattr('period_start…
jezhall
(Jez)
September 11, 2023, 10:32am
1154
What a pain in the bum, Yep 100%, im waiting for it all to update correct but yes. The 1000 multiplyer worked a charm.
No its time to play with other settings.
Is there a way to make cards bigger to fill more of the screen? or just zoom the chrome browser is only way?
jezhall
(Jez)
September 11, 2023, 11:20am
1155
Could you put this apex card Yaml file up here please.
rcruikshank
(Robert Cruikshank)
September 11, 2023, 11:32am
1156
type: custom:apexcharts-card
experimental:
color_threshold: true
graph_span: 16h
span:
start: minute
now:
show: true
label: now
color: red
yaxis:
- id: first
min: -0.1
max: 0.9
decimals: 1
apex_config:
forceNiceScale: true
- id: second
opposite: true
min: -4000
max: 7000
decimals: 1
apex_config:
header:
show: true
title: Energy flow
show_states: true
colorize_states: true
series:
- entity: sensor.cecil_st_general_forecast
yaxis_id: first
float_precision: 2
show:
in_header: after_now
stroke_width: 4
data_generator: |
return entity.attributes.forecasts.map((entry) => {
return [new Date(entry.start_time), entry.per_kwh];
- entity: sensor.cecil_st_feed_in_forecast
yaxis_id: first
float_precision: 2
show:
stroke_width: 4
data_generator: |
- entity: sensor.p_batt_forecast
yaxis_id: second
curve: stepline
type: area
show:
in_header: before_now
stroke_width: 2
color: rgb(0,255,0)
data_generator: |
return entity.attributes.battery_scheduled_power.map((entry) => {
return [new Date(entry.date), entry.p_batt_forecast];
- entity: sensor.p_deferrable0
yaxis_id: second
curve: stepline
stroke_width: 2
show:
data_generator: |
return entity.attributes.deferrables_schedule.map((entry) => {
return [new Date(entry.date), entry.p_deferrable0];
- entity: sensor.p_deferrable1
yaxis_id: second
curve: stepline
stroke_width: 2
color: black
show:
data_generator: |
return [new Date(entry.date), entry.p_deferrable1];
- entity: sensor.p_pv_forecast
yaxis_id: second
curve: stepline
show:
stroke_width: 2
color: rgb(255,255,0)
data_generator: |
return [new Date(entry.date), entry.p_pv_forecast];
- entity: sensor.p_load_forecast
yaxis_id: second
curve: stepline
show:
stroke_width: 2
color: rgb(255,0,0)
data_generator: |
return [new Date(entry.date), entry.p_load_forecast];
- entity: sensor.p_grid_forecast
yaxis_id: second
curve: stepline
color: rgb(0,255,255)
type: area
show:
stroke_width: 2
data_generator: |
return [new Date(entry.date), entry.p_grid_forecast];
Jeza
(Jeza)
September 11, 2023, 7:50pm
1159
Is there a way that i can devide the battery output sensor? Im terrible with creating sensors,
The system value it puts out is correct but it assumes that i can charge at 11600w, this is over 3 units. So i need to provide the correct flow vlaue back to my inverter.
I have used the node redflow that robert created and this works wonders.
I have 1 x 5kw inverter with 20kwh
2 x sonnens with 10kwh in each.
Sonnens only can do 3.3kw max each charge and discharge.
Even if i get the flow value devided i may get a better result
rcruikshank
(Robert Cruikshank)
September 11, 2023, 9:11pm
1160
You would have to do something like this:
sensors:
# Split .p_batt_forecast
sensors:
p_batt_forecast_a:
unique_id: p_batt_forecast_a
unit_of_measurement: W
value_template: >-
{{ states('sensor.p_batt_forecast')|float(0) / 4 }}
sensors:
p_batt_forecast_b:
unique_id: p_batt_forecast_b
value_template: >-
sensors:
p_batt_forecast_c:
unique_id: p_batt_forecast_c
value_template: >-
sensors:
p_batt_forecast_d:
unique_id: p_batt_forecast_d
value_template: >-
or if not in equal 4 parts, whatever ratio is required.
Calculate it on paper first and then transpose the calculation into jinja. Experiment with the jinja code in the developer tools. Then use sensor.p_batt_forecast_a b c d for each battery.
You might have to get more elaborate and change the rate of charge if the batteries are at different levels and you want to charge one battery more than the others, so they all reach 100% at the same time.
markpurcell
(Mark Purcell)
September 11, 2023, 9:23pm
1161
Home Assistant 2023.9 also supports template creation from the user interface, which makes this easier:
110hs
(110hs)
September 11, 2023, 11:27pm
1162
Hello!
Any idea why setting set_nodischarge_to_grid
to true
makes the optimization process “infeasible”?
hass_url: empty
long_lived_token: empty
costfun: self-consumption
logging_level: DEBUG
optimization_time_step: 30
historic_days_to_retrieve: 2
method_ts_round: nearest
set_total_pv_sell: false
lp_solver: COIN_CMD
lp_solver_path: /usr/bin/cbc
set_nocharge_from_grid: false
set_nodischarge_to_grid: true
set_battery_dynamic: false
battery_dynamic_max: 0.9
battery_dynamic_min: -0.9
load_forecast_method: naive
sensor_power_photovoltaics: sensor.production_pv_w
sensor_power_load_no_var_loads: sensor.consumption_w
number_of_deferrable_loads: 1
list_nominal_power_of_deferrable_loads:
- nominal_power_of_deferrable_loads: 0
list_operating_hours_of_each_deferrable_load:
- operating_hours_of_each_deferrable_load: 0
list_peak_hours_periods_start_hours:
- peak_hours_periods_start_hours: "07:00"
list_peak_hours_periods_end_hours:
- peak_hours_periods_end_hours: "23:00"
list_treat_deferrable_load_as_semi_cont:
- treat_deferrable_load_as_semi_cont: true
load_peak_hours_cost: 0.1907
load_offpeak_hours_cost: 0.1419
photovoltaic_production_sell_price: 0.065
maximum_power_from_grid: 6000
list_pv_module_model:
- pv_module_model: SunPower_SPR_E20_327
- pv_module_model: SunPower_SPR_P19_395_COM
list_pv_inverter_model:
- pv_inverter_model: SMA_America__SB3000TL_US_22__240V_
- pv_inverter_model: SMA_America__STP50_US_40__480V_
list_surface_tilt:
- surface_tilt: 17
- surface_tilt: 17
list_surface_azimuth:
- surface_azimuth: 225
list_modules_per_string:
- modules_per_string: 9
- modules_per_string: 14
list_strings_per_inverter:
- strings_per_inverter: 1
set_use_battery: true
battery_discharge_power_max: 7100
battery_charge_power_max: 7100
battery_discharge_efficiency: 0.95
battery_charge_efficiency: 0.95
battery_nominal_energy_capacity: 27000
battery_minimum_state_of_charge: 0.3
battery_maximum_state_of_charge: 0.9
battery_target_state_of_charge: 0.6
Jeza
(Jeza)
September 12, 2023, 6:41am
1163
Oh i didnt know that, im updating now. Ill try find it.
Jeza
(Jeza)
September 12, 2023, 7:02am
1164
I do have to ask if anyone else started experiance entities not updating once emhasss running?
My power meter info from sonnen stop displaying info and requires me to do a hard reset on entire home assist to reboot them.
Im not sure if when im updating info to try get values correct or just random as its about 3 tims a day.
Jeza
(Jeza)
September 13, 2023, 7:56am
1165
Hi Mark,
Ive found tou have solaredge metering, how did you manage to get this consumption monitoring working to go into emhass?
markpurcell
(Mark Purcell)
September 13, 2023, 8:31am
1166
I used a mix of sensors from the solaredge integration to calculate the household load:
modbus_consumption:
friendly_name: "Consumption"
device_class: power
value_template: "{{ (states('sensor.solaredge_i1_ac_power')|int(0)
+ states('sensor.solaredge_i2_ac_power')|int(0)
- states('sensor.apf_battery_entity')|int(0)
- states('sensor.solaredge_m1_ac_power')|int(0))}}"
The calculated consumption is the sum of the power from two SolarEdge inverter sensors minus the power from a battery entity and the grid export SolarEdge sensor.
jezhall
(Jez)
September 14, 2023, 5:50am
1167
The battery Entity, is that power discharging?
markpurcell
(Mark Purcell)
September 14, 2023, 5:56am
1168
Negative battery is charging 9am-12pm.
Positive battery is exporting to grid after 6pm.
jezhall
(Jez)
September 14, 2023, 6:23am
1169
Sorry i ment the value
modbus_consumption:
device_class: power
- states('sensor.apf_battery_entity')|int(0) ******this one******
Quick question about the “household power consumption sensor in Watts”. At the solar panels are working the value is always negative. So shouldn’t be the inverter output also being extracted from the household power consumption?
And will this not also the case for when EMHASS would like to discharge the battery?
Another question about the “The desired battery state of charge at the end of each optimization cycle”. If I turn this off (so 0) the Cost total is higher than leaving the option default at 0,6.
In my current configuration it’s 12.18 euro (with value 0) and 9.27 euro with value 0.6.
Why is this option good to use?
