EMHASS update from 0.8.1 to 0.8.2 went very smoothly.
New option to show the payload in the log is very nice!
2024-03-11 09:20:02,447 - web_server - INFO - Using core emhass version: 0.8.2
waitress INFO Serving on http://0.0.0.0:5000
2024-03-11 09:20:10,306 - web_server - INFO - Passed runtime parameters: {
'load_cost_forecast': [0.25749, 0.25749, 0.25227, 0.25227, 0.24346, 0.24346, 0.24236, 0.24236, 0.23582, 0.23582, 0.23389, 0.23389, 0.24176, 0.24176, 0.24863, 0.24863, 0.26161, 0.26161, 0.27382, 0.27382, 0.2835, 0.2835, 0.25422, 0.25422, 0.24563, 0.24563, 0.24361, 0.24361, 0.23399, 0.23399, 0.26532, 0.26532, 0.26532, 0.26532, 0.26532, 0.26532, 0.26532, 0.26532, 0.26532, 0.26532, 0.26532, 0.26532, 0.26532, 0.26532, 0.26532, 0.26532, 0.26532, 0.26532],
'prod_price_forecast': [0.25749, 0.25749, 0.25227, 0.25227, 0.24346, 0.24346, 0.24236, 0.24236, 0.23582, 0.23582, 0.23389, 0.23389, 0.24176, 0.24176, 0.24863, 0.24863, 0.26161, 0.26161, 0.27382, 0.27382, 0.2835, 0.2835, 0.25422, 0.25422, 0.24563, 0.24563, 0.24361, 0.24361, 0.23399, 0.23399, 0.26532, 0.26532, 0.26532, 0.26532, 0.26532, 0.26532, 0.26532, 0.26532, 0.26532, 0.26532, 0.26532, 0.26532, 0.26532, 0.26532, 0.26532, 0.26532, 0.26532, 0.26532],
'pv_power_forecast': [289, 387, 438, 338, 325, 547, 745, 843, 823, 769, 703, 620, 537, 457, 397, 303, 169, 84, 23, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 15, 84, 184, 364],
'prediction_horizon': 48, 'soc_init': 0.94, 'soc_final': 0.1, 'alpha': 0.25, 'beta': 0.75, 'num_def_loads': 3, 'P_deferrable_nom': [1000, 500, 200], 'treat_def_as_semi_cont': [1, 1, 0], 'set_def_constant': [1, 0, 0], 'def_total_hours': [2, 2, 1], 'def_start_timestep': [22, -2, 26], 'def_end_timestep': [46, 22, 30]}
2024-03-11 09:20:10,306 - web_server - INFO - >> Setting input data dict
2024-03-11 09:20:10,307 - web_server - INFO - Setting up needed data
2024-03-11 09:20:10,408 - web_server - INFO - Retrieve hass get data method initiated...
2024-03-11 09:20:15,773 - web_server - INFO - Retrieving weather forecast data using method = list
2024-03-11 09:20:15,777 - web_server - INFO - Retrieving data from hass for load forecast using method = mlforecaster
