I would like to use Alexa to increase and decrease the volume of my amp, which is triggered via command line(IR transmitter). I have it working when I say “Alexa, turn on VolUp”. It’s a bit of a kludge, and I think I can do better so here we go…
I created an Emulated Hue Script that allows me to say “Alexa, increase Emulated Hue” and the brightness value increases. Ideally, I would like to set the brightness to, say 100, upon HA startup and have Alexa increase and decrease the brightness from there. From there I could fire volume up or down IR commands depending if the brightness was more or less an 100.
My issue is that I’m able to set the brightness of the Emulated Hue script via Alexa, but am not able to set it from within Home Assistant.
As a reality check I’ve done the following: In HA Developer Tools -> Services: Domain = light, Service = turn_on, Service Data = { “entity_id” : “light.kitchen_island”, “brightness” : “200” }, click [Call Service] and voila the brightness is set to 200 when I view it at: http://localhost:8300/api/pi/lights. When I try the same Data command with the Emulated Hue entity_id (script.jefferson the Emulated Hue), and visit http://localhost:8300/api/pi/lights I get no joy. The value of the Emulated Hue script haven’t changed. I’m wondering why the Emulated Hue Script brightness level from within Home Assistant won’t change, even though Alexa can do it without any problems.
Thoughts:
Can an Emulated Hue script “device” be dimmed? I’ve tried a boolean_switch based Emulated Hue “device” as well, but still no dice. Is this a limitation of Emulated Hue? Should I be using HA Bridge instead? Is there a another/better way to dim the Emulated Hue script via Home Assistant?
Any pointers from the community would be greatly appreciated.
Cheers,
Mike
configuration.yaml
customize:
script.jefferson:
friendly_name: 'Emulated Hue'
emulated_hue: true
emulated_hue:
host_ip: 192.168.1.x
listen_port: 8300
