Emulated Hue Issue- Trying to change setting
2019-04-22 16:25:48 ERROR (MainThread) [homeassistant.components.emulated_hue.hue_api] Entity not exposed: switch.nodemcu_01
I’ve tried everything I can think of and I keep having this show up. It just keeps trying and trying over and over. Under emulated hue I tried to have this entity hidden, but it still shows up. What is the proper way in your opinion to reset. Like with Homekit I can just remove home or delete the file. Anything like this for Amazon devices? Like a way to start fresh.
It seems like once the entities are in there it’s impossibly for Home Assistant to not search for them. Like there is a residual. Or am I missing something?
2019-04-22 16:25:58 ERROR (MainThread) [homeassistant.components.emulated_hue.hue_api] Entity not exposed: switch.nodemcu_01
2019-04-22 16:26:22 ERROR (MainThread) [homeassistant.components.emulated_hue.hue_api] Entity not exposed: switch.nodemcu_01
2019-04-22 16:26:41 ERROR (MainThread) [homeassistant.components.emulated_hue.hue_api] Entity not exposed: switch.sonoff_01
2019-04-22 16:26:54 ERROR (MainThread) [homeassistant.components.emulated_hue.hue_api] Entity not exposed: switch.sonoff_01
2019-04-22 16:27:01 ERROR (MainThread) [homeassistant.components.emulated_hue.hue_api] Entity not exposed: switch.sonoff_01
2019-04-22 16:27:15 ERROR (MainThread) [homeassistant.components.emulated_hue.hue_api] Entity not exposed: switch.sonoff_01
2019-04-22 16:27:58 ERROR (MainThread) [homeassistant.components.emulated_hue.hue_api] Entity not exposed: switch.nodemcu_01
2019-04-22 16:28:11 ERROR (MainThread) [homeassistant.components.emulated_hue.hue_api] Entity not exposed: switch.sonoff_01
2019-04-22 16:30:12 ERROR (MainThread) [homeassistant.components.emulated_hue.hue_api] Entity not exposed: switch.sonoff_wall_switch_02
2019-04-22 16:30:20 ERROR (MainThread) [homeassistant.components.emulated_hue.hue_api] Entity not exposed: switch.sonoff_wall_switch_02
2019-04-22 16:30:26 ERROR (MainThread) [homeassistant.components.emulated_hue.hue_api] Entity not exposed: switch.sonoff_wall_switch_02
2019-04-22 16:30:48 ERROR (MainThread) [homeassistant.components.emulated_hue.hue_api] Entity not exposed: switch.sonoff_wall_switch_02
2019-04-22 16:31:55 ERROR (MainThread) [homeassistant.components.emulated_hue.hue_api] Entity not exposed: switch.sonoff_01
2019-04-22 16:32:16 ERROR (MainThread) [homeassistant.components.emulated_hue.hue_api] Entity not exposed: switch.sonoff_wall_switch_02
2019-04-22 16:34:22 ERROR (MainThread) [homeassistant.components.emulated_hue.hue_api] Entity not exposed: switch.nodemcu_01
Just an endless loop of errors.
As I said…
Mon Apr 22 2019 17:04:15 GMT-0700 (Pacific Daylight Time)
Error handling request
File “/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py”, line 418, in start
resp = await task
File “/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py”, line 458, in _handle
resp = await handler(request)
File “/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py”, line 119, in impl
return await handler(request)
File “/usr/local/lib/python3.7/site-packages/homeassistant/components/http/real_ip.py”, line 33, in real_ip_middleware
File “/usr/local/lib/python3.7/site-packages/homeassistant/components/http/view.py”, line 112, in handle
result = handler(request, **request.match_info)
File “/usr/local/lib/python3.7/site-packages/homeassistant/components/emulated_hue/hue_api.py”, line 172, in get
entity = hass.states.get(entity_id)
File “/usr/local/lib/python3.7/site-packages/homeassistant/core.py”, line 829, in get
return self._states.get(entity_id.lower())
AttributeError: ‘NoneType’ object has no attribute ‘lower’
I deleted everything in alexa and kept getting cant discover on all devices now.
Ok so I deleted type: alexa as per wiki page.and I get the error above.
Here is my .yaml
#  type: alexa
  host_ip: 192.168.1.20
  listen_port: 80
  off_maps_to_on_domains:
  expose_by_default: false
#  exposed_domains:
#    - light
#    - switch
#    - input_boolean
#    - fan
#    - cover
#    - alarm_control_panel
  entities:
#    switch.sonoff_01:
#      hidden: true
#    switch.sonoff_wall_switch_02:
#      hidden: true
#    switch.nodemcu_01:
#      hidden: true
    cover.garage_door:
    light.homeseer_hswd100_wall_dimmer_level:
      name: "Living Room Light"
    light.homeseer_hswd100_wall_dimmer_level_2:
    light.homeseer_hswd100_wall_dimmer_level_3:
Any other ideas what I’m messing up here? It’s getting so frustrating becuase I just want to set expose by default to false and add my own entities. I am approaching more than 45 now.
OMG it was the port. I just changed the port and all is well!!
Sorry about all of this.
I’m having the same problem. I want to “reset” all the Alexa devices and start fresh, but when I discover again, I get all the old devices. I’ve tried EVERYTHING except the correct one…
So, I have about 38 devices and a few groups. Z-wave lights, TP-link switches and such. After the Echo update things went crazy, I changed the emulated_hue to port 80, removed all devices and re-discovered on the alexa.amazon.com website and it worked, but gave the “this device appears not to be working” but worked. The wife started to complain, so I decided to fix it… Deleted the emulated_hue_id.yaml file - then re-discover the devices. At first I was getting 3-4 copies of each. I’ve tried different hue ports, I do a reboot of the Pi, not just a service restart - but it seems Hassio has a cache of the emulated_hue_id file in components/emulated_hue/hue_api.py - where ever that is. I do not know much about Docker but that it is like little VMs. I looked for it…
Anyway, I have set the emulated_hue in the config file to exposed_by_default: false
Here is my config - I have tried to setup one of the z-wave
emulated_hue:
  host_ip: 192.168.1.23
  listen_port: 80
    - scene
    - script
#  exposed_domains:
#   - light
#    - switch
#   - group
  entities:
    light.jims_den_lamp_level:
      hidden: false
Here is a sample of the error log I get, after deleting the emulated_hue_ids file.
Unknown entity number: 12 not found in emulated_hue_ids.json
5:43 PM components/emulated_hue/hue_api.py (ERROR) - message first occured at 5:31 PM and shows up 24 times
It shows 38 or so devices, why doesn’t it clear, and how can I reset it.
Thanks for reading!
jim
A piece of advice. Delete each device individually in the Amazon Alexa UI and run Discover again. Your actual valid devices should show up.
Thanks PeteA that did work and only 1 of the devices showed up. But the problems continued. I read it’s the bridge listing all the devices as lights and need a dim setting or it craps out.
Anyway, it’s a losing battle. emulated_hue in HA is pretty much dead. I went ahead and moved to the HA cloud thing, works great and took a few minutes to setup. I already used the Alexa script tools, have to open a port, but will continue it to use it for my sensors.
It will cost $5 a month, oh well, another thing to pay for. I’m glad the HA guys might make a little money, I’ve been using there tech for free for years, they deserve it.
I don’t like the fact that I can’t run the z-wave and IP switches local. I will have to work on that, but until then, the wife is happy and the lights work!!
thx
Search the forum a bit more. I think I saw a solution that may work that doesn’t involve a subscription. The Hue emulator is a bit of a mess at the moment though.
Have a look at this Emulated Hue suddenly stopped working with Echo Dot V2
Does somebody have a solution to reduce the number of exposed entities? If I set it to exposed by default false it does not expose ANY. How are we supposed to change the configuration ?
by following the direction and exposing what you want to expose…
taking a look at the provided example:
# Example configuration.yaml entry
emulated_hue:
  host_ip: 192.168.1.186
  listen_port: 8300
  advertise_ip: 10.0.0.10
  advertise_port: 8080
    - script
    - scene
  expose_by_default: true
  exposed_domains:
    - light
  entities:
    light.bedroom_light:
    light.ceiling_lights:
      hidden: true #<------ THIS WILL HIDE/UNHIDE
I appreciate your answer.
Do you mean that I can not do it the other way around?
I tried setting expose_by_default to false and specified the entities. But this leads to an empty entities list.
Is hiding the only way of changing the behavior? Once you setup emulated_hue once there is no way back to choose a different strategy?
exposed_domains:
- light
entities:
    hidden: false
to get just light.bedroom_light
Again, thank you. Here is my actual configuration:
host_ip: 192.168.0.12
listen_port: 80
exposed_domains:
  - input_boolean
  - switch
entities:
  switch.xperia_video_recording:
  switch.xperia_torch:
  input_boolean.camera_hall:
  switch.sonoff_relay:
That configuration led me to several warnings on my log about the entities not being exposed and the /api/pi/lights to return an empty value.
As I said before, I started with a simple configuration like this:
listen_port: 80
exposed_domains:
  - input_boolean
  - switch
  - lights
And now I want to restrict it
So add hidden: false for each one under name.
Ok, I’ll try that and report
Hey! that worked! thank you very much
Thank you for this… this was my third attempt to try to get only few lights and switches to show on my harmony hub. I spent way too much time it should be part of the documentation for anyone trying to set up emulated hue on HA.
my working config…
emulated_hue:
  host_ip: 192.168.1.XX
  listen_port: 8300
    - script
    - scene
  exposed_domains:
    - light
    - switch
    - input_boolean
  entities:
    light.88568006cc50e34432eb:
      name: "Theater Wall Scones"
      hidden: false
    switch.theater_room_pots:
      hidden: false
    switch.bar_cabinets:
      name: "Bar Cabinets"
      hidden: false
    switch.bar_light:
      hidden: false
    switch.basement_loft:
      hidden: false
    switch.basement_stair:
      hidden: false
I have two homes with near identical HA configurations. Both are doing what I am about to describe.
I added some color bulbs to my lamps and created a group then in emulated hue I replace the original light.xxx entity to a group.xxx entity. rebooted but alexa still controls the original bulb and not the new group. I deleted the emulated.hue.json.id file and again rebooted, same result. I then deleted all my alexa devices manually in the alexa app one by one, deleted the json.id file again, did a cold hard reboot (by removing power from HA). and re-discovered my devices. Again the original bulb is being controlled and not my new group. I have another group in emulated hue which is working so I know I have the visibility settings ok. Why will it not change to my new device? I really don’t want to call it something else as the wf is used to how things work. Thankx for any advise in advance. J
PS, I have updated to the latest and greatest release as of 2/2/21 (both core and op-sys, using ras-pi HASS canned load)
