Oddly enough I forgot that I had tried HA Bridge while I was following that post and had the same issue of the Echo not finding anything even though it works via the HA Bridge console. I went out of town and then got sidetracked by the 0.29.X segmentation fault problems. Now that I remember, I think I was starting go down other troubleshooting routes. If my actual Hue bridge is causing issues, being on a VM and virtual network interface that is tied to a physical 802.3ad Link Aggregated port, router blocking something, etc.
This is interesting. I have Hue emulation and HA Bridge both working in my home. I’ve been thinking of setting up Haaska so that I could do “Alexa, tell Home Assistant to…” types of commands.
Are you saying that if I set up Haaska, it automatically exposes everything in my HA configuration?
It does, however it’s pretty easy to add a line to your customize to disable them. What I was doing, just a first world problem.
Just as a follow up to this, received a few additional echo dot’s (v2) and soon as I connected them up it started to work as expected and all of my emulated hue devices showed up as expected. Makes me believe something was not working on the Echo end or network.
I got my 2 new dots as well and no luck getting anything working. This is what I keep getting in the error log for Home assistant:
16-10-20 16:57:57 homeassistant.components.light.hue: Error connecting to the Hue bridge at 192.168.86.148
I’ve had no luck with HA Bridge either, I think there is a problem if you have LetsEncrypt SSL certificate (HA-Bridge Issue#183).
I could go the skill route, but I really hate having to say “ask home assistant”.
Never mind!!! it all works now … don’t ask me how but emulated hue just started working for some reason.
Same thing, wonder if it has something to do with the software update they pushed to the Echo. Also that error you’re seeing I believe is caused by HA thinking you are running an actual Hue hub and trying to connect.
Mine started working as well. Not sure when but all devices are seen in Alexa! - DAMN! Spoke too soon. I had it forget all devices and groups and now won’t discover any again… argh… frustrating.
I had a similar issue that went away after I pinged my Amazon Echo from the RPi that HA is running on. Echo doesn’t respond to pings, but I confirmed that ARP was working (“arp -a” at the command line), so devices were able to reach other.
After the ping, I did a discovery on the Echo and everything showed up. It might be a coincidence, but it’s worth a try.
Hey, guys!
Is this supposed to work on Windows? I get WinError 10049 “The requested address is not valid in its context”.
Don’t know what to do with it.
Hey CCostan. Do this.
1 Clear devices
2 Reinitialize HA-Bridge
3 change your emulated_hue: section in configuration.yaml to only show emulated_hue:
So if at first it was something like
emulated_hue:
host_ip: 192.168.0.10
listen_port: 8300
expose_by_default: true
exposed_domains:
- light
change it to
emulated_hue:
4 Do a restart of HA via Developers Tools - Services
5 Discover Devices in your Alexa App
6 Forget Devices you don’t need.
7 change your emulated_hue: section in configuration.yaml back into:
emulated_hue:
listen_port: 8300
exposed_domains:
- light
5 Do another restart of HA via Developers Tools - Services
6 Start talking sweet to your “other woman” Alexa.
You will want to do the following
When you say:
…you mean?
I’m having similar problems with the Emulated Hue component, am I missing a HA Bridge component? I don’t have anything like that configured…
It means that you have to have HA-Bridge installed.
One you have done that go to HA-Bridge control panel in your browser and reinitialize bridge under Bridge Control
I have my HA on a windows 10 machine, echo is not getting any device discovered. The reason is because HA is on windows?
tried this, they see each other, but nothing, no discovery
Very strange – My Emulated Hue configuration is simple:
# Emulated Hue
emulated_hue:
host_ip: x.x.x.x
x.x.x.x is the IP address of my RPi.
Trying this without the HA Bridge, I am on windows. Still no luck in discovering
Sorry to resurrect this thread, but I have the same issue - but slightly different symptoms:
- emulated_hue used to work fine
- now Alexa does not discover anything anymore
- But I can still control the devices that once got discovered
- http://:8300/description.xml looks ok
- http://:8300/api/pi/lights shows 500 internal server error
My config:
emulated_hue: host_ip: [raspberry IP removed] expose_by_default: true exposed_domains: - group - input_boolean - media_player - switch - scene
Any ideas what this could be?
I just updated to 0.33.4, before that the /api/pi/lights call just produced an empty response, no error - the rest of the behaviour was the same.
Edit:
- I realized not all previously discovered devices work. Actually, only one Lightify Switch works (connected to the Hue bridge, but the bridge does not offer it to Alexa - it only works through HASS). The LG hombot and Yamaha receiver don’t work anymore via Alexa, she claims the hub these devices are connected to is offline
- When I remove (comment) the whole emulated_hue section, both description.xml and api/pi/lights get a 404 error (makes sense), when I even only add the line “emulated_hue:”, the description.xml works, api/pi/light shows the 500 error - so it’s not related to my settings.
I’m still stuck and would appreciate any idea…
I found errors in home-assistant.log:
16-12-10 22:51:57 homeassistant.components.light.hue: Error connecting to the Hue bridge at x.x.x.x
16-12-10 22:54:18 aiohttp.web: Error handling request
File "/home/homeassistant/.homeassistant/deps/aiohttp/server.py", line 265, in start
yield from self.handle_request(message, payload)
File "/home/homeassistant/.homeassistant/deps/aiohttp/web.py", line 96, in handle_request
resp = yield from handler(request)
File "/usr/lib/python3.4/asyncio/coroutines.py", line 143, in coro
res = yield from res
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/http/__init__.py", line 400, in handle
result = handler(request, **request.match_info)
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/emulated_hue/hue_api.py", line 69, in get
json_response[number] = entity_to_json(entity)
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/emulated_hue/hue_api.py", line 255, in entity_to_json
ATTR_EMULATED_HUE_NAME, entity.attributes[ATTR_FRIENDLY_NAME])
KeyError: 'friendly_name'
The first line appears at startup of HASS, the rest every time I call the /api/pi/lights URL and see the 500 internal server error. I did not change the set-up of my Raspberry Pi, but now updated HA to 0.34.4, but no change.
Any help is highly appreciated!
