Enegic intergration
@edvinerikson I would love to try out your component if possible to share it
+1, would love to give it a shot! Thanks!
I totally forgot about this thread. No notifications either :frowning:
Here is the custom component: GitHub - Pokeyo-AB/homeassistant-perific
Thanks,
But I can’t get the API to respond with any data. Authorization is OK and I get some information from the API but not the relevant.
Is there some pre-requisites that is needed for this to work?
Regards PH2
Thanks Edvin!
Have been waiting for this! It works really well with hourly energy reading and can get rid of my other p1 dongle and splitter!
Great work! :clap:
I manage to add the integration but I don’t get any readings.
Does anyone have any advice on what I should do for troubleshooting?
Hi, I think I have a similar issue as you. Did you find a solution?
Have a issue in github:
In the end I forked his repo added openapi and now get all sensors per device. Created a PR in his repo.
I got it to work on my setup but as usual your mileage may vary.
Now what is left is to find out what do do with all those 80(!) sensors per device?
Hey! I’m not sure how i do that. I also managed to get it installed but get no readings. Can you share your repo instead?
Sure!
I’m not using it since I don’t have a use case for it right now but it “should” work.
Any progress?
Yes, it works! But I had to have a USB-C for power as it could drive both at the same time. Works like a charm.
Legend! Thanks a lot! To think I nearly bought a p1 splitter as well…
I merged some PRs now. Seems the API response variate a lot depending on what hardware you have.
