Sorry, wish I could help on the HA front but I stopped using it a while back, I’m focussing on Vera & OpenLuup. Although I’ll no doubt pick it up again at some point…
Hello, I am in the process of switching to HA and would like to integrate my LAN socket.
I discovered your MQTT script and wanted to try it right away.
Can you adapt the scripts to newer Python versions?
I can not start the scripts because I always get error messages that modules can not be imported, syntax errors and so on.
And from debugging and programming I have no plan.
Hi together,
I know this is a quite bit old thread, but this helped me out to get my EG-PMS2-LAN working properly (so far I can see) with home assistant.
So I will share my working config. The problem at @acme s post was, that the logout need the curl -X GET command.
Also the value of the socket should be determined in other way.
- switch:
name: EG-PMS2-LAN Nord - Socket 4
command_on: curl -s -d "pw=1" http://192.168.178.50/login.html && curl -s -d "cte4=1" http://192.168.178.50/ && curl -X GET http://192.168.178.50/login.html
command_off: curl -s -d "pw=1" http://192.168.178.50/login.html && curl -s -d "cte4=0" http://192.168.178.50/ && curl -X GET http://192.168.178.50/login.html
command_state: curl -s -d "pw=1" http://192.168.178.50/login.html && curl -X GET http://192.168.178.50/ && curl -X GET http://192.168.178.50/login.html
value_template: '{{ value.split("sockstates = ")[1].split("]")[0].replace("[", "").split(",")[3] == "1" }}'
I hope my post can help someone else, to get this working.
@Lordas, i have tried your suggestion but the problem remains the same.
After restarting the Home Assistant, all switches are displayed as “OFF”.
But two of my switches are definitely on. Am I doing something wrong?
Hi! Even though this is a quite old thread, I wanted to share my Node-RED flow with you. With the flow, I’m able to control an Energenie PMS2 LAN and retrieve its state. For the control via HA, I created switches from within Node-RED that will be registered in HA.
[{"id":"01d019b793c41636","type":"subflow","name":"Energenie PMS2 LAN","info":"","category":"home_assistant","in":[],"out":[{"x":520,"y":80,"wires":[{"id":"e565f6a5ed297146","port":1},{"id":"e565f6a5ed297146","port":0}]},{"x":520,"y":120,"wires":[{"id":"e0ff63322b58363c","port":0},{"id":"e0ff63322b58363c","port":1}]},{"x":520,"y":160,"wires":[{"id":"38c6654c48c27496","port":0},{"id":"38c6654c48c27496","port":1}]},{"x":520,"y":200,"wires":[{"id":"e9c92f4bee849acc","port":0},{"id":"e9c92f4bee849acc","port":1}]}],"env":[],"meta":{},"color":"#AAAA66","outputLabels":["Socket 1","Socket 2","Socket 3","Socket 4"],"icon":"font-awesome/fa-power-off","status":{"x":480,"y":40,"wires":[{"id":"299e6c990ec0b33e","port":0}]}},{"id":"e565f6a5ed297146","type":"ha-switch","z":"01d019b793c41636","name":"Energenie PMS2 LAN Socket 1","version":0,"debugenabled":false,"inputs":1,"outputs":2,"entityConfig":"be97b35209b5413a","enableInput":true,"outputOnStateChange":true,"outputProperties":[{"property":"outputType","propertyType":"msg","value":"state change","valueType":"str"},{"property":"state","propertyType":"msg","value":"","valueType":"entityState"},{"property":"socket","propertyType":"msg","value":"1","valueType":"num"}],"x":270,"y":80,"wires":[[],[]]},{"id":"e0ff63322b58363c","type":"ha-switch","z":"01d019b793c41636","name":"Energenie PMS2 LAN Socket 2","version":0,"debugenabled":false,"inputs":1,"outputs":2,"entityConfig":"83a6eda8aa9174c5","enableInput":true,"outputOnStateChange":true,"outputProperties":[{"property":"outputType","propertyType":"msg","value":"state change","valueType":"str"},{"property":"state","propertyType":"msg","value":"","valueType":"entityState"},{"property":"socket","propertyType":"msg","value":"2","valueType":"num"}],"x":270,"y":120,"wires":[[],[]]},{"id":"38c6654c48c27496","type":"ha-switch","z":"01d019b793c41636","name":"Energenie PMS2 LAN Socket 3","version":0,"debugenabled":false,"inputs":1,"outputs":2,"entityConfig":"8c36f378721f4365","enableInput":true,"outputOnStateChange":true,"outputProperties":[{"property":"outputType","propertyType":"msg","value":"state change","valueType":"str"},{"property":"state","propertyType":"msg","value":"","valueType":"entityState"},{"property":"socket","propertyType":"msg","value":"3","valueType":"num"}],"x":270,"y":160,"wires":[[],[]]},{"id":"e9c92f4bee849acc","type":"ha-switch","z":"01d019b793c41636","name":"Energenie PMS2 LAN Socket 4","version":0,"debugenabled":false,"inputs":1,"outputs":2,"entityConfig":"086a81c8c6ddc220","enableInput":true,"outputOnStateChange":true,"outputProperties":[{"property":"outputType","propertyType":"msg","value":"state change","valueType":"str"},{"property":"state","propertyType":"msg","value":"","valueType":"entityState"},{"property":"socket","propertyType":"msg","value":"4","valueType":"num"}],"x":270,"y":200,"wires":[[],[]]},{"id":"299e6c990ec0b33e","type":"status","z":"01d019b793c41636","name":"","scope":null,"x":340,"y":40,"wires":[[]]},{"id":"setLoginData","type":"function","z":"f1","name":"Set Login Data","func":"msg.headers = {\n 'Content-Type': 'application/x-www-form-urlencoded'\n};\nmsg.payload = 'pw=1';\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":1540,"y":620,"wires":[["loginRequest"]]},{"id":"loginRequest","type":"http request","z":"f1","name":"Login Request","method":"POST","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.200/login.html","tls":"","persist":false,"proxy":"","insecureHTTPParser":true,"authType":"","senderr":false,"headers":[],"x":1720,"y":620,"wires":[["captureCookies"]]},{"id":"captureCookies","type":"function","z":"f1","name":"Capture Cookies","func":"if (msg.responseHeaders && msg.responseHeaders['set-cookie']) {\n msg.headers = {\n 'Cookie': msg.responseHeaders['set-cookie'].join(';')\n };\n}\nreturn msg;","outputs":1,"noerr":0,"x":1910,"y":620,"wires":[["firstGetRequest"]]},{"id":"firstGetRequest","type":"http request","z":"f1","name":"First GET Request","method":"GET","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.200/","tls":"","persist":false,"proxy":"","insecureHTTPParser":true,"authType":"","senderr":false,"headers":[],"x":2110,"y":620,"wires":[["secondGetRequest","parseStateNode"]]},{"id":"secondGetRequest","type":"http request","z":"f1","name":"Second GET Request","method":"GET","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.200/login.html","tls":"","persist":false,"proxy":"","insecureHTTPParser":true,"authType":"","senderr":false,"headers":[],"x":2340,"y":620,"wires":[["953135ad3c5cfa6d"]]},{"id":"b137ac1254fcc816","type":"inject","z":"f1","name":"Refresh Status","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"30","crontab":"","once":true,"onceDelay":"20","topic":"","payload":"","payloadType":"date","x":1100,"y":660,"wires":[["758dde869105defe"]]},{"id":"parseStateNode","type":"function","z":"f1","name":"Parse Socket States","func":"var htmlContent = msg.payload;\nvar start = htmlContent.indexOf(\"var sockstates = [\") + \"var sockstates = [\".length;\nvar end = htmlContent.indexOf(\"];\", start);\nvar statesString = htmlContent.substring(start, end);\nvar statesArray = statesString.split(\",\").map(function(item) {\n return parseInt(item, 10);\n});\nmsg.payload = statesArray;\n\nreturn [{ socket: 1, enable: true ? statesArray[0] == 1 : false }, { socket: 2, enable: true ? statesArray[1] == 1 : false}, { socket: 3, enable: true ? statesArray[2] == 1 : false}, { socket: 4, enable: true ? statesArray[3] == 1 : false}];","outputs":4,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":2340,"y":540,"wires":[["c68516e138dafa44"],["c68516e138dafa44"],["c68516e138dafa44"],["c68516e138dafa44"]]},{"id":"02f7c808f5a8e276","type":"function","z":"f1","name":"Set Login Data","func":"msg.headers = {\n 'Content-Type': 'application/x-www-form-urlencoded'\n};\nmsg.payload = 'pw=1';\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":1360,"y":740,"wires":[["41765c2afe939963"]]},{"id":"41765c2afe939963","type":"http request","z":"f1","name":"Login Request","method":"POST","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.200/login.html","tls":"","persist":false,"proxy":"","insecureHTTPParser":true,"authType":"","senderr":false,"headers":[],"x":1540,"y":740,"wires":[["67eb172462049459"]]},{"id":"67eb172462049459","type":"function","z":"f1","name":"Capture Cookies","func":"if (msg.responseHeaders && msg.responseHeaders['set-cookie']) {\n msg.headers = {\n 'Cookie': msg.responseHeaders['set-cookie'].join(';')\n };\n}\nreturn msg;","outputs":1,"noerr":0,"x":1730,"y":740,"wires":[["befeef3766944041"]]},{"id":"befeef3766944041","type":"function","z":"f1","name":"Command On","func":"msg.payload = msg.on_command;\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1920,"y":740,"wires":[["da118aead47d2ae6"]]},{"id":"da118aead47d2ae6","type":"http request","z":"f1","name":"First POST Request","method":"POST","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.200/","tls":"","persist":false,"proxy":"","insecureHTTPParser":true,"authType":"","senderr":false,"headers":[],"x":2120,"y":740,"wires":[["1edc16f156e5b439"]]},{"id":"1edc16f156e5b439","type":"http request","z":"f1","name":"Second GET Request","method":"GET","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.200/login.html","tls":"","persist":false,"proxy":"","insecureHTTPParser":true,"authType":"","senderr":false,"headers":[],"x":2340,"y":740,"wires":[["18997a853b92cdc3"]]},{"id":"57be4a7aee6abfb6","type":"function","z":"f1","name":"Set Login Data","func":"msg.headers = {\n 'Content-Type': 'application/x-www-form-urlencoded'\n};\nmsg.payload = 'pw=1';\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":1360,"y":820,"wires":[["335cae384c31e3f5"]]},{"id":"335cae384c31e3f5","type":"http request","z":"f1","name":"Login Request","method":"POST","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.200/login.html","tls":"","persist":false,"proxy":"","insecureHTTPParser":true,"authType":"","senderr":false,"headers":[],"x":1540,"y":820,"wires":[["b67665b72b7d6f99"]]},{"id":"b67665b72b7d6f99","type":"function","z":"f1","name":"Capture Cookies","func":"if (msg.responseHeaders && msg.responseHeaders['set-cookie']) {\n msg.headers = {\n 'Cookie': msg.responseHeaders['set-cookie'].join(';')\n };\n}\nreturn msg;","outputs":1,"noerr":0,"x":1730,"y":820,"wires":[["c393d6f9cf84e0e9"]]},{"id":"c393d6f9cf84e0e9","type":"function","z":"f1","name":"Command Off","func":"msg.payload = msg.off_command;\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1920,"y":820,"wires":[["f031c09223b4678b"]]},{"id":"f031c09223b4678b","type":"http request","z":"f1","name":"First POST Request","method":"POST","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.200/","tls":"","persist":false,"proxy":"","insecureHTTPParser":true,"authType":"","senderr":false,"headers":[],"x":2120,"y":820,"wires":[["ee3b823ba3ac910a"]]},{"id":"ee3b823ba3ac910a","type":"http request","z":"f1","name":"Second GET Request","method":"GET","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.200/login.html","tls":"","persist":false,"proxy":"","insecureHTTPParser":true,"authType":"","senderr":false,"headers":[],"x":2340,"y":820,"wires":[["18997a853b92cdc3"]]},{"id":"4673f8c089bc5685","type":"ha-switch","z":"f1","name":"Energenie PMS2 LAN Socket 1","version":0,"debugenabled":false,"inputs":1,"outputs":2,"entityConfig":"be97b35209b5413a","enableInput":true,"outputOnStateChange":false,"outputProperties":[{"property":"outputType","propertyType":"msg","value":"state change","valueType":"str"},{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"x":2910,"y":480,"wires":[[],[]]},{"id":"c68516e138dafa44","type":"switch","z":"f1","name":"socket","property":"socket","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"2","vt":"num"},{"t":"eq","v":"3","vt":"num"},{"t":"eq","v":"4","vt":"num"}],"checkall":"true","repair":false,"outputs":4,"x":2650,"y":540,"wires":[["4673f8c089bc5685"],["2c52f4f79e453991"],["bc285305e66dedd5"],["4514bf9ff596a115"]]},{"id":"2c52f4f79e453991","type":"ha-switch","z":"f1","name":"Energenie PMS2 LAN Socket 2","version":0,"debugenabled":false,"inputs":1,"outputs":2,"entityConfig":"83a6eda8aa9174c5","enableInput":true,"outputOnStateChange":false,"outputProperties":[{"property":"outputType","propertyType":"msg","value":"state change","valueType":"str"},{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"x":2910,"y":520,"wires":[[],[]]},{"id":"bc285305e66dedd5","type":"ha-switch","z":"f1","name":"Energenie PMS2 LAN Socket 3","version":0,"debugenabled":false,"inputs":1,"outputs":2,"entityConfig":"8c36f378721f4365","enableInput":true,"outputOnStateChange":false,"outputProperties":[{"property":"outputType","propertyType":"msg","value":"state change","valueType":"str"},{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"x":2910,"y":560,"wires":[[],[]]},{"id":"4514bf9ff596a115","type":"ha-switch","z":"f1","name":"Energenie PMS2 LAN Socket 4","version":0,"debugenabled":false,"inputs":1,"outputs":2,"entityConfig":"086a81c8c6ddc220","enableInput":true,"outputOnStateChange":false,"outputProperties":[{"property":"outputType","propertyType":"msg","value":"state change","valueType":"str"},{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"x":2910,"y":600,"wires":[[],[]]},{"id":"def838de3811e963","type":"function","z":"f1","name":"Build on/off command","func":"if(msg.socket != null) {\n msg.on_command = \"cte\" + msg.socket + \"=1\";\n msg.off_command = \"cte\" + msg.socket + \"=0\";\n\n return msg;\n}\nreturn null;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":360,"y":780,"wires":[["83d74c70e1b961f4"]]},{"id":"e5d04d31aa1602e8","type":"switch","z":"f1","name":"state","property":"state","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":1110,"y":780,"wires":[["7001db3fc031d641"],["74e2b81cc6ad7612"]]},{"id":"3b127957309ffcc5","type":"link in","z":"f1","name":"energenie_http_status_req","links":["18997a853b92cdc3"],"x":985,"y":620,"wires":[["1906db841a270229"]]},{"id":"1906db841a270229","type":"delay","z":"f1","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1100,"y":620,"wires":[["758dde869105defe"]]},{"id":"18997a853b92cdc3","type":"link out","z":"f1","name":"call_energenie_http_status_req","mode":"link","links":["3b127957309ffcc5"],"x":2475,"y":780,"wires":[]},{"id":"97b20f3a84201ad5","type":"subflow:01d019b793c41636","z":"f1","name":"","x":120,"y":780,"wires":[["def838de3811e963"],["def838de3811e963"],["def838de3811e963"],["def838de3811e963"]]},{"id":"758dde869105defe","type":"function","z":"f1","name":"status_request_in_progress","func":"flow.set('status_request_in_progress', true);\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1320,"y":620,"wires":[["setLoginData"]]},{"id":"953135ad3c5cfa6d","type":"function","z":"f1","name":"status_request_in_progress","func":"flow.set('status_request_in_progress', false);\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":2580,"y":620,"wires":[[]]},{"id":"8ff6257e0e4473f1","type":"catch","z":"f1","name":"","scope":["loginRequest","firstGetRequest","secondGetRequest"],"uncaught":false,"x":2390,"y":660,"wires":[["953135ad3c5cfa6d"]]},{"id":"844832e4da8d8d90","type":"switch","z":"f1","name":"status_request_in_progress","property":"status_request_in_progress","propertyType":"flow","rules":[{"t":"null"},{"t":"false"},{"t":"true"}],"checkall":"true","repair":false,"outputs":3,"x":740,"y":780,"wires":[["52da96df4ea94f83"],["52da96df4ea94f83"],["158fe09d9d3db270"]]},{"id":"5e3818ecb5f273d3","type":"function","z":"f1","name":"Update Send retry","func":"var send_retry = flow.get(\"command_send_retry\") || 0;\nsend_retry += 1;\nflow.set(\"command_send_retry\", send_retry);\n\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":610,"y":920,"wires":[["1dd1a03030f11f7f"]]},{"id":"70942ba9a70415b1","type":"delay","z":"f1","name":"","pauseType":"delay","timeout":"100","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":940,"y":920,"wires":[["33896c0e31361873"]]},{"id":"1dd1a03030f11f7f","type":"switch","z":"f1","name":"","property":"command_send_retry","propertyType":"flow","rules":[{"t":"lte","v":"100","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":770,"y":920,"wires":[["70942ba9a70415b1"],[]]},{"id":"e833d39ca784ba5b","type":"inject","z":"f1","name":"Reset status_request_in_progress","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":340,"y":280,"wires":[["7f2bfced54b7e312"]]},{"id":"7f2bfced54b7e312","type":"function","z":"f1","name":"status_request_in_progress","func":"flow.set('status_request_in_progress', false);\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":620,"y":280,"wires":[[]]},{"id":"33896c0e31361873","type":"link out","z":"f1","name":"link out 110","mode":"link","links":["e9dbcaf3ece8b29f"],"x":1075,"y":920,"wires":[]},{"id":"e9dbcaf3ece8b29f","type":"link in","z":"f1","name":"link in 63","links":["33896c0e31361873","83d74c70e1b961f4"],"x":585,"y":780,"wires":[["844832e4da8d8d90"]]},{"id":"158fe09d9d3db270","type":"link out","z":"f1","name":"link out 111","mode":"link","links":["1da97d651a463ca3"],"x":895,"y":800,"wires":[]},{"id":"1da97d651a463ca3","type":"link in","z":"f1","name":"link in 64","links":["158fe09d9d3db270"],"x":485,"y":920,"wires":[["5e3818ecb5f273d3"]]},{"id":"c4bfcd2028bb114f","type":"link in","z":"f1","name":"link in 65","links":["718556041f992de0","52da96df4ea94f83"],"x":1025,"y":780,"wires":[["e5d04d31aa1602e8"]]},{"id":"52da96df4ea94f83","type":"link out","z":"f1","name":"link out 113","mode":"link","links":["c4bfcd2028bb114f"],"x":895,"y":760,"wires":[]},{"id":"7001db3fc031d641","type":"link out","z":"f1","name":"link out 114","mode":"link","links":["b4e686921ada51f9"],"x":1195,"y":760,"wires":[]},{"id":"b4e686921ada51f9","type":"link in","z":"f1","name":"link in 66","links":["7001db3fc031d641"],"x":1245,"y":740,"wires":[["02f7c808f5a8e276"]]},{"id":"74e2b81cc6ad7612","type":"link out","z":"f1","name":"link out 115","mode":"link","links":["be0955d080906cf4"],"x":1195,"y":800,"wires":[]},{"id":"be0955d080906cf4","type":"link in","z":"f1","name":"link in 67","links":["74e2b81cc6ad7612"],"x":1245,"y":820,"wires":[["57be4a7aee6abfb6"]]},{"id":"83d74c70e1b961f4","type":"link out","z":"f1","name":"link out 116","mode":"link","links":["e9dbcaf3ece8b29f"],"x":495,"y":780,"wires":[]},{"id":"be97b35209b5413a","type":"ha-entity-config","server":"dfd9f15b.de1b1","deviceConfig":"ef3c327f3868d287","name":"Energenie PMS2 LAN Socket 1","version":"6","entityType":"switch","haConfig":[{"property":"name","value":"Energenie PMS2 LAN Socket 1"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":"outlet"}],"resend":false,"debugEnabled":false},{"id":"83a6eda8aa9174c5","type":"ha-entity-config","server":"dfd9f15b.de1b1","deviceConfig":"ef3c327f3868d287","name":"Energenie PMS2 LAN Socket 2","version":"6","entityType":"switch","haConfig":[{"property":"name","value":"Energenie PMS2 LAN Socket 2"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":"outlet"}],"resend":false,"debugEnabled":false},{"id":"8c36f378721f4365","type":"ha-entity-config","server":"dfd9f15b.de1b1","deviceConfig":"ef3c327f3868d287","name":"Energenie PMS2 LAN Socket 3","version":"6","entityType":"switch","haConfig":[{"property":"name","value":"Energenie PMS2 LAN Socket 3"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":"outlet"}],"resend":false,"debugEnabled":false},{"id":"086a81c8c6ddc220","type":"ha-entity-config","server":"dfd9f15b.de1b1","deviceConfig":"ef3c327f3868d287","name":"Energenie PMS2 LAN Socket 4","version":"6","entityType":"switch","haConfig":[{"property":"name","value":"Energenie PMS2 LAN Socket 4"},{"property":"icon","value":""},{"property":"entity_picture","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":"outlet"}],"resend":false,"debugEnabled":false},{"id":"dfd9f15b.de1b1","type":"server","name":"Local","version":5,"addon":false,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":false,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true},{"id":"ef3c327f3868d287","type":"ha-device-config","name":"Energenie PMS2 LAN","hwVersion":"","manufacturer":"Energenie","model":"PMS2 LAN","swVersion":""}]
Thanks for sharing this node-red Flow. I tried out, but it doesn’t work. I set the correct IP-Address in the every http request nodes. The password I have to set in the set login data node?
Is the password under function this:
msg.headers = {
msg.payload = 'PASSWORD';
return msg;
Thanks for help
