Now I am thinking I’ve got the sensor name wrong though, because I have 3 different energy meter plugs, and they’re all saying the same name. Any ideas?
Yes, sadly this is the case. Some devices work in the original tuya integration, but not in the new one and some devices work in the new tuya integration but not in the old. The number of devices that are supported in the new integration are increasing (whilst the old version was pretty stagnant), so there is hope.
Ah. No. As described earlier in this thread:
“From the Lovelace gui interface, go into Configuration, then Integrations, find the Tuya2 integration then click on the “devices” hyperlink. Now find the Tuya device”
Click on the sensor and use that name to be the data source for the extra sensor you are creating for energy monitoring.
Ok i spend hours now trying to install tuya v2.
“Config flow could not be loaded” after install.
If i click on integrations after restarts it loads forever.
Tried to uninstall tuya from hacs and repeat process but no luck.
Ah. OK. Assuming you have the latest HA, TuyaV2 is installed normally ie not via HACS, and is just called Tuya. Just to clear up your install, I’d suggest removing the HACS version and any other Tuya install, restarting, then following the instructions (Tuya - Home Assistant) to add in the native Tuya integration.
Thank you for this Post zagnuts. I got my Arlec Grid Connect SMART plug collecting kwh.
I didn’t have any sensors in my configuration.yaml file so I added a line in the same file:
sensor: !include sensor.yaml
Then I created a file called sensor.yaml in the same folder and added:
- platform: integration
source: sensor.smart_plug_with_energy_meter_pc399ha_power
name: Kitchen Hot Water Energy
unit_prefix: k
round: 2
method: left
I did have issues when copying and pasting from your example, perhaps because of invisible formatting characters. Typing it out solved it for me.
For those new to this, you need to connect your smart plug using the app “Smart Life” and not Grid Connect and follow the TUYA integrations guide.
There was a comment above that the waterbed produced inaccurate readings. If you refer to Integration - Riemann sum integral - Home Assistant (home-assistant.io), this recommends changing the collection method for on/off heaters to left.
I am trying this out as my readings are not the same as the Smart Life reading.
No problem - glad it’s working for you as well! As for the copy and paste thing - there shouldn’t have been any hidden characters but it may very well have been a formatting issue. It’s so easy for a space or tab to creep into a yaml file and break it - which why I got into the habit of always testing my code after any change no matter how minor…
Assuming you are using the new Tuya integration then it will create ten switches and each switch will have separate sensors. To see them in the energy section have you created ten extra sensors as described above?
Oooh. Was in Bunnings yesterday and found this “Arlec Grid Connect Smart IP44 Heavy Duty Timer”. It is designed to plug into an external power point, and it does energy monitoring. Cost AUD$25. Bought one to play with, and:
Connected it to my wifi via the Smart Life app
Went to hassio, reloaded the Tuya integration, and the new device was there
Still in hassio, went into the integration and enabled the three additional sensors
Once the sensors were available, I then checked the name of the power sensor which in my case was “sensor.pc44ha_power” and of course reporting power usage in W.
Then edited my sensor.yaml file and added:
source: sensor.pc44ha_power
name: Pool Fridge Energy
unit_prefix: k
round: 2
After a little while, my new power monitor for the pool fridge was available to add into my energy monitoring. Yay!
