Energy dashboard not populating
Indeed, but how?
well, start by posting your configuration for that esp device
I have now added some code I found on github. this “skips” the first 20 readings after ESP boot. But I doubt this will work because the ESP is already running when the inverter is starting up in the morning.
the current code:
esphome:
  platform: ESP8266
  board: d1_mini
  on_boot:
    # set a default value for the skip counter, otherwise it's nan
    - sensor.template.publish:
        state: 0
substitutions:
  esp_name: Growattmodbus
  my_sensor: my_sensor
wifi:
  ssid: "SSID"
  password: !secret wifi_key
  use_address: 192.168.6.42
  domain: !secret domain
  ap:
    ssid: "${esp_name} fb Hotspot"
    password: !secret Fallback_Hotspot
captive_portal:
# Enable logging
logger:
#  level: VERBOSE
#  baud_rate: 0
# Enable Home Assistant API
api:
ota:
time:
  - platform: homeassistant
    on_time:
      # Every morning on weekdays reset ID todaygen
      - seconds: 0
        minutes: 0
        hours: 0
        #days_of_week: MON-SUN
        then:
          - lambda: id(todaygen).publish_state(0);
uart:
  - id: uart1
    baud_rate: 9600
    tx_pin: D1
    rx_pin: D2
#  stop_bits: 1
modbus:
  uart_id: uart1
web_server:
  port: 80
  - platform: wifi_signal
    name: "${esp_name} - ESP WiFi Signal"
    update_interval: 60s
  - platform: uptime
    name: "${esp_name} - ESP Uptime"
    icon: mdi:clock-outline
  - platform: growatt_solar
    update_interval: 3s
    protocol_version: RTU2
    inverter_status:
      name: "${esp_name} - Status Code"
    phase_a:
      voltage:
          name: "${esp_name} - AC Voltage"
      current:
          name: "${esp_name} - AC Current"
      active_power:
          name: "${esp_name} - AC Power"
          filters:
            - filter_out: NaN
    pv1:
      voltage:
          name: "${esp_name} - PV1 Voltage"
      current:
          name: "${esp_name} - PV1 Current"
      active_power:
          name: "${esp_name} - PV1 Power"
    pv2:
      voltage:
          name: "${esp_name} - PV2 Voltage"
      current:
          name: "${esp_name} - PV2 Current"
      active_power:
          name: "${esp_name} - PV2 Power"
    active_power:
      state_class: "measurement"
      name: "${esp_name} - Output Power"
      filters:
       - lambda: |-
           if (x <= 5500 && x >= 0) return x;
           else return 0;
       #- lambda: |-
       #    if (x <= 5500) return x;
       #    else return {};
    pv_active_power:
      name: "${esp_name} - Input Power"
    frequency:
      name: "${esp_name} - Grid Frequency"
    energy_production_day:
      name: "${esp_name} - Today Gen"
      filters:
      # increment a skip counter, this skips the first two measurements
      - lambda: auto s = id(${my_sensor}_skips); if(s->state > 20) { return x; } else { s->publish_state(s->state+1); return {}; }
      #filters:
      # - lambda: |-
      #     if (x >= 0) return x;
      #     else return 0;
         #lambda: |-
         #   if (id(inverter_status).state != 0) {
         #       return x;
         #   return {};
      #  - lambda: "if (x - id(todaygen).state) > 0.5) return {}; return x;"
      # https://github.com/esphome/feature-requests/issues/607
      #- lambda: auto s = id(${todaygen}_skips); if(s->state > 100) { return x; } else { s->publish_state(s->state+1); return {}; }
    total_energy_production:
      name: "${esp_name} - Total Gen"
      #state_class: "measurement"
      #device_class: energy
      accuracy_decimals: 1
    inverter_module_temp:
      name: "${esp_name} - Temperature"
  # create a skip counter
    internal: true
    accuracy_decimals: 0
This is the original “problematic” code:
esphome:
  platform: ESP8266
  board: d1_mini
substitutions:
wifi:
  ssid: "SSID"
  ap:
captive_portal:
# Enable logging
logger:
#  level: VERBOSE
#  baud_rate: 0
api:
ota:
time:
    on_time:
      - seconds: 0
        minutes: 0
        hours: 0
        then:
uart:
  - id: uart1
    baud_rate: 9600
    tx_pin: D1
    rx_pin: D2
#  stop_bits: 1
modbus:
  uart_id: uart1
web_server:
  port: 80
  - platform: uptime
    update_interval: 3s
    inverter_status:
    phase_a:
      voltage:
      current:
      active_power:
          filters:
            - filter_out: NaN
    pv1:
      voltage:
      current:
      active_power:
    pv2:
      voltage:
      current:
      active_power:
    active_power:
      filters:
       - lambda: |-
           else return 0;
       #- lambda: |-
       #    else return {};
    pv_active_power:
    frequency:
      filters:
       - lambda: |-
           else return 0;
         #lambda: |-
         #       return x;
         #   return {};
      #state_class: total
      #state_class: total_increasing # was empty
      # https://developers.home-assistant.io/docs/core/entity/sensor/#how-to-choose-state_class-and-last_reset
which sensor is outputting 0 or NaN on startup that’s causing the issues?
But its outputing:
You’re most likely running into a timing issue. The last calculation of the day is slightly past midnight by the time it reaches HA, so HA adds it to the next days values. Your only option is to control the timing of your data points, by forcing the values to specific intervals.
Or have HA calculate the energy from your power entities.
Ok, but how can I solve that? Get the first bugus readings out every day?
You can try adjusting your update interval to an odd value so that it doesn’t occur on the minute when crossing midnight.
Keep in mind, that you think your problem is getting 0 at midnight. Your actual problem is that you’re getting the previous day’s value at midnight. So sending an extra 0 or whatever at midnight isn’t going to solve the problem. And it doesn’t look like lambdas can get the time? Unless I’m wrong. If you can get the current time in your lambda, you can output zero if it’s >= midnight.
EDIT: You can get the time in lambdas. So all you need to do is filter out values between 23:59 and 00:01 and you’ll be good.
The problem is not at midnight, but is at the starting up of the inverter. So every morning on sunrise.
I need the value near-real-time due to some automations, so update interval of a minute is not feasible.
I need something to filter out the values every morning before the actual counting starts…
Then you need to get inventive and figure out what’s happening. If the ESP device is turning off, then don’t have the device turn off.
Your other option is to have HA do the calculations and you can use an automation to ignore data around sunrise.
Either way, the problem is in your device and you have to work around it. To me, it doesn’t make sense that your device would be outputting yesterdays values on startup at sunrise. This would be something should occur at midnight every day.
The ESP device is always on. It’s the inverter going on and off (on sunrise) and sending the day gen of the day before a few times before it completely starts.
At midnight the inverter is really off (dead).
The best solution would be to “filter” out the first readings every start of the day.
But how do I do that?
it’s not at the start of every day. It’s at sunrise when it turns on. You need to understand that those have different meanings.
I recommend using HA’s energy calculations instead of the devices as the devices is not correct.
The last resort is that you can wrap a template sensor around your data and filter out the results that way if you are within 10 minutes of sunrise when the device is going to turn on.
Either way, you can’t do it on the esp side as I don’t think you can get sunrise/sunset times. Then again, I’m not 100% versed in ESPHome syntax.
Semantics :slight_smile: but you’re right. It’s at the start of every dawn.
I prefer clean input in my sensors and prefer to use the value from the esp. Everything works fine with it (all my sensors are calculated correctly) but the energy dashboard.
I would really be happy with a filter that filters out every bogus reading every dawn…
well, a simple search on the forums found that yes, you can get sunrise in lambds
so you should be able to filter out startup values around sunrise.
would this component be an option to include in a lambda and if the sun if rised only send the readings?
(I don’t know how to lambda-code that)…
Sorry, I don’t know how to do
that in lambda
Sorry, I’ve never used lambdas, I don’t know the syntax and I’d have to learn it. It seems straight forward and looks like JS with a twist. If you know JS you should be able to pick it up quickly. Anyways, this seems like an adventure you’ll have to take. Might be an opportunity to create a new posts explicitly asking to filter out data at a specific time in the ESPHome section.
For the archive:
It’s basically C++
Which is foreign to me. I can usually muddle through simple things by adapting examples but this is beyond me.
Sender, how to filter 10 minutes either side of sunrise with a lambda would best be asked on the ESPHome discord. The ESPHome devs hang out there and are usually very helpful.
