I have been getting errors ever since I upgraded to 2021.10. I see several SQL errors in the log (below) and they keep appearing when the Energy Dashboard tries to get the latest info (so 12 minutes past the hour). This started hapening right after the latest upgrade so I am afraid something is wrong here.
I am using Mysql on my Drobo NAS to store the database and use following connection string (which all works great for the rest)
Anyone any idea what I could do here?
confguration.yaml
db_url: mysql://user:password@INTERNAL-IP/homeassistant?charset=utf8mb4
The log error:
Logger: homeassistant.components.recorder.util
Source: components/recorder/util.py:135
Integration: Recorder (documentation, issues)
First occurred: 11:00:10 AM (9 occurrences)
Last logged: 1:00:11 PM
Error executing query: (MySQLdb._exceptions.ProgrammingError) (1064, "You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '(PARTITION BY statistics_short_term.metadata_id ORDER BY statistics_short_term.s' at line 2") [SQL: SELECT anon_1.metadata_id AS anon_1_metadata_id, anon_1.start AS anon_1_start, anon_1.last_reset AS anon_1_last_reset, anon_1.state AS anon_1_state, anon_1.sum AS anon_1_sum, anon_1.rownum AS anon_1_rownum FROM (SELECT statistics_short_term.metadata_id AS metadata_id, statistics_short_term.start AS start, statistics_short_term.last_reset AS last_reset, statistics_short_term.state AS state, statistics_short_term.sum AS sum, row_number() OVER (PARTITION BY statistics_short_term.metadata_id ORDER BY statistics_short_term.start DESC) AS rownum FROM statistics_short_term WHERE statistics_short_term.start >= %s AND statistics_short_term.start < %s) AS anon_1 WHERE anon_1.rownum = %s ORDER BY anon_1.metadata_id] [parameters: (datetime.datetime(2021, 10, 7, 8, 0, tzinfo=datetime.timezone.utc), datetime.datetime(2021, 10, 7, 9, 0, tzinfo=datetime.timezone.utc), 1)] (Background on this error at: https://sqlalche.me/e/14/f405)
Error executing query: (MySQLdb._exceptions.ProgrammingError) (1064, "You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '(PARTITION BY statistics_short_term.metadata_id ORDER BY statistics_short_term.s' at line 2") [SQL: SELECT anon_1.metadata_id AS anon_1_metadata_id, anon_1.start AS anon_1_start, anon_1.last_reset AS anon_1_last_reset, anon_1.state AS anon_1_state, anon_1.sum AS anon_1_sum, anon_1.rownum AS anon_1_rownum FROM (SELECT statistics_short_term.metadata_id AS metadata_id, statistics_short_term.start AS start, statistics_short_term.last_reset AS last_reset, statistics_short_term.state AS state, statistics_short_term.sum AS sum, row_number() OVER (PARTITION BY statistics_short_term.metadata_id ORDER BY statistics_short_term.start DESC) AS rownum FROM statistics_short_term WHERE statistics_short_term.start >= %s AND statistics_short_term.start < %s) AS anon_1 WHERE anon_1.rownum = %s ORDER BY anon_1.metadata_id] [parameters: (datetime.datetime(2021, 10, 7, 9, 0, tzinfo=datetime.timezone.utc), datetime.datetime(2021, 10, 7, 10, 0, tzinfo=datetime.timezone.utc), 1)] (Background on this error at: https://sqlalche.me/e/14/f405)
Error executing query: (MySQLdb._exceptions.ProgrammingError) (1064, "You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '(PARTITION BY statistics_short_term.metadata_id ORDER BY statistics_short_term.s' at line 2") [SQL: SELECT anon_1.metadata_id AS anon_1_metadata_id, anon_1.start AS anon_1_start, anon_1.last_reset AS anon_1_last_reset, anon_1.state AS anon_1_state, anon_1.sum AS anon_1_sum, anon_1.rownum AS anon_1_rownum FROM (SELECT statistics_short_term.metadata_id AS metadata_id, statistics_short_term.start AS start, statistics_short_term.last_reset AS last_reset, statistics_short_term.state AS state, statistics_short_term.sum AS sum, row_number() OVER (PARTITION BY statistics_short_term.metadata_id ORDER BY statistics_short_term.start DESC) AS rownum FROM statistics_short_term WHERE statistics_short_term.start >= %s AND statistics_short_term.start < %s) AS anon_1 WHERE anon_1.rownum = %s ORDER BY anon_1.metadata_id] [parameters: (datetime.datetime(2021, 10, 7, 10, 0, tzinfo=datetime.timezone.utc), datetime.datetime(2021, 10, 7, 11, 0, tzinfo=datetime.timezone.utc), 1)] (Background on this error at: https://sqlalche.me/e/14/f405)
Source: components/recorder/util.py:72
First occurred: 11:00:10 AM (3 occurrences)
Source: components/recorder/util.py:116
Unhandled database error while processing event StatisticsTask(start=datetime.datetime(2021, 10, 7, 8, 55, tzinfo=datetime.timezone.utc)): (MySQLdb._exceptions.ProgrammingError) (1064, "You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '(PARTITION BY statistics_short_term.metadata_id ORDER BY statistics_short_term.s' at line 2") [SQL: SELECT anon_1.metadata_id AS anon_1_metadata_id, anon_1.start AS anon_1_start, anon_1.last_reset AS anon_1_last_reset, anon_1.state AS anon_1_state, anon_1.sum AS anon_1_sum, anon_1.rownum AS anon_1_rownum FROM (SELECT statistics_short_term.metadata_id AS metadata_id, statistics_short_term.start AS start, statistics_short_term.last_reset AS last_reset, statistics_short_term.state AS state, statistics_short_term.sum AS sum, row_number() OVER (PARTITION BY statistics_short_term.metadata_id ORDER BY statistics_short_term.start DESC) AS rownum FROM statistics_short_term WHERE statistics_short_term.start >= %s AND statistics_short_term.start < %s) AS anon_1 WHERE anon_1.rownum = %s ORDER BY anon_1.metadata_id] [parameters: (datetime.datetime(2021, 10, 7, 8, 0, tzinfo=datetime.timezone.utc), datetime.datetime(2021, 10, 7, 9, 0, tzinfo=datetime.timezone.utc), 1)] (Background on this error at: https://sqlalche.me/e/14/f405)
Unhandled database error while processing event StatisticsTask(start=datetime.datetime(2021, 10, 7, 9, 55, tzinfo=datetime.timezone.utc)): (MySQLdb._exceptions.ProgrammingError) (1064, "You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '(PARTITION BY statistics_short_term.metadata_id ORDER BY statistics_short_term.s' at line 2") [SQL: SELECT anon_1.metadata_id AS anon_1_metadata_id, anon_1.start AS anon_1_start, anon_1.last_reset AS anon_1_last_reset, anon_1.state AS anon_1_state, anon_1.sum AS anon_1_sum, anon_1.rownum AS anon_1_rownum FROM (SELECT statistics_short_term.metadata_id AS metadata_id, statistics_short_term.start AS start, statistics_short_term.last_reset AS last_reset, statistics_short_term.state AS state, statistics_short_term.sum AS sum, row_number() OVER (PARTITION BY statistics_short_term.metadata_id ORDER BY statistics_short_term.start DESC) AS rownum FROM statistics_short_term WHERE statistics_short_term.start >= %s AND statistics_short_term.start < %s) AS anon_1 WHERE anon_1.rownum = %s ORDER BY anon_1.metadata_id] [parameters: (datetime.datetime(2021, 10, 7, 9, 0, tzinfo=datetime.timezone.utc), datetime.datetime(2021, 10, 7, 10, 0, tzinfo=datetime.timezone.utc), 1)] (Background on this error at: https://sqlalche.me/e/14/f405)
Unhandled database error while processing event StatisticsTask(start=datetime.datetime(2021, 10, 7, 10, 55, tzinfo=datetime.timezone.utc)): (MySQLdb._exceptions.ProgrammingError) (1064, "You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '(PARTITION BY statistics_short_term.metadata_id ORDER BY statistics_short_term.s' at line 2") [SQL: SELECT anon_1.metadata_id AS anon_1_metadata_id, anon_1.start AS anon_1_start, anon_1.last_reset AS anon_1_last_reset, anon_1.state AS anon_1_state, anon_1.sum AS anon_1_sum, anon_1.rownum AS anon_1_rownum FROM (SELECT statistics_short_term.metadata_id AS metadata_id, statistics_short_term.start AS start, statistics_short_term.last_reset AS last_reset, statistics_short_term.state AS state, statistics_short_term.sum AS sum, row_number() OVER (PARTITION BY statistics_short_term.metadata_id ORDER BY statistics_short_term.start DESC) AS rownum FROM statistics_short_term WHERE statistics_short_term.start >= %s AND statistics_short_term.start < %s) AS anon_1 WHERE anon_1.rownum = %s ORDER BY anon_1.metadata_id] [parameters: (datetime.datetime(2021, 10, 7, 10, 0, tzinfo=datetime.timezone.utc), datetime.datetime(2021, 10, 7, 11, 0, tzinfo=datetime.timezone.utc), 1)] (Background on this error at: https://sqlalche.me/e/14/f405)
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1771, in _execute_context
self.dialect.do_execute(
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/default.py", line 717, in do_execute
cursor.execute(statement, parameters)
File "/usr/local/lib/python3.9/site-packages/MySQLdb/cursors.py", line 206, in execute
res = self._query(query)
File "/usr/local/lib/python3.9/site-packages/MySQLdb/cursors.py", line 319, in _query
db.query(q)
File "/usr/local/lib/python3.9/site-packages/MySQLdb/connections.py", line 259, in query
_mysql.connection.query(self, query)
MySQLdb._exceptions.ProgrammingError: (1064, "You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '(PARTITION BY statistics_short_term.metadata_id ORDER BY statistics_short_term.s' at line 2")
File "/usr/src/homeassistant/homeassistant/components/recorder/__init__.py", line 682, in _process_one_event_or_recover
self._process_one_event(event)
File "/usr/src/homeassistant/homeassistant/components/recorder/__init__.py", line 788, in _process_one_event
self._run_statistics(event.start)
File "/usr/src/homeassistant/homeassistant/components/recorder/__init__.py", line 771, in _run_statistics
if statistics.compile_statistics(self, start):
File "/usr/src/homeassistant/homeassistant/components/recorder/util.py", line 315, in wrapper
return job(instance, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/recorder/statistics.py", line 357, in compile_statistics
compile_hourly_statistics(instance, session, start)
File "/usr/src/homeassistant/homeassistant/components/recorder/statistics.py", line 288, in compile_hourly_statistics
stats = execute(query.params(start_time=start_time, end_time=end_time))
File "/usr/src/homeassistant/homeassistant/components/recorder/util.py", line 116, in execute
result = list(qry)
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/orm/query.py", line 2839, in __iter__
return self._iter().__iter__()
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/orm/query.py", line 2846, in _iter
result = self.session.execute(
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/orm/session.py", line 1689, in execute
result = conn._execute_20(statement, params or {}, execution_options)
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1583, in _execute_20
return meth(self, args_10style, kwargs_10style, execution_options)
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/sql/elements.py", line 323, in _execute_on_connection
return connection._execute_clauseelement(
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1452, in _execute_clauseelement
ret = self._execute_context(
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1814, in _execute_context
self._handle_dbapi_exception(
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1995, in _handle_dbapi_exception
util.raise_(
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/util/compat.py", line 207, in raise_
raise exception
db.query(q)
sqlalchemy.exc.ProgrammingError: (MySQLdb._exceptions.ProgrammingError) (1064, "You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '(PARTITION BY statistics_short_term.metadata_id ORDER BY statistics_short_term.s' at line 2")
