Energy dashboard stopped tracking energy but sensors are still reporting readings
I’ve had a few light switches tracking their energy use for a year or two without issue. About 3 weeks ago I added an Emporia Vue flashed with ESPHome to do whole-home energy monitoring along with several circuits. This worked great in the energy dashboard for a few days, but then all of my energy reports started showing 0, even the light switches that had been working for a long time.
The current state of my energy dashboard:
Here is my energy dashboard for last month when I had whole home energy tracking working briefly.
I haven’t seen anything in the logs that jumps out, but maybe I’m looking in the wrong spot or for the wrong thing.
I’m running Home Assistant OS. I was on a Raspberry Pi when the issue started, but I migrated to a Core i5 mini PC over the weekend.
 Home Assistant 2023.10.1
 Supervisor 2023.10.0
 Operating System 10.5
 Frontend 20231005.0 - latest
Any suggestions for fixing my energy dashboard?
I went to my history dashboard to prove to myself that I’m still collecting data reliably, but it seems I’m getting way fewer data points than I thought I was. So my issue is likely related to this. Any idea how to fix this?
Edit: I should have noted that I’ve been using MariaDB for at least 2 years.
I’m not seeing any errors in my MariaDB logs
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service mariadb-pre: starting
[09:06:42] INFO: Using existing mariadb
s6-rc: info: service mariadb-pre successfully started
s6-rc: info: service mariadb-core: starting
s6-rc: info: service mariadb-core successfully started
s6-rc: info: service mariadb-post: starting
[09:06:42] INFO: Starting MariaDB
2023-10-10  9:06:42 0 [Note] Starting MariaDB 10.6.12-MariaDB source revision 4c79e15cc3716f69c044d4287ad2160da8101cdc as process 66
2023-10-10  9:06:42 0 [Note] mysqld: Aria engine: starting recovery
tables to flush: 2 1 0
 (0.0 seconds);
2023-10-10  9:06:42 0 [Note] mysqld: Aria engine: recovery done
2023-10-10  9:06:42 0 [Note] InnoDB: Compressed tables use zlib 1.2.12
2023-10-10  9:06:42 0 [Note] InnoDB: Number of pools: 1
2023-10-10  9:06:42 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
2023-10-10  9:06:42 0 [Note] mysqld: O_TMPFILE is not supported on /var/tmp (disabling future attempts)
2023-10-10  9:06:42 0 [Note] InnoDB: Using Linux native AIO
2023-10-10  9:06:42 0 [Note] InnoDB: Initializing buffer pool, total size = 134217728, chunk size = 134217728
2023-10-10  9:06:42 0 [Note] InnoDB: Completed initialization of buffer pool
2023-10-10  9:06:42 0 [Note] InnoDB: Starting crash recovery from checkpoint LSN=621618896939,621621884509
2023-10-10  9:06:42 0 [Note] InnoDB: Starting final batch to recover 3426 pages from redo log.
2023-10-10  9:06:43 0 [Note] InnoDB: 128 rollback segments are active.
2023-10-10  9:06:43 0 [Note] InnoDB: Removed temporary tablespace data file: "./ibtmp1"
2023-10-10  9:06:43 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2023-10-10  9:06:43 0 [Note] InnoDB: Setting file './ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2023-10-10  9:06:43 0 [Note] InnoDB: File './ibtmp1' size is now 12 MB.
2023-10-10  9:06:43 0 [Note] InnoDB: 10.6.12 started; log sequence number 621623347956; transaction id 22675730
2023-10-10  9:06:43 0 [Note] InnoDB: Loading buffer pool(s) from /data/databases/ib_buffer_pool
2023-10-10  9:06:43 0 [Note] Plugin 'FEEDBACK' is disabled.
2023-10-10  9:06:43 0 [Note] Server socket created on IP: '0.0.0.0'.
2023-10-10  9:06:43 0 [Note] Server socket created on IP: '::'.
2023-10-10  9:06:43 0 [Note] InnoDB: Buffer pool(s) load completed at 231010  9:06:43
2023-10-10  9:06:43 0 [Note] mysqld: ready for connections.
Version: '10.6.12-MariaDB'  socket: '/run/mysqld/mysqld.sock'  port: 3306  MariaDB Server
[09:06:43] INFO: MariaDB started
[09:06:43] INFO: Check data integrity and fix corruptions
mysql.column_stats                                 OK
mysql.columns_priv                                 OK
mysql.db                                           OK
mysql.event                                        OK
mysql.func                                         OK
mysql.global_priv                                  OK
mysql.gtid_slave_pos                               OK
mysql.help_category                                OK
mysql.help_keyword                                 OK
mysql.help_relation                                OK
mysql.help_topic                                   OK
mysql.index_stats                                  OK
mysql.innodb_index_stats                           OK
mysql.innodb_table_stats                           OK
mysql.plugin                                       OK
mysql.proc                                         OK
mysql.procs_priv                                   OK
mysql.proxies_priv                                 OK
mysql.roles_mapping                                OK
mysql.servers                                      OK
mysql.table_stats                                  OK
mysql.tables_priv                                  OK
mysql.time_zone                                    OK
mysql.time_zone_leap_second                        OK
mysql.time_zone_name                               OK
mysql.time_zone_transition                         OK
mysql.time_zone_transition_type                    OK
mysql.transaction_registry                         OK
homeassistant.event_data                           OK
homeassistant.event_types                          OK
homeassistant.events                               OK
homeassistant.recorder_runs                        OK
homeassistant.schema_changes                       OK
homeassistant.state_attributes                     OK
homeassistant.states                               OK
homeassistant.states_meta                          OK
homeassistant.statistics                           OK
homeassistant.statistics_meta                      OK
homeassistant.statistics_runs                      OK
homeassistant.statistics_short_term                OK
sys.sys_config                                     OK
[09:06:43] INFO: Ensuring internal database upgrades are performed
[09:06:43] INFO: Ensure databases exists
[09:06:44] INFO: Create database homeassistant
[09:06:44] INFO: Ensure users exists and are updated
[09:06:44] INFO: Update user homeassistant
[09:06:44] INFO: Init/Update rights
[09:06:44] INFO: Granting all privileges to homeassistant on homeassistant
[09:06:44] INFO: Sending service information to Home Assistant
s6-rc: info: service mariadb-post successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
I’ve checked the history from zigbee, z-wave, and esphome entities and they are all affected.
Well, I’m not really sure what is going on, but I am now seeing granular history from about 9 am (prior to me posting my issue) and there is data in my energy dashboard again. The new server has only been online since some time overnight when it finished importing its backup, so maybe something about the new install fixed it and it just needed some time to shake things loose? I’ll consider it fixed for now. If it comes back, I’ll post here again.
