Energy - How to account for daily standing charge?
Thanks bo. Yes I did set that correctly I set it to 330 as my daily supply charge is £0.33
However this morning it has started working, so I think it just needs a little while to kick in. And perhaps I was fiddling around with too many settings trying to get it to work.
Great solution thanks!
Good solution. I went with your method and it is working fine for me. Thank you for sharing it
the energy solutions seem half baked. Though i got the daily standing charge to work as posted before, my actual per kWh Cost for my real energy entity does not work for days and suddenly yesterday it calculated finally the costs for 1 single day. (i opened a thread for this)
I am a bit flabbergastered as this was implemented well over a year now. Also there is too less data for me to debug it myself, so i kinda have to wait and see where it gets us…
I will probably try to get my data into influx and use grafana for the time being.
Hello, thx for this.
I’m very new to HA, and I get most of it, but the scripting part …arghh.
Well, I really don’t understand how this line can generate 1W per day as the calculation will change every day, since the now() will be different …
Could you please explain the logic behind it ?
sorry for such a newbee question, but I’ve spent 2h hours on this ^^
On my side I would like to do just like this but only once per month on the 9th.
so I was thinking to add
  - plateform: time
    at: :01:00:00"
  # Increases every month by 1W to fake a monthly supply charge in energy dashboard.
  - state: >-
      {% if now().day == 9 %}
        0.001
      {% else %}
        0
      {%endif%}
    unit_of_measurement: kWh
    state_class: total_increasing
    device_class: energy
    unique_id: CHANGE_ME_TO_ANYTHING_JUST_MAKE_IT_UNIQUE
    name: "Monthly supply charge"
would this work ?
thx a lot
Okay, so as I could not get this to work, here is what I did
  • Create an input_number
  • Create an automation :
    • to set the input number to 0.001
    • at 01:00:00
    • when the day is equal to 9 (my bill start on the 9th)
  • Set a template sensor to use the input_number as m3 (as my energy dashboard started in m3 I don’t want to loose the data to switch to kWh)
  • Add the sensor to the energy dashboard with my monthly fixed charges
One question remain :
when do i need to set the input number back to 0 in order to charge only 1 time ?
I mean how long does it take for the dashboard to record this and apply the charge in € ?
Thx a lot for your help
    sensors:
      energy_import_cost:
        friendly_name: 'Import Cost'
        icon_template: mdi:home-import-outline
        unit_of_measurement: '$'
        value_template: "{{ (states('sensor.grid_consumed_energy_day') | float * 0.262026 + 0.9393) | round(2) }}"
did you add this as a utillity meter?
I’m not sure how to use your solution, can you provide more infomation please.
many thanks, this worked as descibed and insurctions were easy to follow.
a side note: did you get this alternate method to work:
With total_increasing , I think it could even work to just have a sensor which toggled between 0 and 1 every 12 hours as the 0 will be interpreted as a start of new cycle, but I haven’t tested that.
I still haven’t tested it tbh!
I’ve Been follow this thread and use method here for while, I updating various things and came across counter helper. not sure when it got added to HA but it is useful in this case. Add a counter eg counter.daily_counter
Create an automation to increase counter daily something like this
alias: Energy quaterly counter
    - platform: time
      at: '00:00'
    - service: counter.increment
        entity_id: counter.daily_counter
Also create an automation to reset counter every bill cycle
so everday the counter go up by one
Then create a sensor for (counter) x (daily supply charge)
      supply_cost:
        value_template: "{{ (states('counter.daily_counter) | float * states('sensor.price_daily_supply') | float) | round(2) }}"
here all services for counter
Thanks for this. Only change I made was make it explicitly 1 (instead of 0.001) and change units to 1 Wh… I was more so curious would HA handle Wh usage with a kWh price… Which worked fine.
I stuck with a kWh price as my standing Charge is 0.9976 euro per day… Which gets rounded on the energy dashboard anyway…
See: Energy: Add fixed daily cost - #56 by jbhobson
I stumbled across this solution GitHub - Rumbaar/Electricity-Daily-Charge-HA: Calculation of a static daily rate charge over 24 hours, inline with the hourly metric of the energy dashboard in Home Assistant.
I like the way a) the standing charge can be pulled from the supplier and therefore no need to manually set a fixed price in the energy monitor settings b) the standing charge accumulates on the energy graph during the day to the full price by the end of the day.
