Yes, I use Envoy and participated in the beta. You need to create some additional sensors for ‘real time’ consumption and export.
solar_export_value:
friendly_name: Solar Export Value
icon_template: mdi:solar-panel
unit_of_measurement: "W"
device_class: power
value_template: >
{% set value = (('%0.1f' | format(states('sensor.envoy_current_energy_production') | float - states('sensor.envoy_current_energy_consumption') | float)) | float) %}
{% if value <= 0 -%}
0
{%- else -%}
{{ value | round(2) }}
{%- endif %}
house_consumption_value:
friendly_name: House Importing Value
icon_template: mdi:transmission-tower
device_class: power
value_template: >
{% set value = (('%0.1f' | format(states('sensor.envoy_current_energy_consumption') | float - states('sensor.envoy_current_energy_production') | float)) | float) %}
0
{%- else -%}
{%- endif %}
You then create two additional sensors using the Reimann Sum integration and point them to the sensors created above
- platform: integration
source: sensor.house_consumption_value
unit_prefix: k
round: 2
method: left
source: sensor.solar_export_value
unit_prefix: k
round: 2
method: left
During the beta, one of these sensors had all the required values, but one didn’t. So I had to customise to add the device_class: energy, state_class: measurement and last_reset value.
Then set the imported energy sensor to be the ‘Grid Consumption’, exported exergy sensor as ‘Return to Grid’
edit: Added method: left to the integration sensors, since generation/consumption is considered spiky.
