An easy way to add feed in Energy Dashboard:
Go to Configuration > Entity: Select wich entity you want to add in Energy Dashboard
Customize the entity with:
state_class : measurement
device_class : energy
Other :
Attribute name = last_reset
Attribute Value = 1970-01-01T00:00:00+00:00
Check that the entity “Unit of measurement” is kWh.
Save
Return to Configuration> Energy and now you should find your feed in the list.
It’s same as append that in customize.yaml:
Example :
sensor.emoncms_energie_injectee:
friendly_name: Energie Injectée
state_class: measurement
device_class: energy
icon: mdi:home-export-outline
unit_of_measurement: kWh
last_reset: '1970-01-01T00:00:00+00:00'
