Energy States in Backup
Request Energy States from the past in the Backup.
They are stored in your recorder. Which is backed up if you do a full backup.
I have successfully installed a backup but no energy states from the past will showing up. Maybe a Bug?
Did you lose all your history data, not just energy data?
for me also does not backup db (docker container here) db is backup as a file but is 0 bytes
Yes. all my history states are lost…
The the issue isn’t that energy stats aren’t in your backup. It’s that either the recorder database was not in your backup or the database became corrupt when backing up. That last one is a common problem. If you search the forum you will find topics on repairing the database with SQL commands, like this:
or this:
