i got this: https://snipboard.io/3eEOGS.jpg
you copy/pasted it wrong and the fields aren’t correctly lining up. Take a look at the copied code again and ensure all spacing is maintained.
I was very carefull now to correct it but stil got the same problem: https://snipboard.io/UKjyL6.jpg
when i try to type it in manually i even got the same problem when i select the sensor-template
can’t see the rest of the file for the spacing on the other items.
that code goes in the sensor section and the spacing needs to line up with previous spacing in the sensor sections.
it works thx
still cant add it to the energy dashboard tho but will look futher for that
To add it to the energy dashboard, I made a utility meter out of the filtered sensor:
daily_solar:
source: sensor.saj_total_yield_filtered
name: Daily Solar Yield
cycle: daily
monthly_solar:
name: Monthly Solar Yield
cycle: monthly
