Thanks, no hurry
That error is strange atleast for /usr/src/homeassistant/homeassistant/setup.py
I dont have it anywhere.
I run home assistant in docker over debian buster.
hi guys,
I’ve got the same issue after updatig HA to 0.117.x version
I am not getting any warning, my config check pass every time but notify service disappeared - so cannot use notifications anymore
I am also running HA on docker
appreciate your help
thanks
Leoshek
Confirmed also on my setup.
Although I am not using hte notify component.
As said, I will have a look on the notify component to see what is missing.
great, many thanks
BTW for the others who might get notification problems:
I discovered MQTT broker/client plugin for Enigma2 - it has interesting features and one of them is sending a message, although it is not as nice as notify component
therefore I looking forward to get that working again
Have you noticed with which HA release the notification service stopped working ?
I do belive it was when I upgraded from latest 0.116 to first 0.117
Ok Thanks.
This is really strange, the services are created, but not available
2020-11-15 10:29:30 INFO (MainThread) [homeassistant.components.notify] Setting up notify.enigma
I see a traceback, probably related
2020-11-15 10:29:31 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/components/notify/__init__.py", line 292, in async_setup_platform
await notify_service.async_setup(hass, service_name, target_service_name_prefix)
AttributeError: 'coroutine' object has no attribute 'async_setup'
Found the problem,
Version 0.117 as an update notify to use async_add_executor_job.
This is causing problems with aiohttp
Thanks you everyone for the feedback.
Version 1.3 released.
Notification are now working with HA 0.117 release.
Please, go ahead, try it and give feedback.
works like a charm now
many thanks
Leoshek
It works very well. Thank you
I removed whole enigma folder and file. but I still got errors:
Logger: homeassistant.components.notify
Source: components/notify/__init__.py:255
Integration: Notifications (documentation, issues)
First occurred: 1:43:12 PM (1 occurrences)
Last logged: 1:43:12 PM
Unknown notification service specified
Logger: homeassistant.setup
Source: custom_components/enigma/init.py:95
Error during setup of component enigma
File “/usr/src/homeassistant/homeassistant/setup.py”, line 213, in _async_setup_component
result = await task
File “/config/custom_components/enigma/init.py”, line 95, in async_setup
configured_devices = config[DOMAIN].get(CONF_DEVICES)
KeyError: ‘enigma’
Hi
Show me the contents of the directory custom_components/enigma.
Also, share your configuration file for the enigmas devices only
here you go:
total 40
-rw-r--r-- 1 root root 5550 Nov 15 14:19 __init__.py
-rw-r--r-- 1 root root 16768 Nov 15 14:19 media_player.py
-rw-r--r-- 1 root root 4667 Nov 15 14:19 notify.py
drwxr-xr-x 2 root root 4096 Nov 16 13:37 __pycache__
configuration.yaml:
media_player:
- platform: enigma2
host: 192.168.1.20
username: !secret vuplus_user
password: !secret vuplus_pass
notify:
- platform: enigma
host: 192.168.1.20
port: 80
Hi @pumo
The notify is correct, but the media_player is not
The media_player needs to be configured as this
enigma:
devices:
- host: 192.168.1.20
port: 80
timeout: 20
picon: screenshot
Many thanks! and stupid me, I had two different enigma settings and I removed right one.
now it works
I am new here. I am trying to make this integration working but I can’t find the proper path to add enigma files from github. Should I create a folder? I have /home/matt bu there is only a file .profile - should I create a folder /home/matt/.homeassistant/custom_components and copy there the content of enigma folder from github?
\\ip_hassio\config\custom_components\enigma
I am doing something wrong. This is what I get:
18:06:55 – loader.py (ERROR)
Error setting up integration notify - received exception
Invalid config for [media_player]: required key not provided @ data['platform']. Got None. (See /config/configuration.yaml, line 14). Please check the docs at https://www.home-assistant.io/integrations/media_player
18:06:43 – config.py (ERROR)
My /config/configuration.yaml file is:
media_player:
enigma:
devices:
- host: 10.10.10.6
port: 80
timeout: 20
username: root
password: password
picon: picon
notify:
- platform: enigma
host: 10.10.10.6
port: 80
username: root
password: password
Try like this
enigma:
devices:
- host: 10.10.10.6
port: 80
timeout: 20
username: root
password: password
picon: picon
notify:
- platform: enigma
host: 10.10.10.6
port: 80
username: root
password: password
