Enigma2 receivers integration
What’s on the file /config/custom_components/enigma.py?
It seems the file has HTML content.
Did you copy the right files from github?
Yes, everything like the tutorial on git.
If you’re copy/pasting, do it from the raw view of the file
https://raw.githubusercontent.com/cinzas/homeassistant-enigma-player/master/enigma.py
Hi, thanks for raw link.
Now I havent errors when verify the configuration, but the player doestn appears into home app…
Its strange beacuse i havent this problems with apple tv and plex media player.
So, you should download all the files and place it in the right place.
Download the 3 raw files, not the HTML version :slight_smile:
You should now have the following structure
custom_components/media_player/enigma.py
custom_components/notify/enigma.py
If yes, restart HA and share your logfile (upload it to http://pastebin.com)
Yes, I’ve the structure like you say.
Here is the log:
  1. 2018-11-29 12:51:13 INFO (MainThread) [homeassistant.components.http.view] Serving /states to 192.168.1.214 (auth: False)
  2. 2018-11-29 12:51:13 INFO (MainThread) [homeassistant.components.http.view] Serving /api/websocket to 192.168.1.214 (auth: False)
  3. 2018-11-29 12:51:14 INFO (MainThread) [homeassistant.components.http.view] Serving /auth/token to 192.168.1.214 (auth: False)
  4. 2018-11-29 12:51:15 INFO (MainThread) [homeassistant.components.http.view] Serving /api/websocket to 192.168.1.214 (auth: False)
  5. 2018-11-29 12:51:24 INFO (MainThread) [homeassistant.components.http.view] Serving /api/config/core/check_config to 192.168.1.214 (auth: True)
  6. 2018-11-29 12:51:24 ERROR (SyncWorker_6) [homeassistant.util.yaml] YAML file /config/automations.yaml contains duplicate key “service”. Check lines 17 and 19.
  7. 2018-11-29 12:51:25 ERROR (SyncWorker_6) [homeassistant.util.yaml] YAML file /config/automations.yaml contains duplicate key “entity_id”. Check lines 18 and 20.
  8. 2018-11-29 12:51:25 ERROR (SyncWorker_6) [homeassistant.util.yaml] YAML file /config/automations.yaml contains duplicate key “service”. Check lines 19 and 21.
  9. 2018-11-29 12:51:25 ERROR (SyncWorker_6) [homeassistant.util.yaml] YAML file /config/automations.yaml contains duplicate key “entity_id”. Check lines 20 and 22.
  10. 2018-11-29 12:51:26 ERROR (SyncWorker_17) [homeassistant.util.yaml] YAML file /config/automations.yaml contains duplicate key “service”. Check lines 17 and 19.
  11. 2018-11-29 12:51:26 ERROR (SyncWorker_17) [homeassistant.util.yaml] YAML file /config/automations.yaml contains duplicate key “entity_id”. Check lines 18 and 20.
  12. 2018-11-29 12:51:26 ERROR (SyncWorker_17) [homeassistant.util.yaml] YAML file /config/automations.yaml contains duplicate key “service”. Check lines 19 and 21.
  13. 2018-11-29 12:51:26 ERROR (SyncWorker_17) [homeassistant.util.yaml] YAML file /config/automations.yaml contains duplicate key “entity_id”. Check lines 20 and 22.
  14. 2018-11-29 12:51:26 INFO (MainThread) [homeassistant.components.websocket_api.http.connection.140426238678296] Connection closed by client
  15. 2018-11-29 12:51:26 INFO (MainThread) [homeassistant.components.websocket_api.http.connection.140426237641896] Connection closed by client
  16. 2018-11-29 12:51:26 INFO (SyncWorker_1) [pyhap.accessory_driver] Stopping accessory Home Assistant Bridge on address 192.168.1.50, port 51827.
  17. 2018-11-29 12:51:27 INFO (SyncWorker_1) [pyhap.hap_server] Stopping HAP server
  18. 2018-11-29 12:51:27 INFO (SyncWorker_5) [pyhap.accessory_driver] Closed the event loop
  19. Home Assistant attempting to restart.
  20. Restarting Home Assistant
  21. Config directory: /config
  22. 2018-11-29 12:51:28 ERROR (SyncWorker_0) [homeassistant.util.yaml] YAML file /config/automations.yaml contains duplicate key “service”. Check lines 17 and 19.
  23. 2018-11-29 12:51:28 ERROR (SyncWorker_0) [homeassistant.util.yaml] YAML file /config/automations.yaml contains duplicate key “entity_id”. Check lines 18 and 20.
  24. 2018-11-29 12:51:28 ERROR (SyncWorker_0) [homeassistant.util.yaml] YAML file /config/automations.yaml contains duplicate key “service”. Check lines 19 and 21.
  25. 2018-11-29 12:51:28 ERROR (SyncWorker_0) [homeassistant.util.yaml] YAML file /config/automations.yaml contains duplicate key “entity_id”. Check lines 20 and 22.
  26. 2018-11-29 12:51:28 INFO (MainThread) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api
  27. 2018-11-29 12:51:28 INFO (MainThread) [homeassistant.bootstrap] Home Assistant core initialized
  28. 2018-11-29 12:51:28 INFO (MainThread) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend
  29. 2018-11-29 12:51:28 INFO (MainThread) [homeassistant.loader] Loaded api from homeassistant.components.api
  30. 2018-11-29 12:51:28 INFO (MainThread) [homeassistant.loader] Loaded http from homeassistant.components.http
  31. 2018-11-29 12:51:28 INFO (MainThread) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log
  32. 2018-11-29 12:51:28 INFO (MainThread) [homeassistant.loader] Loaded auth from homeassistant.components.auth
  33. 2018-11-29 12:51:28 INFO (MainThread) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding
  34. 2018-11-29 12:51:28 INFO (MainThread) [homeassistant.loader] Loaded lovelace from homeassistant.components.lovelace
  35. 2018-11-29 12:51:28 INFO (MainThread) [homeassistant.loader] Loaded introduction from homeassistant.components.introduction
  36. 2018-11-29 12:51:28 INFO (MainThread) [homeassistant.setup] Setting up introduction
  37. 2018-11-29 12:51:28 INFO (MainThread) [homeassistant.components.introduction]
  • Hello, and welcome to Home Assistant!
  • We’ll hope that we can make all your dreams come true.
  • Here are some resources to get started:
    • Configuring Home Assistant:
  1. https://home-assistant.io/getting-started/configuration/
    • Available components:
  1. https://home-assistant.io/components/
    • Troubleshooting your configuration:
  1. https://home-assistant.io/getting-started/troubleshooting-configuration/
    • Getting help:
  1. https://home-assistant.io/help/
  • This message is generated by the introduction component. You can
  1. disable it in configuration.yaml.
  • 2018-11-29 12:51:28 INFO (MainThread) [homeassistant.loader] Loaded persistent_notification from homeassistant.components.persistent_notification
  1. 2018-11-29 12:51:28 INFO (MainThread) [homeassistant.setup] Setup of domain introduction took 0.0 seconds.
  2. 2018-11-29 12:51:28 INFO (MainThread) [homeassistant.loader] Loaded history from homeassistant.components.history
  3. 2018-11-29 12:51:28 INFO (MainThread) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder
  4. 2018-11-29 12:51:28 INFO (MainThread) [homeassistant.setup] Setting up lovelace
  5. 2018-11-29 12:51:28 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 0.0 seconds.
  6. 2018-11-29 12:51:28 INFO (MainThread) [homeassistant.setup] Setting up http
  7. 2018-11-29 12:51:28 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
  8. 2018-11-29 12:51:28 INFO (MainThread) [homeassistant.setup] Setting up recorder
  9. 2018-11-29 12:51:28 INFO (MainThread) [homeassistant.setup] Setting up api
  10. 2018-11-29 12:51:28 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
  11. 2018-11-29 12:51:28 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.
  12. 2018-11-29 12:51:28 INFO (MainThread) [homeassistant.setup] Setting up system_log
  13. 2018-11-29 12:51:28 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds.
  14. 2018-11-29 12:51:28 INFO (MainThread) [homeassistant.setup] Setting up auth
  15. 2018-11-29 12:51:28 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds.
  16. 2018-11-29 12:51:28 INFO (MainThread) [homeassistant.setup] Setting up onboarding
  17. 2018-11-29 12:51:28 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.0 seconds.
  18. 2018-11-29 12:51:28 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 0.0 seconds.
  19. 2018-11-29 12:51:28 INFO (MainThread) [homeassistant.setup] Setting up frontend
  20. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.3 seconds.
  21. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 0.4 seconds.
  22. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setting up history
  23. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds.
  24. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded apple_tv from homeassistant.components.apple_tv
  25. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setting up apple_tv
  26. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded binary_sensor from homeassistant.components.binary_sensor
  27. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded binary_sensor.ping from homeassistant.components.binary_sensor.ping
  28. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setting up binary_sensor
  29. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded discovery from homeassistant.components.discovery
  30. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setting up discovery
  31. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setup of domain discovery took 0.0 seconds.
  32. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded switch from homeassistant.components.switch
  33. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded group from homeassistant.components.group
  34. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded switch.command_line from homeassistant.components.switch.command_line
  35. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded script from homeassistant.components.script
  36. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded conversation from homeassistant.components.conversation
  37. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded hue from homeassistant.components.hue
  38. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setting up hue
  39. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setup of domain hue took 0.0 seconds.
  40. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded config from homeassistant.components.config
  41. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded automation from homeassistant.components.automation
  42. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded updater from homeassistant.components.updater
  43. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setting up updater
  44. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook
  45. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded weather from homeassistant.components.weather
  46. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded weather.yweather from homeassistant.components.weather.yweather
  47. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setting up weather
  48. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded sensor from homeassistant.components.sensor
  49. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded sensor.yweather from homeassistant.components.sensor.yweather
  50. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded sensor.rest from homeassistant.components.sensor.rest
  51. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setting up sensor
  52. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded homekit from homeassistant.components.homekit
  53. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setting up homekit
  54. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setting up group
  55. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded tts from homeassistant.components.tts
  56. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded tts.google from homeassistant.components.tts.google
  57. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded media_player from homeassistant.components.media_player
  58. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded media_player.plex from homeassistant.components.media_player.plex
  59. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded media_player.enigma from custom_components.media_player.enigma
  60. 2018-11-29 12:51:29 WARNING (MainThread) [homeassistant.loader] You are using a custom component for media_player.enigma which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
  61. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded map from homeassistant.components.map
  62. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setting up map
  63. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.0 seconds.
  64. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded cloud from homeassistant.components.cloud
  65. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.ping
  66. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.ping
  67. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.ping
  68. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.components.weather] Setting up weather.yweather
  69. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.rest
  70. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.rest
  71. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.rest
  72. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.yweather
  73. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.rest
  74. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.rest
  75. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.rest
  76. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.rest
  77. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.rest
  78. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.1 seconds.
  79. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded remote from homeassistant.components.remote
  80. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setup of domain apple_tv took 0.2 seconds.
  81. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setting up conversation
  82. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setup of domain conversation took 0.0 seconds.
  83. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setting up config
  84. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setting up logbook
  85. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.0 seconds.
  86. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setting up tts
  87. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setting up media_player
  88. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setting up cloud
  89. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 0.0 seconds.
  90. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded config.hassbian from homeassistant.components.config.hassbian
  91. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded config.automation from homeassistant.components.config.automation
  92. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded config.core from homeassistant.components.config.core
  93. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded config.script from homeassistant.components.config.script
  94. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded config.customize from homeassistant.components.config.customize
  95. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded config.auth from homeassistant.components.config.auth
  96. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded config.config_entries from homeassistant.components.config.config_entries
  97. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded config.device_registry from homeassistant.components.config.device_registry
  98. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded config.auth_provider_homeassistant from homeassistant.components.config.auth_provider_homeassistant
  99. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded config.entity_registry from homeassistant.components.config.entity_registry
  100. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded config.group from homeassistant.components.config.group
  101. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.enigma
  102. 2018-11-29 12:51:29 ERROR (MainThread) [homeassistant.components.media_player] Error while setting up platform enigma
  103. Traceback (most recent call last):
  104. File “/usr/src/app/homeassistant/helpers/entity_platform.py”, line 124, in _async_setup_platform
  105. task = async_create_setup_task()
  106. File “/usr/src/app/homeassistant/helpers/entity_platform.py”, line 89, in async_create_setup_task
  107. None, platform.setup_platform, hass, platform_config,
  108. AttributeError: module ‘custom_components.media_player.enigma’ has no attribute ‘setup_platform’
  109. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.plex
  110. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setup of domain config took 0.1 seconds.
  111. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 0.1 seconds.
  112. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setup of domain group took 0.2 seconds.
  113. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setting up switch
  114. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setting up script
  115. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.0 seconds.
  116. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setting up automation
  117. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setting up remote
  118. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setup of domain remote took 0.0 seconds.
  119. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.components.switch] Setting up switch.command_line
  120. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded remote.apple_tv from homeassistant.components.remote.apple_tv
  121. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.components.remote] Setting up remote.apple_tv
  122. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setup of domain switch took 0.0 seconds.
  123. 2018-11-29 12:51:29 INFO (SyncWorker_16) [homeassistant.components.media_player.plex] Discovery configuration done (no token needed)
  124. 2018-11-29 12:51:29 INFO (SyncWorker_16) [homeassistant.components.media_player.plex] Connected to: http://192.168.1.50:32400
  125. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded light from homeassistant.components.light
  126. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setting up light
  127. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setup of domain light took 0.0 seconds.
  128. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded light.hue from homeassistant.components.light.hue
  129. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.components.light] Setting up light.hue
  130. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setup of domain media_player took 0.2 seconds.
  131. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.loader] Loaded media_player.apple_tv from homeassistant.components.media_player.apple_tv
  132. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.apple_tv
  133. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.1 seconds.
  134. 2018-11-29 12:51:29 INFO (MainThread) [homeassistant.setup] Setup of domain homekit took 0.3 seconds.
  135. 2018-11-29 12:51:30 INFO (MainThread) [homeassistant.setup] Setup of domain weather took 1.4 seconds.
  136. 2018-11-29 12:51:30 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 1.4 seconds.
  137. 2018-11-29 12:51:34 INFO (MainThread) [homeassistant.setup] Setup of domain binary_sensor took 5.3 seconds.
  138. 2018-11-29 12:51:34 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 6.00s
  139. 2018-11-29 12:51:34 INFO (MainThread) [homeassistant.core] Starting Home Assistant
  140. 2018-11-29 12:51:34 INFO (MainThread) [homeassistant.core] Timer:starting
  141. 2018-11-29 12:51:34 INFO (SyncWorker_10) [pyhap.accessory_driver] Loading Accessory state from /config/.homekit.state
  142. 2018-11-29 12:51:34 INFO (SyncWorker_31) [pyhap.accessory_driver] Starting the event loop
  143. 2018-11-29 12:51:34 INFO (SyncWorker_0) [pyhap.accessory_driver] Starting accessory Home Assistant Bridge on address 192.168.1.50, port 51827.
  144. 2018-11-29 12:51:35 INFO (Thread-3) [pyhap.hap_server] Got connection with (‘192.168.1.240’, 50759).
  145. 2018-11-29 12:51:35 INFO (Thread-4) [pyhap.hap_server] 192.168.1.240 - “POST /pair-verify HTTP/1.1” 200 -
  146. 2018-11-29 12:51:35 INFO (Thread-4) [pyhap.hap_server] 192.168.1.240 - “POST /pair-verify HTTP/1.1” 200 -
  147. 2018-11-29 12:51:35 INFO (Thread-4) [pyhap.hap_server] 192.168.1.240 - “GET /accessories HTTP/1.1” 200 -
  148. 2018-11-29 12:51:35 INFO (Thread-3) [pyhap.hap_server] Got connection with (‘192.168.1.248’, 49635).
  149. 2018-11-29 12:51:35 INFO (Thread-3) [pyhap.hap_server] Got connection with (‘192.168.1.237’, 60538).
  150. 2018-11-29 12:51:35 INFO (Thread-5) [pyhap.hap_server] 192.168.1.248 - “POST /pair-verify HTTP/1.1” 200 -
  151. 2018-11-29 12:51:35 INFO (Thread-6) [pyhap.hap_server] 192.168.1.237 - “POST /pair-verify HTTP/1.1” 200 -
  152. 2018-11-29 12:51:35 INFO (Thread-5) [pyhap.hap_server] 192.168.1.248 - “POST /pair-verify HTTP/1.1” 200 -
  153. 2018-11-29 12:51:35 INFO (Thread-5) [pyhap.hap_server] 192.168.1.248 - “GET /accessories HTTP/1.1” 200 -
  154. 2018-11-29 12:51:35 INFO (Thread-6) [pyhap.hap_server] 192.168.1.237 - “POST /pair-verify HTTP/1.1” 200 -
  155. 2018-11-29 12:51:35 INFO (Thread-6) [pyhap.hap_server] 192.168.1.237 - “GET /accessories HTTP/1.1” 200 -
  156. 2018-11-29 12:51:35 INFO (Thread-4) [pyhap.hap_server] 192.168.1.240 - “PUT /characteristics HTTP/1.1” 207 -
  157. 2018-11-29 12:51:35 INFO (Thread-4) [pyhap.hap_server] 192.168.1.240 - “PUT /characteristics HTTP/1.1” 207 -
  158. 2018-11-29 12:51:36 INFO (Thread-4) [pyhap.hap_server] 192.168.1.240 - “PUT /characteristics HTTP/1.1” 207 -
  159. 2018-11-29 12:51:36 INFO (Thread-5) [pyhap.hap_server] 192.168.1.248 - “PUT /characteristics HTTP/1.1” 207 -
  160. 2018-11-29 12:51:36 INFO (Thread-5) [pyhap.hap_server] 192.168.1.248 - “PUT /characteristics HTTP/1.1” 207 -
  161. 2018-11-29 12:51:36 INFO (MainThread) [homeassistant.components.http.view] Serving /api/websocket to 192.168.1.214 (auth: False)
  162. 2018-11-29 12:51:36 INFO (MainThread) [homeassistant.loader] Loaded lifx from homeassistant.components.lifx
  163. 2018-11-29 12:51:36 INFO (MainThread) [homeassistant.loader] Loaded nest from homeassistant.components.nest
  164. 2018-11-29 12:51:36 INFO (MainThread) [homeassistant.loader] Loaded upnp from homeassistant.components.upnp
  165. 2018-11-29 12:51:36 INFO (MainThread) [homeassistant.loader] Loaded deconz from homeassistant.components.deconz
  166. 2018-11-29 12:51:36 INFO (MainThread) [homeassistant.loader] Loaded cast from homeassistant.components.cast
  167. 2018-11-29 12:51:36 INFO (MainThread) [homeassistant.loader] Loaded zwave from homeassistant.components.zwave
  168. 2018-11-29 12:51:36 INFO (MainThread) [homeassistant.loader] Loaded sonos from homeassistant.components.sonos
  169. 2018-11-29 12:51:36 INFO (MainThread) [homeassistant.loader] Loaded simplisafe from homeassistant.components.simplisafe
  170. 2018-11-29 12:51:36 INFO (MainThread) [homeassistant.loader] Loaded smhi from homeassistant.components.smhi
  171. 2018-11-29 12:51:36 INFO (MainThread) [homeassistant.loader] Loaded zone from homeassistant.components.zone
  172. 2018-11-29 12:51:36 INFO (MainThread) [homeassistant.loader] Loaded homematicip_cloud from homeassistant.components.homematicip_cloud
  173. 2018-11-29 12:51:36 INFO (MainThread) [homeassistant.loader] Loaded hangouts from homeassistant.components.hangouts
  174. 2018-11-29 12:51:36 INFO (MainThread) [homeassistant.loader] Loaded dialogflow from homeassistant.components.dialogflow
  175. 2018-11-29 12:51:36 INFO (MainThread) [homeassistant.loader] Loaded mqtt from homeassistant.components.mqtt
  176. 2018-11-29 12:51:36 INFO (MainThread) [homeassistant.loader] Loaded ios from homeassistant.components.ios
  177. 2018-11-29 12:51:36 INFO (MainThread) [homeassistant.loader] Loaded ifttt from homeassistant.components.ifttt
  178. 2018-11-29 12:51:36 INFO (MainThread) [homeassistant.loader] Loaded twilio from homeassistant.components.twilio
  179. 2018-11-29 12:51:36 INFO (MainThread) [homeassistant.loader] Loaded mailgun from homeassistant.components.mailgun
  180. 2018-11-29 12:51:36 INFO (MainThread) [homeassistant.loader] Loaded openuv from homeassistant.components.openuv
  181. 2018-11-29 12:51:36 INFO (MainThread) [homeassistant.loader] Loaded tradfri from homeassistant.components.tradfri
  182. 2018-11-29 12:51:36 INFO (MainThread) [homeassistant.loader] Loaded unifi from homeassistant.components.unifi
  183. 2018-11-29 12:51:36 INFO (MainThread) [homeassistant.components.http.view] Serving /api/websocket to 192.168.1.214 (auth: False)
  184. 2018-11-29 12:51:52 INFO (MainThread) [homeassistant.components.discovery] Unknown service discovered: homekit {‘host’: ‘192.168.1.105’, ‘port’: 8080, ‘hostname’: ‘Hue-PB.local.’, ‘properties’: {‘c#’: ‘108’, ‘ff’: ‘1’, ‘id’: ‘AA:47:4F:F5:FD:BB’, ‘md’: ‘BSB002’, ‘pv’: ‘1.1’, ‘sf’: ‘1’, ‘s#’: ‘1’, ‘ci’: ‘2’}, ‘name’: ‘Philips hue - 7C8908’}
  185. 2018-11-29 12:51:52 INFO (MainThread) [homeassistant.components.discovery] Unknown service discovered: homekit {‘host’: ‘192.168.1.50’, ‘port’: 51827, ‘hostname’: ‘HA.local.’, ‘properties’: {‘md’: ‘Home Assistant Bridge’, ‘pv’: ‘1.0’, ‘id’: ‘7B:87:D1:85:0F:7E’, ‘c#’: ‘2’, ‘s#’: ‘1’, ‘ff’: ‘0’, ‘ci’: ‘2’, ‘sf’: ‘0’, ‘sh’: ‘cpi+zA==’}, ‘name’: ‘Home Assistant Bridge’}
  186. 2018-11-29 12:51:52 INFO (MainThread) [homeassistant.components.discovery] Unknown service discovered: homekit {‘host’: ‘192.168.1.100’, ‘port’: 51826, ‘hostname’: ‘eedomus.local.’, ‘properties’: {‘md’: ‘eedomus’, ‘pv’: ‘1.0’, ‘id’: ‘C1:38:5A:AC:39:06’, ‘c#’: ‘19’, ‘s#’: ‘1’, ‘ff’: ‘0’, ‘ci’: ‘2’, ‘sf’: ‘1’}, ‘name’: ‘eedomus’}
  187. 2018-11-29 12:51:52 INFO (MainThread) [homeassistant.components.discovery] Unknown service discovered: asus_router {‘host’: ‘192.168.1.10’, ‘port’: 36683, ‘ssdp_description’: ‘http://192.168.1.10:36683/rootDesc.xml’, ‘name’: ‘DSL-AC68U’, ‘model_name’: ‘DSL-AC68U’, ‘model_number’: ‘3.0.0.4.382’, ‘serial’: ‘ac:9e:17:69:df:60’, ‘manufacturer’: ‘ASUSTeK Computer Inc.’, ‘udn’: ‘uuid:02995ffe-ea41-4ac0-9f1a-4773f74bc07c’, ‘upnp_device_type’: ‘urn:schemas-upnp-org:device:InternetGatewayDevice:1’}
  188. 2018-11-29 12:51:52 INFO (MainThread) [homeassistant.components.discovery] Unknown service discovered: igd {‘host’: ‘192.168.1.10’, ‘port’: 36683, ‘ssdp_description’: ‘http://192.168.1.10:36683/rootDesc.xml’, ‘name’: ‘DSL-AC68U’, ‘model_name’: ‘DSL-AC68U’, ‘model_number’: ‘3.0.0.4.382’, ‘serial’: ‘ac:9e:17:69:df:60’, ‘manufacturer’: ‘ASUSTeK Computer Inc.’, ‘udn’: ‘uuid:02995ffe-ea41-4ac0-9f1a-4773f74bc07c’, ‘upnp_device_type’: ‘urn:schemas-upnp-org:device:InternetGatewayDevice:1’}
  189. 2018-11-29 12:51:52 INFO (MainThread) [homeassistant.components.discovery] Found new service: apple_tv {‘host’: ‘192.168.1.248’, ‘port’: 3689, ‘hostname’: ‘Salon.local.’, ‘properties’: {‘DFID’: ‘3’, ‘EiTS’: ‘1’, ‘mV’: ‘131082’, ‘aV’: ‘196620’, ‘hG’: ‘00000000-11b1-20e6-df41-5e86449545c7’, ‘fs’: ‘2’, ‘Name’: ‘Salón’, ‘atSV’: ‘65539’, ‘Ver’: ‘131075’}, ‘name’: ‘Salón’}
  190. 2018-11-29 12:51:52 INFO (MainThread) [homeassistant.components.discovery] Found new service: plex_mediaserver {‘name’: ‘laloNAS’, ‘host’: ‘192.168.1.50’, ‘port’: ‘32400’, ‘urlbase’: ‘https://192.168.1.50:32400’}
  191. 2018-11-29 12:51:52 INFO (MainThread) [homeassistant.components.discovery] Unknown service discovered: dlna_dms {‘host’: ‘172.17.0.1’, ‘port’: 32469, ‘ssdp_description’: ‘http://172.17.0.1:32469/DeviceDescription.xml’, ‘name’: ‘Plex Media Server: laloNAS’, ‘model_name’: ‘Plex Media Server’, ‘model_number’: ‘1.13.4.5271’, ‘serial’: None, ‘manufacturer’: ‘Plex, Inc.’, ‘udn’: ‘uuid:9e1b930b-eaf6-3ea7-b50c-6c81c8edefd3’, ‘upnp_device_type’: ‘urn:schemas-upnp-org:device:MediaServer:1’}
  192. 2018-11-29 12:51:52 INFO (MainThread) [homeassistant.components.discovery] Unknown service discovered: dlna_dms {‘host’: ‘192.168.1.50’, ‘port’: 32469, ‘ssdp_description’: ‘http://192.168.1.50:32469/DeviceDescription.xml’, ‘name’: ‘Plex Media Server: laloNAS’, ‘model_name’: ‘Plex Media Server’, ‘model_number’: ‘1.13.4.5271’, ‘serial’: None, ‘manufacturer’: ‘Plex, Inc.’, ‘udn’: ‘uuid:9e1b930b-eaf6-3ea7-b50c-6c81c8edefd3’, ‘upnp_device_type’: ‘urn:schemas-upnp-org:device:MediaServer:1’}
  193. 2018-11-29 12:51:52 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.plex
  194. 2018-11-29 12:51:52 INFO (SyncWorker_38) [homeassistant.components.media_player.plex] Discovery configuration done (no token needed)
  195. 2018-11-29 12:51:52 INFO (SyncWorker_38) [homeassistant.components.media_player.plex] Connected to: http://192.168.1.50:32400
Thanks!
@gerardojaime
Your problem is here
Can you share your config file, where you specify the enigma component.
Here is:
Name of the location where Home Assistant is running
Location required to calculate the time the sun rises and sets
latitude: 36.664
longitude: -4.5614
Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 0
metric for Metric, imperial for Imperial
unit_system: metric
Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Europe/Madrid
Customization file
customize: !include customize.yaml
Show links to resources in log and frontend
introduction:
Enables the frontend
frontend:
Enables configuration UI
config:
Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
base_url: example.duckdns.org:8123
Checks for available updates
Note: This component will send some information about your system to
the developers to assist with development of Home Assistant.
For more information, please see:
https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
Optional, allows Home Assistant developers to focus on popular components.
include_used_components: true
Discover some devices automatically
discovery:
Allows you to issue voice commands from the frontend in enabled browsers
conversation:
Enables support for tracking state changes over time
history:
View all events in a logbook
logbook:
Enables a map showing the location of tracked devices
map:
El Tiempo, en habitación jardín
weather:
  • platform: yweather
    woeid: 20080850
    forecast: 5
    monitored_conditions:
    • weather
    • weather_current
    • temp_min
    • temp_max
    • wind_speed
    • pressure
    • visibility
    • humidity
    • temperature
Media Players
apple_tv:
  • host: 192.168.1.248
    login_id: 00000000-11b1-20e6-df41-5e86449545c7
    credentials: 6F69107971F8927B:40D50E000FE2713F683A769D3B74ECC8BD893C0FC7319FD19E63583D1A451346
    start_off: true
media_player:
  • platform: plex
enigma:
devices:
- host: 192.168.1.6
port: 80
timeout: 20
username: root
password: lalo
Text to speech
tts:
  • platform: google
Cloud
cloud:
group: !include groups.yaml
script: !include scripts.yaml
sensor: !include sensors.yaml
binary_sensor: !include bsensors.yaml
homekit: !include homekit.yaml
switch: !include switch.yaml
Thanks!.
@cinzas
Would it be possible to implement a binary_sensor that checks if there is a timer set in the next 24h hours?
The reason is, I’m using you component mainly to turn my vu+ on and off with a sonoff socket.
Everyone away → shutdown vu+ → wait 5min → turn socket off
This works really well and saves me a lot of energy because one vu+ model has the ability to use WOL.
The problem is, I dont want to power off the vu+ when there is a timer pending for recording series or movies.
you can get the timer list with
http://<ipaddress>/web/timerlist
but the times in the results come back in ‘unix’ time, e.g.
<e2timerlist>
<e2timer>
<e2disabled>0</e2disabled> <e2timebegin>1543692420</e2timebegin> <e2timeend>1543700100</e2timeend> <e2duration>7680</e2duration> <e2startprepare>1543692400</e2startprepare> <e2justplay>0</e2justplay>
</e2timer>
If you’re good using shell scripts, or use node red, or even appdaemon you could get this info such as
In a shell script
  1. Get the current date time in ‘linux’ format, i.e. seconds since epoch - date +%s
  2. Call the url with wget and using something like xmllint to get the e2startprepare time for each timer
  3. Subtract curr date from timer date and if the value is > 0 but less then 60s * 60m * 24h = 86400secs then you’ve got a timer in the next 24 hrs
In node red
  • http request
  • xml to convert to JSON
  • function to enumerate the timers - something like this:
var duration = 24;
var checktime = duration*60*60;
var now = (new Date).getTime() / 1000;
var timerInNextDuration = false;
for(i=0;i<Object.keys(msg.payload.e2timerlist.e2timer).length;i++)
//console.log(msg.payload.e2timerlist.e2timer[i].e2startprepare);
diff = msg.payload.e2timerlist.e2timer[i].e2startprepare - now;
if(diff>=0 && diff <= checktime) timerInNextDuration = true;
if(timerInNextDuration)
//DO SOMETHING HERE
console.log("found recording in period");
return msg;
You could expose the result as a sensor to use in automations.
Are you giving the right indentation?
Yes of course, im sure of this.
Thanks. I’m already using a node-red flow for this so i think i’ll give it a try at the weekend.
Hi
I was using an old version of this. I upgraded with the latest version and didn’t bother to keep the old working version…
But now it is not working. These are the errors I’m seeing.
Error during setup of component enigma
  File "/usr/local/lib/python3.6/site-packages/homeassistant/setup.py", line 145, in _async_setup_component
    hass, processed_config)
  File "/config/custom_components/enigma.py", line 91, in async_setup
    configured_devices = config[DOMAIN].get(CONF_DEVICES)
KeyError: 'enigma'
Unable to set up dependencies of media_player.enigma. Setup failed for dependencies: enigma
Unable to prepare setup for platform media_player.enigma: Could not set up all dependencies.
Obviously it’s not listed anymore as a media player and I can’t work with it. I haven’t changed anything on the receiver side, I only upgraded to the latest version.
Check the readme (https://github.com/cinzas/homeassistant-enigma-player)
Enigma is now a component that implement two platforms (media_player and notify).
Configuration also changes:
enigma:
  devices:
    - host: 192.168.1.20
      port: 80
      timeout: 20
      username: root
      password: your_password
      picon: picon
notify:
  - platform: enigma
    host: 192.168.1.20
    port: 80
    username: root
Found the time to implement this in node-red. Thanks to your fantastic guide its working now :heart_eyes:
The function either returns 1 if a timer is active or 0 if no timer is found.
This is a screenshot of the flow for everyone interested:
Hey, its me again.
I thought it would be a good idea to update the component from github but now i cannot get it to work anymore. I removed the old file and copied both folders and the single enigma.py
2018-12-04 16:06:56 ERROR (MainThread) [homeassistant.setup] Error during setup of component enigma Traceback (most recent call last): File “/usr/local/lib/python3.6/site-packages/homeassistant/setup.py”, line 145, in _async_setup_component hass, processed_config) File “/config/custom_components/enigma.py”, line 91, in async_setup configured_devices = config[DOMAIN].get(CONF_DEVICES) KeyError: ‘enigma’
2018-12-04 16:06:56 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of media_player.enigma. Setup failed for dependencies: enigma
2018-12-04 16:06:56 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform media_player.enigma: Could not set up all dependencies.`
- platform: enigma
  devices:
    - host: 192.168.x.x
      port: 80
      icon: mdi:satellite-variant
      timeout: 20
      username: root
      password: 'xxx'
Can anyone help me?
Check the indentation :
enigma:
  devices:
    - host: 192.168.x.x
      port: 80
      timeout: 20
      username: root
      password: 'xxx'
Also guarantee you add the right enigma.py files in the right place.
custom_components
├── enigma.py
├── media_player
│   ├── enigma.py
├── notify
│   ├── enigma.py
Could it be, that i cannot use this with my existing splitted config?
This is the hole yaml:
https://hastebin.com/raw/ereyoronel
The part in the middle is the old config.
This is the error message:
Error loading /config/configuration.yaml: while parsing a block collection in "/config/includes/media_player/living_room.yaml", line 1, column 1 expected <block end>, but found '?' in "/config/includes/media_player/living_room.yaml", line 23, column 1
Your identation is wrong. Please post your config and log on pastebin.ca and post the link here.
