Curious, I am playing with my Enphase now, and I noticed that my results are updating every 1 or so minutes on HA. I have seen that a few people are able to get updates every 1 second. I was wondering how to do that… I tried checking the Enphase site and calling them, but I have had no luck. I assume this is on the enphase side - not HA, but I was hoping someone might have an idea.
Ideally, I would like to see the consumption real time, so that we can determine how much each appliance is using in real time by turning it off and on. Of course, I can wait a minute each time, but it would be nicer if I could get an update every second.
Yep, 1 second updates are able to be done via this script. I currently have this working myself.
The 1 second updates are currently only possible by running this script on a computer that has python. In my case I have a windows 10 computer that I leave on all the time where I just leave this python script running and it polls the envoy every second and then publishes the output to Home Assistant via the mqtt protocol.
The installer password was rather easy to decrypt too. Let us know if you need a hand as I just went through this myself.
This is great… I will take a look. I am using a Windows 10 Hyper-V to run my instance of HA. So I can do the same. I tried to setup a installer account, which I was able to do, but I noticed that I could not access my enphase installer account. Enphase told me only the installer that setup the system has access… not just any installer. If you have a link to decrypt the installer credentials, that would be great too. This is an amazing thread and I am learning so much about HA and Enphase!
Copied and pasted my serial number into serialnumber = of passwordCalc.py (left of screen)
then I pressed Run / Run Module and it spits out the password in blue on the output (right of screen)
@del13r Genius Simply a genius. Thank you for this information. I was able to follow your instructions and get the data I was looking for… This is great!
I’m getting the following error in the HAS logs sometimes at startup (5 in succession):
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/connection.py:89
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 16:45:31 (5 occurrences)
Last logged: 16:45:31
[281473253665088] Received invalid command: energy/info
Has anyone else seen this? My Energy dashboard seems to populate just fine…
I saw that, but I haven’t excluded anything from Recorder, and my Energy dashboard is populating just fine. Seems to only happen at HA startup, and not every time. Can anyone see if they have the same message in the logs?
Something about the visual layout of power wheel turned me off and I didn’t feel I could commit to it.
I have instead decided to go with the Tesla Style Solar Power Card as it sort of looks like the Energy Dashboard card.
Once installed, I used the following sensors in the card config.
type: custom:tesla-style-solar-power-card
# 3 flows between bubbles
grid_to_house_entity: sensor.mqtt_import_power
generation_to_grid_entity: sensor.mqtt_export_power
generation_to_house_entity: sensor.mqtt_consumption
# extra values to show as text above icons
grid_extra_entity: sensor.mqtt_instant_cost_per_hour
house_extra_entity: sensor.today_energy_total_cost
generation_extra_entity: sensor.temp
