Enphase Envoy with Energy Dashboard
Oh you set that up today, wow.
So is this in addition to the minute by minute graph I have setup can all be replicated there etc?
I might need to remind myself how to reverse everything and move it. Or is there an easier route?
I am excited. Thanks for the awesome work again.
Hi @Mrsash
The default Enphase production and consumption sensors are minute by minute, so I’m not sure specifically which sensors/graphs you are referring to.
The guide is focussed on 2 steps.
Step 1 - Getting home assistant to calculate both:
Grid import power
Grid export power
using template sensors to perform calculations using data from the enphase sensors.
Step 2 - Setting up Riemann Sum sensors which convert:
grid import power (W) to grid import energy (kWh)
grid export power (W) to grid export energy (kWh)
Given you are asking about power import and power export sensors being absent, I have to assume you have not set these up yet.
Sorry I meant I have this currently which is working well.
I guess what I was trying to figure out is if the updated guide for Enphase Envoy and Energy Dashboard is a total replacement including the above minute by minute graph?
Ah ok,
This graph is in W, so you have done step 1 which gives you power export and power import (shown in grey in the graph). The names may not be identical but you can adjust them to suit your setup.
If you want to use energy dashboard, you can do step 2 and convert the power sensors you have in the graph into energy sensors.
ok sounds promising. Pretty much have the following in my config.yaml
rest:
  - headers:
      Authorization: !secret enphase_api
    verify_ssl: False
    scan_interval: 15
    resource: https://envoy.local/ivp/meters/readings
      - name: "Power Production"
        value_template: >
          {% set value = value_json[0].activePower | int(0) %}
          {% if value  <= 5 -%}
              0
          {% elif is_state('sun.sun','below_horizon') %}
              0
          {%- else -%}
              {{ value }}
          {%- endif %}
        device_class: power
        unit_of_measurement: W
        state_class: measurement
        icon: mdi:solar-panel
      - name: "Power Net"
        value_template: "{{ value_json[1].activePower | int(0) }}"
        device_class: power
        icon: mdi:transmission-tower
template:
  - sensor:
      - name: Solar Power Corrected
        device_class: power
        state: >
          {% set value = states('sensor.envoy_XXXXXXXXXX_current_power_production') | int(0) %}
            0
            0
          {%- else -%}
            {{ value }}
          {%- endif %}
  - sensor:
      - name: Grid Import Power
        device_class: power
        state: >
          {{ [0, states('sensor.envoy_XXXXXXXXXX_current_power_consumption') | int(0) - states('sensor.solar_power_corrected') | int(0) ] | max }}
  - sensor:
      - name: Grid Export Power
        device_class: power
        state: >
          {{ [0, states('sensor.solar_power_corrected') | int(0) - states('sensor.envoy_XXXXXXXXXX_current_power_consumption') | int(0) ] | max }}
  - sensor:
      - name: Net Power
        device_class: power
        state: >
          {% set production = states('sensor.solar_power_corrected') | int %}
          {% set consumption = states('sensor.envoy_XXXXXXXXXX_current_power_consumption') | int %}
          {{ (production - consumption) }}
  - platform: integration
    name: Solar Energy Corrected
    source: sensor.solar_power_corrected
    method: left
    unit_prefix: k
    unit_time: h
    name: Grid Import Energy
    source: sensor.grid_import_power
    method: left
    unit_prefix: k
    unit_time: h
    name: Grid Export Energy
    source: sensor.grid_export_power
    method: left
    unit_prefix: k
    unit_time: h
utility_meter:
  daily_energy:
    source: sensor.grid_import_energy
    name: Daily Import Meter
    cycle: daily
    tariffs:
      - offpeak
      - shoulder
      - peak
  daily_energy_export:
    source: sensor.grid_export_energy
    name: Daily Export Meter
    cycle: daily
    tariffs:
      - buyback
Your sensor names are:
These sensors are the ones you use in your automations.
My sensor names are:
sensor.power_import
sensor.power_export
Just update the sensor names from mine to yours.
For your Energy Dashboard, you can use these
Import = Grid Consumption
Export = Return to Grid
Oh right so just the names are different
Grid Import Power to your sensor.power_import
Grid Export Power to sensor.power_export
So I just need to substitute with my sensor names, got it
The energy Dash you are referring to is the HA one right? Already have the Dash configured
thanks for the help
Once the new heat pump is in I will have it setup with automatons. Cant wait…
Hey guys! I found an issue with my data reporting here
When the day ticks over, the production doesn’t start at zero, instead it starts at 3.54kWh. Is there anything I can do to fix this? Here’s my energy dashboard
Any help would be appreciated to balance this out. Dunno why it’s doing this, it happened after my Envoy firmware got updated to the latest version.
Just checked mine, and the “Energy production today” value is reset to 0 at midnight.
not resetting to 0 can be worked around by setting up an integration sensor to record power over time into an energy figure.
hmmm, how would i do that? could you give any pointers? Thank you!
Sure, I just wrote about how this works in another topic.
As for how you would do it, you would find the name of your solar power production sensor and use that in the “Input Sensor:” field.
My only warning would be to make sure your power sensor is in W (Watts) as Riemann sum integral seems to only work when I use a sensor expressed in W (Watts) in my experience.
I was wondering if someone could help me. I believe I have everything right, but my import energy doesn’t seem to be working.
Here is code from my configuration.yaml
template:
  - sensor:
        device_class: power
        state: >
            {{ [0, states('sensor.envoy_121804003802_current_power_consumption') | int(0) - states('sensor.envoy_121804003802_current_power_production') | int(0) ] | max }}
  - sensor:
        device_class: power
        state: >
            {{ [0, states('sensor.envoy_121804003802_current_power_production') | int(0) - states('sensor.envoy_121804003802_current_power_consumption') | int(0) ] | max }}
    unit_prefix: k
    unit_time: h
    method: left
    unit_prefix: k
    unit_time: h
    method: left
This is the entities added to the energy dashboard
Perhaps it’s just taking time? as I haven’t imported any energy yet
Don’t worry, human error, all working :slight_smile:
so… I was playing with the way it shows me all this info. I wanted to incorporate the energy distribution for the day on the top right. At the moment its just a duplicated live usage powerflow card entity. Any thoughts?
Like this?
Here is my code
cards:
  - type: custom:power-flow-card-plus
    entities:
      grid:
        entity: sensor.power_net
      solar:
        entity: sensor.power_production
      home:
        entity: sensor.power_consumption
      fossil_fuel_percentage:
        entity: sensor.grid_fossil_fuel_percentage
  - type: energy-distribution
Thanks much appreciated.
Hmm I added that to a card and I was getting errors.
I didnt have the sensor.power_consumption instead used sensor.envoy_XXXXXXXXXX_current_power_consumption
Also I had to move this to the left and remove the "- "
Need to wait until it loads info, but will post it after it does.
Either create a new view or edit an existing view and press the pencil icon.
Then press the 3 dots in top right and press edit in yaml
Then paste in the code
The - type: is used for each card in the page
The other method is to press add card, choose manual, paste in type: energy-distribution
Cool
Got it working. Top right
Any reason the Grid Export and solar info does not match? Seems off significantly
