I don’t know, I just went to the services page and either switched on the light with the service.toggle and copied the service data !!
However it works !!
However it works !!
Your solution works, I try it both with and without the extra “brackets” (that @alverman used). Not sure why he need those extras…Thanks for your solution.
Okay my issue is related…
So I’ve set up a sensor that changes Icon based on state:
sensors:
garage_door_status:
value_template: >-
{% if states.binary_sensor.garage_roller_100.state == 'on' %}
Open
{% elif states.binary_sensor.garage_roller_100.state == 'off' %}
Close
{% endif %}
icon_template: >-
mdi:garage-open
mdi:garage
{% endif %}
which is great, but I want to associate it with a button:
type: 'custom:button-card'
tap_action:
action: toggle
confirmation:
text: Toggle Garage Door?
entity: switch.garage_door_90
icon: 'mdi:garage'
show_state: false
show_name: true
show_icon: true
color: var(--paper-item-icon-color)
hold_action:
action: none
How do I combine the two…
The reason I’m doing that is because my button activates a pushbutton via dry contact, so there is no feedback on state. So i have a reed switch which will pick up if it’s open or closed so I want to relay that information visually on this button rather than having a button and a sensor state glance adjacent.
Thanks.
Instead of using the button, use the sensor, and call the button as its action:
- entity: garage_door_status
tap_action:
action: call-service
service: switch.toggle
service_data:
entity_id: switch.garage_door_90
confirmation:
or something similar to that
Thanks Richie!
this works:
tap_action:
service_data:
confirmation:
entity: sensor.garage_door_status
show_state: false
show_name: false
show_icon: true
hold_action:
action: none
