Hey, Thanks for posting this. I was trying to get a notification for alarm in delay entry mode and did not think to use an attribute here. Kept trying different states to no avail.
Has the situation with Envisalink - specifically with Honeywell panels - gotten any better? And what is the experience like using zones for automation purposes, do they report open/closed relatively quickly, even with lots of zones?
I’m moving in to a new house next month and it has the remnants of an ancient Vista 10-SE ADT system in place, including a fair amount of wiring. I’m planning on putting in a rather extensive system, mix of wired and wireless, door and window sensors, motion in every room, glass break, and smokes and CO. My plan is to use a 128BPT, but I’m not going to do that unless I can also use the door and motion sensors for automations, and have them be more or less as fast and reliable as my current Z-Wave and Zigbee stuff… any feedback would be greatly appreciated
Not entirely sure what situation you mean? I’ve got an EVL4 working just fine with my Vista 20P and HA. report is about a second. I have both wired and wireless door/window contacts. Been good for just under a year in this house. Last house had an EVL3 with a Vista 15P - same situation of wired and wireless, about a second report, no issues.
Anybody know how to get Envisalink 4 working in home assistant in standalone more?
This is using just the Envisalink and Uno expansion boards.
It loads a different firmware than the DSC / Honey well.
Would love to get this working!
Did you get your Vista 128bpt installed with an Envisalink 4? I have that same panel with an EVL4 and it mostly works. If I just open and close one door or one motion, it is pretty much immediate. But if I open a door and leave it open then open another door, the second one is delayed. If I close the first door, leaving the second door open, EVL4 reports both doors still open until I close the second door then both will clear. It is quite annoying. I have monitored these panels before through the serial port and I can get immediate real time response. But connecting through the keypad bus is just not the same.
I scoured through this thread trying to find an answer. I have a DSC alarm panel connected to the Envisalink. Everything works as you’d expect, but when I arm the alarm in “stay” mode, even with a PIN code it is still reported back that the last arm was “unknown” in the integration.
I assume this is because arming in “stay” mode on the DSC panel is just holding the “stay” button for two seconds. So no PIN code is required, but is there a way to arm in stay mode (still no audible beeps during the arming process) while also still providing a PIN so the integration correctly identifies the user who armed the system.
