EPEVER Modbus RS-485 Config
hi @marcao88
Yes there is rs485 rj-45 port on UPpower Hi, but like I have it’s connected to BMS-LINK.
If you have ebox-wifi-01, make the cable and connect it to DB9 connector, should be easy and pinouts are in the manuals. That way you should able to connect like in this thread.
I have feel that Epever try to get all new inverters connected to their cloud services (like other manufactures also) and from there I assume in future they offer API (in Epever Cloud service, there is already some mentions on the API). That way it works in normal conditions. But if after few years cloud service stop working or you have unreliable/no internet connection then it is problematic.
I finally ditched “EPEVER-WIFI-2.4G-DB9-B" and I have old rpi2b connected via usb-rs485 cable to inverter (which was delivered with inverter). Basically config same as in post #67 by dylan, but with different registers values. This has been worked for me few weeks now without problems and I also control from HA when UPower Hi charge battery from grid (and when consuming it).
Check this for newer register values https://community.home-assistant.io/t/epever-upower-hi-modbus-setting-if-you-need/483184. And from this perl script you will find more register values (from German FHEM forum)
