If you run HA on Home Assistant Operating System, it not have drivers for CC-USB-DB9(M)-150U-V1.0.
Because of that I have ~12 years old Atom industrial PC running Debian 11 and for it have build drivers to CC-USB-DB9(M)-150U-V1.0. Drivers you find here . This Debian also runs mbusd daemon. With this mbusd daemon HA can talk via rs485 bus to UPower HI.
All UPower HI series devices have same rs485 registers, so you can use directly my setup.
Maybe esp32 can be used, but I don’t own it so I no idea
Thank you so much for the modbus config! And finding all of the register information… I have gotten it working using the ebox-wifi-01, im very happy . Now to make a dashboard:thinking:
Hi, i think there is one register missing, for the current load in watts, i dont suppose you would know the correct register address etc for this?
I found this from marcao88 on another thread, but it does not work for me, but the address type looks different to yours, not hexadecimal?
name: “Sol2 Load W”
unit_of_measurement: W
device_class: power
slave: 1
address: 12558 # low 12550 high 12551 #12558
input_type: input
scale: 0.01
precision: 2
scan_interval: 5
Yes thanks, ive done a template calculation instead, and works ok. Ive also emailed epever to see if they can send me the full register information for upower hi series.
Hello. I’m from Romania and I have a home assistant system for monitoring the devices in the house. the photovoltaic system consisting of 4 mppt epever tracer 4210 and rj45 wi-fi modules. how could I integrate those mppts in ha? they are connected to the internal network and I have their ips. I greet you.
Has anyone managed to get buttons for the Upower HI series working? (Edit: In esphome)
I have the stats working but would really like to be able to switch between Utility Priority and Inverter Priority without going to the front panel every evening.
I’m not fussed about the other switches but it’d be nice to have them working too but seems epever changed a lot of stuff for some reason.
Just want to say a big thank you to Timo and Ucatchmydrift for all the information supplied here, finally got this working with my two UP-Hi inverter/chargers.
Many thanks
Ade
