EPEVER UPower-Hi modbus setting, if you need :)
Perhaps you need to check those data_types and swap and there is also two registers L and H, this one is example for the older UPower taken from this thread EPEVER Modbus RS-485 Config - #67 by dylan
    - name: "Solaire Watt L"
      unique_id: epever.solarwatt
      unit_of_measurement: W
      slave: 1
      address: 12546
      input_type: input
      data_type: int32
      scale: 0.01
      count: 2
      precision: 2
      swap: word
    - name: "Solaire Watt H"
      unique_id: epever.solarwatt2
      unit_of_measurement: kWh
      slave: 1
      address: 12547
      input_type: input
      data_type: int32
      scale: 0.01
      count: 2
      precision: 2
      swap: word
Maybe the len value from perl scripts means that it reads also next register like this example 12546&12547. But how to get one value from those two registers, I don’t know.
Check from docs https://www.home-assistant.io/integrations/modbus/
Let me know if you get it working.
