No, I don’t use Nabu Casa
After 1 month, I got again the same error
Starts with HA core 0.114.3, upgrade to 0.115.2 with no success…
When I remove/add the integration, it works for a few minutes only (I got 1 value for each sensor)…
Log:
Sep 23 12:23:58 localhost hass[21015]: #033[31m2020-09-23 12:23:58 ERROR (MainThread) [homeassistant.components.climate] The netatmo platform for the climate integration does not support platform setup. Please remove it from your config.#033[0m
Sep 23 12:24:47 localhost hass[21015]: 2020-09-23 12:24:47,920 [21015] INFO homeassistant.components.netatmo.config_flow: Successfully authenticated
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,148 [21015] ERROR homeassistant.components.netatmo: Error during webhook registration - 400 - Bad request - Allowed ports for webhooks are 443 and 80. (21) when accessing 'https://api.netatmo.com/api/addwebhook'
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,188 [21015] DEBUG homeassistant.components.netatmo.data_handler: Data class HomeData added
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,217 [21015] DEBUG homeassistant.components.netatmo.data_handler: Data class WeatherStationData added
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,218 [21015] DEBUG homeassistant.components.netatmo.sensor: Adding module Indoor 70:ee:50:3d:0e:7a
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,219 [21015] DEBUG homeassistant.components.netatmo.sensor: Adding module Outdoor 02:00:00:3c:dd:80
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,245 [21015] INFO homeassistant.helpers.entity_registry: Registered new sensor.netatmo entity: sensor.netatmo_darkstation_temperature
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,248 [21015] DEBUG homeassistant.components.netatmo.netatmo_entity_base: New client sensor.netatmo_darkstation_temperature
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,253 [21015] INFO homeassistant.helpers.entity_registry: Registered new sensor.netatmo entity: sensor.netatmo_darkstation_co2
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,258 [21015] DEBUG homeassistant.components.netatmo.netatmo_entity_base: New client sensor.netatmo_darkstation_co2
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,263 [21015] INFO homeassistant.helpers.entity_registry: Registered new sensor.netatmo entity: sensor.netatmo_darkstation_humidity
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,266 [21015] DEBUG homeassistant.components.netatmo.netatmo_entity_base: New client sensor.netatmo_darkstation_humidity
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,272 [21015] INFO homeassistant.helpers.entity_registry: Registered new sensor.netatmo entity: sensor.netatmo_darkstation_noise
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,275 [21015] DEBUG homeassistant.components.netatmo.netatmo_entity_base: New client sensor.netatmo_darkstation_noise
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,280 [21015] INFO homeassistant.helpers.entity_registry: Registered new sensor.netatmo entity: sensor.netatmo_darkstation_pressure
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,284 [21015] DEBUG homeassistant.components.netatmo.netatmo_entity_base: New client sensor.netatmo_darkstation_pressure
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,288 [21015] INFO homeassistant.helpers.entity_registry: Registered new sensor.netatmo entity: sensor.netatmo_darkstation_wifi
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,295 [21015] DEBUG homeassistant.components.netatmo.netatmo_entity_base: New client sensor.netatmo_darkstation_wifi
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,300 [21015] INFO homeassistant.helpers.entity_registry: Registered new sensor.netatmo entity: sensor.netatmo_darkstation_min_temp
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,304 [21015] DEBUG homeassistant.components.netatmo.netatmo_entity_base: New client sensor.netatmo_darkstation_min_temp
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,308 [21015] INFO homeassistant.helpers.entity_registry: Registered new sensor.netatmo entity: sensor.netatmo_darkstation_max_temp
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,315 [21015] DEBUG homeassistant.components.netatmo.netatmo_entity_base: New client sensor.netatmo_darkstation_max_temp
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,322 [21015] INFO homeassistant.helpers.entity_registry: Registered new sensor.netatmo entity: sensor.netatmo_darkstation_reachability
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,324 [21015] DEBUG homeassistant.components.netatmo.netatmo_entity_base: New client sensor.netatmo_darkstation_reachability
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,331 [21015] INFO homeassistant.helpers.entity_registry: Registered new sensor.netatmo entity: sensor.netatmo_darkstation_wifi_level
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,334 [21015] DEBUG homeassistant.components.netatmo.netatmo_entity_base: New client sensor.netatmo_darkstation_wifi_level
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,340 [21015] INFO homeassistant.helpers.entity_registry: Registered new sensor.netatmo entity: sensor.netatmo_darkstation_outdoor_temperature
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,343 [21015] DEBUG homeassistant.components.netatmo.netatmo_entity_base: New client sensor.netatmo_darkstation_outdoor_temperature
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,348 [21015] INFO homeassistant.helpers.entity_registry: Registered new sensor.netatmo entity: sensor.netatmo_darkstation_outdoor_humidity
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,351 [21015] DEBUG homeassistant.components.netatmo.netatmo_entity_base: New client sensor.netatmo_darkstation_outdoor_humidity
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,358 [21015] INFO homeassistant.helpers.entity_registry: Registered new sensor.netatmo entity: sensor.netatmo_darkstation_outdoor_radio
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,362 [21015] DEBUG homeassistant.components.netatmo.netatmo_entity_base: New client sensor.netatmo_darkstation_outdoor_radio
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,368 [21015] INFO homeassistant.helpers.entity_registry: Registered new sensor.netatmo entity: sensor.netatmo_darkstation_outdoor_battery
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,372 [21015] DEBUG homeassistant.components.netatmo.netatmo_entity_base: New client sensor.netatmo_darkstation_outdoor_battery
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,381 [21015] INFO homeassistant.helpers.entity_registry: Registered new sensor.netatmo entity: sensor.netatmo_darkstation_outdoor_battery_percent
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,388 [21015] DEBUG homeassistant.components.netatmo.netatmo_entity_base: New client sensor.netatmo_darkstation_outdoor_battery_percent
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,395 [21015] INFO homeassistant.helpers.entity_registry: Registered new sensor.netatmo entity: sensor.netatmo_darkstation_outdoor_min_temp
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,397 [21015] DEBUG homeassistant.components.netatmo.netatmo_entity_base: New client sensor.netatmo_darkstation_outdoor_min_temp
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,404 [21015] INFO homeassistant.helpers.entity_registry: Registered new sensor.netatmo entity: sensor.netatmo_darkstation_outdoor_max_temp
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,408 [21015] DEBUG homeassistant.components.netatmo.netatmo_entity_base: New client sensor.netatmo_darkstation_outdoor_max_temp
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,412 [21015] INFO homeassistant.helpers.entity_registry: Registered new sensor.netatmo entity: sensor.netatmo_darkstation_outdoor_reachability
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,417 [21015] DEBUG homeassistant.components.netatmo.netatmo_entity_base: New client sensor.netatmo_darkstation_outdoor_reachability
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,421 [21015] INFO homeassistant.helpers.entity_registry: Registered new sensor.netatmo entity: sensor.netatmo_darkstation_outdoor_radio_level
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,426 [21015] DEBUG homeassistant.components.netatmo.netatmo_entity_base: New client sensor.netatmo_darkstation_outdoor_radio_level
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,430 [21015] INFO homeassistant.helpers.entity_registry: Registered new sensor.netatmo entity: sensor.netatmo_darkstation_outdoor_battery_level
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,433 [21015] DEBUG homeassistant.components.netatmo.netatmo_entity_base: New client sensor.netatmo_darkstation_outdoor_battery_level
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,644 [21015] DEBUG homeassistant.components.netatmo.data_handler: No weather station available
Sep 23 12:24:48 localhost hass[21015]: 2020-09-23 12:24:48,650 [21015] DEBUG homeassistant.components.netatmo.data_handler: Data class HomeCoachData added
Sep 23 12:30:48 localhost hass[21015]: 2020-09-23 12:30:48,161 [21015] DEBUG homeassistant.components.netatmo.data_handler: 403 - Forbidden - Application does not have the good scope rights (13) when accessing 'https://api.netatmo.com/api/getstationsdata'
Sep 23 12:30:48 localhost hass[21015]: 2020-09-23 12:30:48,242 [21015] DEBUG homeassistant.components.netatmo.data_handler: 403 - Forbidden - Application does not have the good scope rights (13) when accessing 'https://api.netatmo.com/api/gethomecoachsdata'
Are you using that Netatmo (dev) app elsewhere than HA?
No (I use the native Netatmo android app ?)
I already try to recreate the app on https://dev.netatmo.com/apps/ to be sure there is no conflict
When I delete the integration, 2 “panels” are created with the “configure” button.
( I got 2 ext. cameras working fine)
Have you been using the Netatmo beta integration via HACS?
No, never, only the official integration
If you haven’t done this already please remove the integration, restart HA and then add it back.
I already do that, 3 Times
Can you please check your config for other entries of netatmo like for example in the climate or sensors config?
All netatmo related config is :
netatmo:
client_id: !secret netatmo_clientid
client_secret: !secret netatmo_secretkey
Ok, I just wonder because your log says otherwise:
Which hints that you have a netatmo entry in your climate config.
Holly crap ! you’re right ! I miss that in my climate.yaml file…
- platform: netatmo
I remove that line, remove/add the integration, same issue :
Sep 24 09:39:33 localhost hass[31933]: #033[32m2020-09-24 09:39:33 INFO (MainThread) [homeassistant.setup] Setting up netatmo#033[0m
Sep 24 09:39:33 localhost hass[31933]: #033[32m2020-09-24 09:39:33 INFO (MainThread) [homeassistant.setup] Setup of domain netatmo took 0.0 seconds#033[0m
Sep 24 09:42:20 localhost hass[31933]: 2020-09-24 09:42:20,211 [31933] INFO homeassistant.components.netatmo.config_flow: Successfully authenticated
Sep 24 09:42:20 localhost hass[31933]: 2020-09-24 09:42:20,435 [31933] ERROR homeassistant.components.netatmo: Error during webhook registration - 400 - Bad request - Allowed ports for webhooks are 443 and 80. (21) when accessing 'https://api.netatmo.com/api/addwebhook'
Sep 24 09:42:20 localhost hass[31933]: 2020-09-24 09:42:20,515 [31933] DEBUG homeassistant.components.netatmo.data_handler: Data class HomeData added
Sep 24 09:42:20 localhost hass[31933]: 2020-09-24 09:42:20,553 [31933] DEBUG homeassistant.components.netatmo.data_handler: Data class WeatherStationData added
Sep 24 09:42:20 localhost hass[31933]: 2020-09-24 09:42:20,554 [31933] DEBUG homeassistant.components.netatmo.sensor: Adding module Indoor 70:ee:50:3d:0e:7a
Sep 24 09:42:20 localhost hass[31933]: 2020-09-24 09:42:20,557 [31933] DEBUG homeassistant.components.netatmo.sensor: Adding module Outdoor 02:00:00:3c:dd:80
Sep 24 09:42:20 localhost hass[31933]: 2020-09-24 09:42:20,581 [31933] INFO homeassistant.helpers.entity_registry: Registered new sensor.netatmo entity: sensor.netatmo_darkstation_temperature
Sep 24 09:42:20 localhost hass[31933]: 2020-09-24 09:42:20,589 [31933] DEBUG homeassistant.components.netatmo.netatmo_entity_base: New client sensor.netatmo_darkstation_temperature
Sep 24 09:42:20 localhost hass[31933]: 2020-09-24 09:42:20,886 [31933] DEBUG homeassistant.components.netatmo.data_handler: No weather station available
Sep 24 09:42:20 localhost hass[31933]: 2020-09-24 09:42:20,887 [31933] DEBUG homeassistant.components.netatmo.data_handler: Data class HomeCoachData added
Sep 24 09:42:21 localhost hass[31933]: 2020-09-24 09:42:21,166 [31933] DEBUG homeassistant.components.netatmo.data_handler: Data class CameraData added
Sep 24 09:42:21 localhost hass[31933]: 2020-09-24 09:42:21,167 [31933] DEBUG homeassistant.components.netatmo.camera: Adding camera 70:ee:50:63:a2:cc cam_devant
Sep 24 09:42:21 localhost hass[31933]: 2020-09-24 09:42:21,168 [31933] DEBUG homeassistant.components.netatmo.camera: Adding camera 70:ee:50:63:ac:b8 cam_jardin
Sep 24 09:42:21 localhost hass[31933]: 2020-09-24 09:42:21,247 [31933] INFO homeassistant.helpers.entity_registry: Registered new camera.netatmo entity: camera.netatmo_cam_devant
Sep 24 09:42:21 localhost hass[31933]: 2020-09-24 09:42:21,249 [31933] DEBUG homeassistant.components.netatmo.netatmo_entity_base: New client camera.netatmo_cam_devant
Sep 24 09:42:21 localhost hass[31933]: 2020-09-24 09:42:21,254 [31933] INFO homeassistant.helpers.entity_registry: Registered new camera.netatmo entity: camera.netatmo_cam_jardin
Sep 24 09:42:21 localhost hass[31933]: 2020-09-24 09:42:21,267 [31933] DEBUG homeassistant.components.netatmo.netatmo_entity_base: New client camera.netatmo_cam_jardin
Sep 24 09:48:20 localhost hass[31933]: 2020-09-24 09:48:20,607 [31933] DEBUG homeassistant.components.netatmo.data_handler: No weather station available
Sep 24 09:55:20 localhost hass[31933]: 2020-09-24 09:55:20,349 [31933] DEBUG homeassistant.components.netatmo.data_handler: No weather station available
Sep 24 09:59:20 localhost hass[31933]: 2020-09-24 09:59:20,290 [31933] DEBUG homeassistant.components.netatmo.data_handler: 403 - Forbidden - Application does not have the good scope rights (13) when accessing 'https://api.netatmo.com/api/getstationsdata'
Sep 24 10:00:20 localhost hass[31933]: 2020-09-24 10:00:20,404 [31933] DEBUG homeassistant.components.netatmo.data_handler: 403 - Forbidden - Application does not have the good scope rights (13) when accessing 'https://api.netatmo.com/api/gethomecoachsdata'
Thanks a lot for your help
@cgtobi : any idea why 6 minutes after start, the integration stop working ?
No, not yet. Could you please create a new app in the Netatmo dev portal and try with that?
Different behavior.
Sep 25 15:19:59 localhost hass[31842]: 2020-09-25 15:19:59,419 [31842] INFO homeassistant.helpers.entity_registry: Registered new sensor.netatmo entity: sensor.netatmo_darkstation_outdoor_battery_level
Sep 25 15:19:59 localhost hass[31842]: 2020-09-25 15:19:59,424 [31842] DEBUG homeassistant.components.netatmo.netatmo_entity_base: New client sensor.netatmo_darkstation_outdoor_battery_level
Sep 25 15:19:59 localhost hass[31842]: 2020-09-25 15:19:59,641 [31842] DEBUG homeassistant.components.netatmo.data_handler: No weather station available
Sep 25 15:19:59 localhost hass[31842]: 2020-09-25 15:19:59,647 [31842] DEBUG homeassistant.components.netatmo.data_handler: Data class HomeCoachData added
Sep 25 15:19:59 localhost hass[31842]: 2020-09-25 15:19:59,932 [31842] DEBUG homeassistant.components.netatmo.data_handler: Data class CameraData added
Sep 25 15:25:59 localhost hass[31842]: 2020-09-25 15:25:59,235 [31842] DEBUG homeassistant.components.netatmo.data_handler: No weather station available
Sep 25 15:32:59 localhost hass[31842]: 2020-09-25 15:32:59,047 [31842] DEBUG homeassistant.components.netatmo.data_handler: No weather station available
Please let’s take a step back and tell me a bit about your setup. What is HA running on? Which release? Do you use HACS?
home assistant core on a raspberry pi3
I use hacs but not for Netatmo integration
Now running 0.115.2 but the problem starts probably with 0.113.3
Sensors are updated !
So, is the problem solved now?
Yes ! Thanks !
