best to replace
{{ states.device.domain.attributes.attr }}
with
{{ state_attr("device.domain", "attr") }}
In Developer Tools -> Registry I see this:
Does âhelpers/condition.py (ERROR)â give a hint?
Does it mean that the problem is inside a condition in my yaml files, or maybe it could be a problem in some custom component?
what is the device that youâre after and what is the attribute name?
I donât know, I didnât understand what is causing the error, Iâm looking for help in finding it.
if you donât know which device you need info from, Iâm not sure anyone can helpâŚ
The error message occurs because your code is wrong and HA doesnât know what youâre trying to doâŚ
you probably have an automation or a template sensor somewhere with incorrect data OR one of your sensors is unavailable and therefore has no attributesâŚ
The error is going to be in a automation condition. So filter your search to all automation condition templates.
I did that, I will try again to see what I missed yesterdayâŚ
Itâs also going to be an automation that fires once a minute. So something thats based on sensor.time or a time_pattern trigger.
Also, itâs pointing to incorrect syntax in general. Itâs saying you are trying to access attributes from attributes. I.e. itâs implying youâre doing the equivalent of states.domain.object_id.attributes.attributes
I checked all my automation related to time, I will double check. Thanks also for the other suggestion.
Nothing.
I will give it another shot at home.
Isnât there any way to use the logger to understand where the problem is?
can you just post all your automations with a condition template?
I rechecked all my yaml files.
I found only 2 automation with a template condition, they are the 2 HACS automation:
- id: 'automation hacs_updates'
alias: Create a notification when there is updates pending in HACS
platform: state
entity_id: sensor.hacs
condition:
- condition: template
value_template: "{{ states(trigger.entity_id) != 'unknown'}}"
value_template: "{{ (states(trigger.entity_id) | float) != 0}}"
service: persistent_notification.create
data_template:
title: Updates pending in HACS
message: >-
{% for repo in state_attr(trigger.entity_id, 'repositories') %}
**{{ repo.display_name }}** _{{ repo["installed version"] }}_ -> _{{ repo["available version"] }}_
{% endfor %}
- id: 'automation hacs_new_repo'
alias: Create a notification when somethig is added to HACS
platform: event
event_type: hacs/repository
event_data:
action: registration
condition:
condition: template
value_template: "{{ trigger.event.data.repository is defined }}"
data_template:
title: New repository in HACS
message: >-
{% set repo = trigger.event.data.repository %}
{% set id = trigger.event.data.repository_id %}
[{{ repo }}](/hacs/repository/{{ id }})
was just added to HACS.
Then I have a couple of automation that in condition have a templated sensor:
- alias: Notifica che occorre aprire la finestra Alex&May
initial_state: 'on'
- platform: state
entity_id: input_boolean.altaumidita_alexmay
to: 'on'
condition:
- condition: numeric_state
entity_id: sensor.umidita_esterna
below: 85
- service: script.notifiche_muffa_telegram
data_template:
titolo: '**Aria Alex & May KO**'
messaggio: 'Il valore di umidità nella camera da letto di Alex & May è troppo elevato. Si consiglia di aprire la finestra per arieggiare.'
- service: script.notifiche_muffa_vocali
the above sensor is defined like this:
sensors:
umidita_esterna:
friendly_name: "UmiditĂ esterna"
unit_of_measurement: '%'
value_template: "{{(states('sensor.dark_sky_humidity'))|int}}"
I must be missing something⌠I understood that the problem must be in an automation that gets triggered every minute and that has a template in the condition, but I canât find an automation like that in my configuration.
I found it!!!
The template giving the problem was not in condition, it was in trigger of this automation:
- alias: telegram_chiudi_auto_sezionale
value_template: "{{ states('sensor.time') == ( states.input_datetime.orario_chiusura.attributes.timestamp | int + 900 ) | timestamp_custom('%H:%M', False) }}"
condition:
condition: and
conditions:
- condition: state
entity_id: binary_sensor.contatto_open_close_2
state: 'on'
- condition: state
entity_id: input_boolean.chiusura_automatica
state: 'on'
- service: notify.alex
message: Hai dimenticato di chiudere il BOX, lo sto chiudendo io per te.
title: '*Chiusura BOX in corso*'
- service: script.chiudi_sezionale
- service: telegram_bot.delete_message
data_template:
message_id: '{{ trigger.event.data.message.message_id }}'
chat_id: '{{ trigger.event.data.chat_id }}'
- service: media_player.volume_set
data_template:
entity_id: media_player.googlehomemini
volume_level: 0.8
- service: tts.google_say
data_template:
message: 'Ho chiuso il box in automatico'
language: 'it'
By commenting the automation, the error popping up every minute finally stopped.
Now I have to fix this row:
First, I have not clear when I have to use single or double quotes, but even changing them to single the result is the same, so thatâs not the problem.
Try evaluating the template a bit at a time in the template editor - that will help you find the error.
Iâm not sure, but maybe I fixed it, I must check if it works.
Recently I added a dropdown list with different hour values available for the automatic garage door closing, but I forgot to update the trigger, and since in winter I usually donât leave the garage door opened, I didnât notice that it was not working.
Now I changed
to
value_template: "{{ states('sensor.time') == ( states.input_select.orario_chiusura.state | int + 900 ) | timestamp_custom('%H:%M', False) }}"
The template editor shows value_template: âFalseâ, so it should be, FINALLY, ok.
Can I ask a little more help, even if itâs going a little OT?
{{states.input_select.orario_chiusura.state == states.sensor.time.state}}
is working ok in order to check if current time is equal to the time in the input_select field.
I need a second trigger 15 minutes later.
{{ ( states.input_select.orario_chiusura.state | int + 900 ) == states.sensor.time.state}}
is not working, while it was working when I was using the input_datetime showed in the previous post.
Can someone help me with the correct syntax?
