Hi all, any ideas why my morning weather announcement routine stopped working with error “Error rendering data template: UndefinedError: None has no element 0”?
Yes. See “Weather” under this list:
Lots of topics on here about it.
In future, please post code as text, not screenshots. See here:
Thanks for your reply. Sorry for posting the screenshot and not the code but I’m sure volunteers here supporting the full community are tired of hearing “sorry” and thank you"
I’ve replaced “forecast” with “weather.get_forecasts” but I get the same error.
Here’s my code:
service: notify.alexa_media_kitchen
metadata: {}
message: >-
{% set state = states('weather.openweathermap') %} {% set temperature =
state_attr('weather.openweathermap', 'temperature') %} {% set humidity =
state_attr('weather.openweathermap', 'humidity') %} {% set windspeed =
state_attr('weather.openweathermap', 'wind_speed') %} {% set rain =
state_attr('weather.openweathermap', 'weather.get_forecasts').0.precipitation_probability
%} {% if state == 'partlycloudy' %}
{% set state = 'Partly Cloudy' %}
{% endif %} Good Morning! It looks like today the weather will be {{state}},
with a temperature of {{temperature}} degrees, wind speed of {{windspeed}}
meters per second and a {{rain}}% chance of rain. Enjoy your day!
It’s not as simple as a rename. weather.get_forecasts
is a service not an attribute. If you need to work with the forecasts beyond simply using the integration’s weather card display, you’ll need to pull them in to a template sensor as described in the first example here, swapping weather.home
for weather.openweathermap
If you add the following code to that, you should get the entire forecast:
attributes:
forecast: "{{ hourly['weather.openweathermap'].forecast }}"
Then you’ll need to update your announcement to use the rainfall probability attribute from that sensor instead.
