Tried to do this, but get an error:
Ignoring typing: markers 'python_version < "3.5"' don't match your environment
Waiting of a new homeassistant release (fix included) is the easiest solution for all!
It looks like “pip install” uses python2 and you should use pip3 for python3:
pip3 install https://github.com/rytilahti/python-miio/archive/master.zip
Same issue:
python3 --version
Python 3.5.3
sudo pip3 install https://github.com/rytilahti/python-miio/archive/master.zip
Please describe your system. How did you install homeassistant? I assume you are using a python virtualenv and missed to enter the environment beforehand (f.e. source /srv/homeassistant/bin/active
I’m running hassbian on RPI3.
Even if I use source /srv/homeassistant/bin/activate
before the install, I get the same error:
pi@hassbian:~ $ source /srv/homeassistant/bin/activate
(homeassistant) pi@hassbian:~ $ sudo pip3 install https://github.com/rytilahti/p ython-miio/archive/master.zip
Collecting https://github.com/rytilahti/python-miio/archive/master.zip
Downloading https://github.com/rytilahti/python-miio/archive/master.zip (115kB )
100% |████████████████████████████████| 122kB 189kB/s
Requirement already satisfied (use --upgrade to upgrade): python-miio==0.3.4 f rom https://github.com/rytilahti/python-miio/archive/master.zip in /usr/local/li b/python3.5/dist-packages
Requirement already satisfied: android_backup in /usr/local/lib/python3.5/dist-p ackages (from python-miio==0.3.4)
Requirement already satisfied: appdirs in /usr/local/lib/python3.5/dist-packages (from python-miio==0.3.4)
Requirement already satisfied: attrs in /usr/local/lib/python3.5/dist-packages ( from python-miio==0.3.4)
Requirement already satisfied: click in /usr/local/lib/python3.5/dist-packages ( from python-miio==0.3.4)
Requirement already satisfied: construct>=2.9.23 in /usr/local/lib/python3.5/dis t-packages (from python-miio==0.3.4)
Requirement already satisfied: cryptography in /usr/local/lib/python3.5/dist-pac kages (from python-miio==0.3.4)
Requirement already satisfied: pretty_cron in /usr/local/lib/python3.5/dist-pack ages (from python-miio==0.3.4)
Requirement already satisfied: pytz in /usr/local/lib/python3.5/dist-packages (f rom python-miio==0.3.4)
Requirement already satisfied: zeroconf in /usr/local/lib/python3.5/dist-package s (from python-miio==0.3.4)
Requirement already satisfied: cffi>=1.7; platform_python_implementation != "PyP y" in /usr/local/lib/python3.5/dist-packages (from cryptography->python-miio==0. 3.4)
Requirement already satisfied: six>=1.4.1 in /usr/local/lib/python3.5/dist-packa ges (from cryptography->python-miio==0.3.4)
Requirement already satisfied: idna>=2.1 in /usr/local/lib/python3.5/dist-packag es (from cryptography->python-miio==0.3.4)
Requirement already satisfied: asn1crypto>=0.21.0 in /usr/local/lib/python3.5/di st-packages (from cryptography->python-miio==0.3.4)
Requirement already satisfied: enum-compat in /usr/local/lib/python3.5/dist-pack ages (from zeroconf->python-miio==0.3.4)
Requirement already satisfied: netifaces!=0.10.5 in /usr/local/lib/python3.5/dis t-packages (from zeroconf->python-miio==0.3.4)
Requirement already satisfied: pycparser in /usr/local/lib/python3.5/dist-packag es (from cffi>=1.7; platform_python_implementation != "PyPy"->cryptography->pyth on-miio==0.3.4)
Okay, if you are running hassbian you have to change the user first:
su - homeassistant
pip3 install -U https://github.com/rytilahti/python-miio/archive/master.zip
and enable the “upgrade”-Flag ("-U")
Thank you. It worked. Sorry, but I’m not an linux expert, Thank You for your help.
Tried that, not fixing the issue. Got the error
" Ignoring typing: markers ‘python_version < “3.5”’ don’t match your environment"
I am running hass on mac mini.
Thanks! Finally got the V2 machine working. V1 was working fine before. Odd.
I’ve been struggling with this error since upgrading to 0.62, thanks for the details on how to fix it.
Still not working here.
Running hass on an archlinux vm. Running latest builds as described here, have also tried various other combos of construct and miio but no joy. Perhaps I need to downgrade hass to 62.0?
[root@home ~]# pip3 show homeassistant | grep Version:
Version: 0.62.1
[root@home ~]# pip3 show construct | grep Version:
Version: 2.9.27
[root@home ~]# pip3 show python-miio | grep Version:
Version: 0.3.5
[root@home ~]# python3 --version
Python 3.6.4
Error while setting up platform xiaomi_miio
File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py", line 189, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
File "/usr/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
return fut.result()
File "/usr/lib/python3.6/asyncio/futures.py", line 243, in result
raise self._exception
File "/usr/lib/python3.6/asyncio/tasks.py", line 180, in _step
result = coro.send(None)
File "/usr/lib/python3.6/asyncio/coroutines.py", line 212, in coro
res = func(*args, **kw)
File "/usr/lib/python3.6/site-packages/homeassistant/components/switch/xiaomi_miio.py", line 52, in async_setup_platform
device_info = plug.info()
File "/root/.homeassistant/deps/lib/python3.6/site-packages/miio/device.py", line 271, in info
return DeviceInfo(self.send("miIO.info", []))
File "/root/.homeassistant/deps/lib/python3.6/site-packages/miio/device.py", line 216, in send
m = Message.build(msg, ctx)
TypeError: build() takes 2 positional arguments but 3 were given
Ok, so tried downgrade to homeassistant 0.62.0 … still no joy
Version: 0.62.0
Version: 0.3.4
Version: 2.8.22
According to this thread, the combo above should work, but it doesn’t
( although that thread does describe a slightly different error).
Updated to hass dev, with latest construct and python-miio - still broken.
Wondering if it’s a python 3.6 problem?
Nope. You are mixing things up! You’ve installed python-miio & construct multiple times. If you use “pip show” as root the path “/usr/lib/python3.6/site-packages/” is used. As you can see in your error message:
python-miio is used from “/root/.homeassistant/deps/lib/python3.6/site-packages”. Just try to check the version of python-miio directly:
cat /root/.homeassistant/deps/lib/python3.6/site-packages/miio/version.py
It return “0.3.4”, right? The dev branch of homeassistant is fixed now. Just update homeassistant. It will pull all required components automatically now.
Thanks for the help @syssi
You are correct in that i have been installing construct and python_miio multiple times. I have been using the commands
pip3 install construct==x.xx.x
etc
Each time these commands seem to uninstall the current version of the component, and install the requested one.
Are these commands not installing into the location that homeassistant is using? If not, how do I make them install to the correct location for homeassistant ? (sorry, still learning linux)
As per your request, I’ve checked the version inside the .homeassistant folder:
[root@home ~]# cat /root/.homeassistant/deps/lib/python3.6/site-packages/miio/version.py
# flake8: noqa
__version__ = "0.3.4"
I then upgraded homeassistant:
pip3 install --upgrade git+git://github.com/home-assistant/home-assistant.git@dev
However, cat /root/.homeassistant/deps/lib/python3.6/site-packages/miio/version.py still shows:
Current pip3 show outputs:
Version: 2.9.27
Version: 0.3.5
Version: 0.63.0.dev0
same problem on hassio 0.63
Yes for me too, still the same problem on 0.63
@Alessandro_Morrone @2xdehelft Do you use hassio?
https://github.com/home-assistant/hassio/issues/356
https://github.com/home-assistant/home-assistant/issues/12298
https://github.com/home-assistant/home-assistant/issues/12028
it’s a neverending story…
