Error updating Home Assistant Core 'HomeAssistantCore.update' blocked from execution, no host internet connection
I seem to have fixed the issue. I’ve now taken the radical step of unloading the module that supports my WiFi adapter, and to block it from loading.
I’ve just successfully executed the update of the Cloudflared module which used to always fail without employing the work-around mentioned here in this thread.
I had this problem - brand new HA Yellow POE with CM5 - installed from scratch with no restore
The troubleshooting says - make sure NTP is working (Bit unhelpful but I searched around for ntp config and found that my default just downloaded timesyncd.conf has no NTP= line so I added one
and rebooted
That seems to be working
Благодарю - отлично помогло!!!
Thanks a lot - helped a lot
