Collecting aiohttp==1.3.3 (from homeassistant)
Using cached aiohttp-1.3.3.tar.gz
Complete output from command python setup.py egg_info:
File "<string>", line 1, in <module>
File "/tmp/pip-build-kznc3i5x/aiohttp/setup.py", line 10, in <module>
from setuptools.command.test import test as TestCommand
File "<frozen importlib._bootstrap>", line 2237, in _find_and_load
File "<frozen importlib._bootstrap>", line 2226, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 1200, in _load_unlocked
File "<frozen importlib._bootstrap>", line 1129, in _exec
File "<frozen importlib._bootstrap>", line 1467, in exec_module
File "<frozen importlib._bootstrap>", line 1570, in get_code
File "<frozen importlib._bootstrap>", line 656, in _compile_bytecode
ValueError: bad marshal data (invalid reference)
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-build-kznc3i5x/aiohttp/
(homeassistant) homeassistant@hassbian:/home/pi $ pip install --upgrade --no-cache-dir aiohttp==1.3.3
Downloading aiohttp-1.3.3.tar.gz (526kB)
100% |████████████████████████████████| 532kB 1.0MB/s
File "/tmp/pip-build-jldjxuzd/aiohttp/setup.py", line 10, in <module>
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-build-jldjxuzd/aiohttp/
Thanks for the tips guys. Unfortunately I’m too limited in time to give the above a go. I’ll reinstall Hassbian as that may be a foolproof way to upgrade.
