Error when trying to run "ha snapshots new" over ssh
I had the same problem, and i finally found the solution.
The command line ha needs a token to work. To have the environment variable SUPERVISOR_TOKEN you need to call a script to set this variable.
This command is working (you should test it)
 ssh homeassistant "source /etc/profile.d/homeassistant.sh && ha core info"
