Please read the instructions for posting at the top of each forum and edit your post to correctly display the code. The forum editor doesn’t keep the sketch formatting without code tags which makes it unreadable. If you post your code in code tags, more forum members will read it.
managed to get it working, leaving the config in case anyone ever stumbles across this page facing the same issue:
esphome:
esp8266:
board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "xxx"
ota:
password: "xxx"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Relay-X16 Fallback Hotspot"
password: "xxx"
captive_portal:
web_server:
port: 80
i2c:
- id: i2c_1
scan: true
scl: GPIO5
sda: GPIO4
pcf8574:
- address: '0x27'
pcf8575: true
switch:
- platform: gpio
pin:
pcf8574: pcf8575_1
# Use pin number 0
number: 0
mode:
output: true
inverted: false
- platform: gpio
pin:
pcf8574: pcf8575_1
# Use pin number 1
number: 1
mode:
output: true
inverted: false
- platform: gpio
pin:
pcf8574: pcf8575_1
# Use pin number 2
number: 2
mode:
output: true
inverted: false
- platform: gpio
pin:
pcf8574: pcf8575_1
# Use pin number 3
number: 3
mode:
output: true
inverted: false
- platform: gpio
pin:
pcf8574: pcf8575_1
# Use pin number 4
number: 4
mode:
output: true
inverted: false
- platform: gpio
pin:
pcf8574: pcf8575_1
# Use pin number 5
number: 5
mode:
output: true
inverted: false
- platform: gpio
pin:
pcf8574: pcf8575_1
# Use pin number 6
number: 6
mode:
output: true
inverted: false
- platform: gpio
pin:
pcf8574: pcf8575_1
# Use pin number 7
number: 7
mode:
output: true
inverted: false
- platform: gpio
pin:
pcf8574: pcf8575_1
# Use pin number 8
number: 8
mode:
output: true
inverted: false
- platform: gpio
pin:
pcf8574: pcf8575_1
# Use pin number 9
number: 9
mode:
output: true
inverted: false
- platform: gpio
pin:
pcf8574: pcf8575_1
# Use pin number 10
number: 10
mode:
output: true
inverted: false
- platform: gpio
pin:
pcf8574: pcf8575_1
# Use pin number 11
number: 11
mode:
output: true
inverted: false
- platform: gpio
pin:
pcf8574: pcf8575_1
# Use pin number 12
number: 12
mode:
output: true
inverted: false
- platform: gpio
pin:
pcf8574: pcf8575_1
# Use pin number 13
number: 13
mode:
output: true
inverted: false
- platform: gpio
pin:
pcf8574: pcf8575_1
# Use pin number 14
number: 14
mode:
output: true
inverted: false
- platform: gpio
pin:
pcf8574: pcf8575_1
# Use pin number 15
number: 15
mode:
output: true
inverted: false
