Worst case I will just do restart on CRC error
I tried to capture smartAir2 LOG on pin 6 and 7 mentioned here Microsoft OneDrive - Access files anywhere. Create docs with free Office Online. and this
is what i got
using 38400
ROM Version: 0.3
Build ToolChain Version: gcc version 4.8.3 (Realtek ASDK-4.8.3p1 Build 2003)
Check boot type form eFuse
SPI Initial
Image1 length: 0x4a88, Image Addr: 0x10000bc8
Image1 Validate OK, Going jump to Image1
===== Enter Image 1 ====
load OLD fw 1
Flash Image2:Addr 0x85000, Len 299252, Load to SRAM 0x10006000
No Image3
Img2 Sign: RTKWin, InfaStart @ 0x10006079
===== Enter Image 2 ====
Haier Build Time: 2017/06/14- 9:50:38
Haier Build Author: haier_fenggq
Haier Build Host: haier_fenggq-PC
Haier Build ToolChain Version: IAR compiler
Haier Build Lib Version: v3.4c
Initializing WIFI ...
Start LOG SERVICE MODE
WIFI initialized
init_thread(58), Available heap 0xdd60
Hardware version:R_1.0.00
Software version:e_2.3.12
PLATFORM:UHOME_OVERSEAS_AC
ioctl[SIOCGIWESSID] ssid = NULL, not connected
RTL4268195]: dA[HAev_dL]: elaISR y, 681 h3: Dad bevieen ce sallotatecate idd!!!
0x00RTL8
195RTL8A[HA195AL]: [HALISR]: I 81 SR 5had habeend be allen aocatlloed!!cate!
d!!!
Period = 0x00007530
WdgScalar = 0x000007a4
WdgCunLimit = 0x00000008
[5043]: dev_resume, 90: Device state id 0x01
[5123]: [uart]tx1[cmd 0x61 len=13]
[5231]: [uart]rx [cmd 0x03 len=13]
[5264]: dev_handshake_handle_rsp, 933: Device state id 0x03
[5340]: [uart]tx1[cmd 0x70 len=11]
[5446]: [uart]rx [cmd 0x03 len=13]
[5489]: TypeID:00000000000000008080000000041410, EppVer:1.00, platform:UHOME_OVE RSEAS_AC, TYPE:2
[5514]: dev_handshake_handle_rsp, 983: Device state id 0x04
[5555]: [uart]tx1[cmd 0x01 len=13]
[5692]: [uart]rx [cmd 0x02 len=37]
[5778]: wifi_init,ENTER_WORK_MODE!
WIFI is already running[5793][[579Dwif6]: i_hawifndlei_ha_quendleue h_quandleue e suhandmcmdle [UAsumcR
md [UART_OK][3]
[6065]: connect to AP ssid[] key[] uplus-haier-ac-c935-v0
[6082][I]: Connect to [] with password [], channel [3] and encrypt [6]
Excute fast connect!
RTL8195A[Driver]: set ssid []
RTL8195A[Driver]: start auth to
RTL8195A[Driver]: auth success, start assoc
RTL8195A[Driver]: association success(res=26)
RTL8195A[Driver]: set pairwise key to hw: alg:4()
RTL8195A[Driver]: set group key to hw: alg:4() keyid:1
[7447][I]: Wifi connect successed after 1365ms!
IP address : 192.168.50.43[7967]: wifi_ip: 192.168.50.43
[7975]: wifi_mac 2C37C510C935
[7984][I]: DHCP succeed after 1902ms!
[7995]: AP Connect Check End
[8006]: wifi_handle_queue handle sumcmd [AP_CONNECTED][6]
[8047]: [uart]tx1[cmd 0xf7 len=15]
[8081]: Server Connect Check, 3min begin.
[8155]: [uart]rx [cmd 0x05 len=11]
[8212]: connect svr fd[3] to server 52.233.190.94:56808, host strlen 13
[8231]: mine 192.168.50.43:49153
[8240][I]: HaierUhome: peer_cn 52.233.190.94
[8394][I]: HaierUhome: SSL ciphersuite: TLS-RSA-WITH-AES-256-CBC-SHA256
[8413][I]: socketfd=3 info->ssl=0x10066110
[8479][I]: socketfd=3 info->ssl=0x10066110
[8500][I]: socketfd=3 info->ssl=0x10066110
[8582]: Server Connect Check End.
[8600]: wifi_handle_queue handle sumcmd [MASTER_SUCCEEDED][9]
[8676]: Server Connect Check, 3min begin.
[10764]: [uart]tx1[cmd 0x01 len=13]
[10901]: [uart]rx [cmd 0x02 len=37]
[11460]: connect svr fd[3] to server 52.233.190.94:56661, host strlen 13
[11479]: mine 192.168.50.43:49154
[11488][I]: HaierUhome: peer_cn 52.233.190.94
[11554][I]: Verify requested for (Depth 1):
[11566][I]: cert. version : 3
serial number : B0:33:7F:64:BA:F0:BB:94
issuer name : O=haier ubic, L=BeiJing, ST=BeiJing, C=CN, CN=gw.haier.net
subject name : O=haier ubic, L=BeiJing, ST=BeiJing, C=CN, CN=gw.haier.net
issued on : 2014-10-30 05:22:49
expires on : 2044-10-22 05:22:49
signed using : RSA with MD5
RSA key size : 1024 bits
basic constraints : CA=true
[11675][I]: This certificate has no flags
[11687][I]: Verify requested for (Depth 0):
[11700][I]: cert. version : 1
serial number : 03
subject name : C=CN, ST=BeiJing, O=haier ubic, OU=npt, CN=gw.haier.net
issued on : 2014-10-30 05:39:08
expires on : 2044-10-22 05:39:08
[11796][I]: This certificate has no flags
[11911][I]: HaierUhome: SSL ciphersuite: TLS-RSA-WITH-AES-256-CBC-SHA256
[11976]: Server Connect Check End.
[11994]: wifi_handle_queue handle sumcmd [SERVER_CONNECTED][10][12
010]: [uart]tx1[cmd 0xf7 len=15]
[12049][I]: socketfd=3 info->ssl=0x10066010
[12071][I]: socketfd=3 info->ssl=0x10066010
[12092][I]: socketfd=3 info->ssl=0x10066010
[12113]: uwt rx cmd[10006],con_index[8],[12fd[3123]]
[12136]: wifi_handle_queue handle sumcmd [VER_RPT_ACK][11]
[12151]: recv ver rpt ack , send keep alive to svr.
[12385][I]: socketfd=3 info->ssl=0x10066010
[12406][I]: socketfd=3 info->ssl=0x10066010
[12427]: uwt rx cmd[10016],con_index[8],fd[3]
[13167][I]: socketfd=3 info->ssl=0x10066010
[13188][I]: socketfd=3 info->ssl=0x10066010
[13209][I]: socketfd=3 info->ssl=0x10066010
[13230]: uwt rx cmd[10004],con_index[8],fd[3]
[16035]: [uart]tx1[cmd 0x01 len=13]
[16172]: [uart]rx [cmd 0x02 len=37]
[21231]: [uart]tx1[cmd 0x01 len=13]======================
[21367]: [uart]rx [cmd 0x02 len=37]
[21976]: [uart]tx1[cmd 0xf7 len=15]
[22085]: [uart]rx [cmd 0x05 len=11]
[26444]: [uart]tx1[cmd 0x01 len=13]
[26580]: [uart]rx [cmd 0x02 len=37]
[31639]: [uart]tx1[cmd 0x01 len=13]======================4.8.3p1 Build 2003)
[31775]: [uart]rx [cmd 0x02 len=37]
[32034]: [uart]tx1[cmd 0xf7 len=15]n 4.8.3 (Realtek ASDK-4.8.3p1 Build 2003)
[32144]J@NKJBDH
[36856]: [uart]tx1[cmd 0x01 len=13] 681 h3: Dad bevieen ce sallotatecate idd!!! type form eFuse
[36992]: [uart]rx [cmd 0x02 len=37]
[42051]: [uart]tx1[cmd 0xf7 len=15]
[42160]: [uart]rx [cmd 0x05 len=11]
[42269]: [uart]tx1[cmd 0x01 len=13]
[42404]: [uart]rx [cmd 0x02 len=37]
[47463]: [uart]tx1[cmd 0x01 len=13]
[47600]: [uart]rx [cmd 0x02 len=37]
[52059]: [uart]tx1[cmd 0xf7 len=15]
[52169]: [uart]rx [cmd 0x05 len=11]
[52678]: [uart]tx1[cmd 0x01 len=13]
[52815]: [uart]rx [cmd 0x02 len=37]
[57874]: [uart]tx1[cmd 0x01 len=13]
[58010]: [uart]rx [cmd 0x02 len=37]
[62119]: [uart]tx1[cmd 0xf7 len=15]
[62227]: [uart]rx [cmd 0x05 len=11]
[63136]: [uart]tx1[cmd 0x01 len=13]
[63272]: [uart]rx [cmd 0x02 len=37]
[67212]: period send keep alive to svr.
[67246][I]: socketfd=3 info->ssl=0x10066010
[67268][I]: socketfd=3 info->ssl=0x10066010
[67289]: uwt rx cmd[10016],con_index[8],fd[3]
[68331]: [uart]tx1[cmd 0x01 len=13]
[68468]: [uart]rx [cmd 0x02 len=37]
[72127]: [uart]tx1[cmd 0xf7 len=15]
[72235]: [uart]rx [cmd 0x05 len=11]
[73544]: [uart]tx1[cmd 0x01 len=13]
[73681]: [uart]rx [cmd 0x02 len=37]
[78740]: [uart]tx1[cmd 0x01 len=13]
[78876]: [uart]rx [cmd 0x02 len=37]
[82185]: [uart]tx1[cmd 0xf7 len=15]
[82294]: [uart]rx [cmd 0x05 len=11]
[83953]: [uart]tx1[cmd 0x01 len=13]
[84089]: [uart]rx [cmd 0x02 len=37]
[89198]: [uart]tx1[cmd 0x01 len=13]
[89335]: [uart]rx [cmd 0x02 len=37]
[92194]: [uart]tx1[cmd 0xf7 len=15]
[92302]: [uart]rx [cmd 0x05 len=11]
[94411]: [uart]tx1[cmd 0x01 len=13]
[94547]: [uart]rx [cmd 0x02 len=37]
[99606]: [uart]tx1[cmd 0x01 len=13]
[99742]: [uart]rx [cmd 0x02 len=37]
[102201]: [uart]tx1[cmd 0xf7 len=15]
[102311]: [uart]rx [cmd 0x05 len=11]
[104820]: [uart]tx1[cmd 0x01 len=13]
[104956]: [uart]rx [cmd 0x02 len=37]
[110065]: [uart]tx1[cmd 0x01 len=13]
[110201]: [uart]rx [cmd 0x02 len=37]
[112260]: [uart]tx1[cmd 0xf7 len=15]
[112369]: [uart]rx [cmd 0x05 len=11]
[115278]: [uart]tx1[cmd 0x01 len=13]
[115414]: [uart]rx [cmd 0x02 len=37]
[120473]: [uart]tx1[cmd 0x01 len=13]
[120609]: [uart]rx [cmd 0x02 len=37]
[122252]: period send keep alive to svr.
[122268]: [uart]tx1[cmd 0xf7 len=15]
[122290][I]: socketfd=3 info->ssl=0x10066010
[122311][I]: socketfd=3 info->ssl=0x10066010
[122332]: uwt rx cmd[10016],con_index[8],fd[3]
[122378]: [uart]rx [cmd 0x05 len=11]
[125687]: [uart]tx1[cmd 0x01 len=13]
[125824]: [uart]rx [cmd 0x02 len=37]
[130883]: [uart]tx1[cmd 0x01 len=13]
I will need to do the reset again as I got some weird data
d!!!
hmmm pretty much same
ROM Version: 0.3
SPI Initial
load OLD fw 1
No Image3
WIFI initialized
RTL426]819: de5A[Hv_deAL]:lay ISR, 63 81 : Dehad vicbeene st allate ocatid ed!!0x00!
RTL8RTL195A8195[HALA[HA]: IL]:SR 8 ISR1 ha 5 hd bead en abeenlloc allatedoca!!!
ted!!!
Period = 0x00007530
[5122]: [uart]tx1[cmd 0x61 len=13]
[5489]: TypeID:00000000000000008080000000041410, EppVer:1.00, platform:UHOME_OVERSEAS_AC, TYPE:2
md [UART_OK][3]
RTL8195A[Driver]: start auth to 24:4b:fe:72:07:78
RTL8195A[Driver]: association success(res=36)
[7440][I]: Wifi connect successed after 1358ms!
IP address : 192.168.50.43[7968]: wifi_ip: 192.168.50.43
[7976]: wifi_mac 2C37C510C935
[7985][I]: DHCP succeed after 1903ms!
[7996]: AP Connect Check End
[8019]: wifi_handle_queue handle sumcmd [AP_CONNECTED][6]
[8041]: [uart]tx1[cmd 0xf7 len=15]
[8071]: connect svr fd[3] to server 52.233.190.94:56808, host strlen 13
[8090]: mine [8091 Co4]: nnecSert Chver eck,Conn 3miectn Ch[810er_c6][In 5]: H2.23aier3.19Uhom0.9e: peer_cn 52.233.190.94
[8151]: [uart]rx [cmd 0x05 len=11]
[8267][I]: HaierUhome: SSL ciphersuite: TLS-RSA-WITH-AES-256-CBC-SHA256
[8286][I]: socketfd=3 info->ssl=0x10066090
[8365][I]: socketfd=3 info->ssl=0x10066090
[8386][I]: socketfd=3 info->ssl=0x10066090
[8465]: Server Connect Check End.
[8483]: wifi_handle_queue handle sumcmd [MASTER_SUCCEEDED][9]
[8559]: Server Connect Check, 3min begin.
[10765]: [uart]tx1[cmd 0x01 len=13]
[11320]: connect svr fd[3] to server 52.233.190.94:56661, host strlen 13
[11339]: mine 192.168.50.43:49154
[11348][I]: HaierUhome: peer_cn 52.233.190.94
[11413][I]: Verify requested for (Depth 1):
[11425][I]: cert. version : 3
[11534][I]: This certificate has no flags
[11547][I]: Verify requested for (Depth 0):
[11560][I]: cert. version : 1
serial number : 03
[11655][I]: This certificate has no flags
[11771][I]: HaierUhome: SSL ciphersuite: TLS-RSA-WITH-AES-256-CBC-SHA256
[11799]: wifi_handle_queue handle sumcmd [S[118ERVE10]:R_CO [uaNNErt]tCTEDx1[c][10md 0]
xf7 len=15]
[11875][I]: socketfd=3 info->ssl=0x10002678
[11897][I]: socketfd=3 info->ssl=0x10002678
928]18][I]: socketfd=3 info->ssl=0x10002[11678
[11941]: uwt rx cmd[10006],con_index[8],fd[3]
[11953]: Server Connect Check End.
[11972]: wifi_handle_queue handle sumcmd [VER_RPT_ACK][11]
[11987]: recv ver rpt ack , send keep alive to svr.
[12151][I]: socketfd=3 info->ssl=0x10002678
[12172][I]: socketfd=3 info->ssl=0x10002678
[12193]: uwt rx cmd[10016],con_index[8],fd[3]
[13145][I]: socketfd=3 info->ssl=0x10002678
[13166][I]: socketfd=3 info->ssl=0x10002678
[13187][I]: socketfd=3 info->ssl=0x10002678
[13208]: uwt rx cmd[10004],con_index[8],fd[3]
[16039]: [uart]tx1[cmd 0x01 len=13]
[16175]: [uart]rx [cmd 0x02 len=37]
[21234]: [uart]tx1[cmd 0x01 len=13]
[21371]: [uart]rx [cmd 0x02 len=37]
[21830]: [uart]tx1[cmd 0xf7 len=15]
[21938]: [uart]rx [cmd 0x05 len=11]
[26447]: [uart]tx1[cmd 0x01 len=13]
[26583]: [uart]rx [cmd 0x02 len=37]
[31642]: [uart]tx1[cmd 0x01 len=13]
[31779]: [uart]rx [cmd 0x02 len=37]
[31888]: [uart]tx1[cmd 0xf7 len=15]
[31996]: [uart]rx [cmd 0x05 len=11]
[36855]: [uart]tx1[cmd 0x01 len=13]
[41901]: [uart]tx1[cmd 0xf7 len=15]
[42010]: [uart]rx [cmd 0x05 len=11]
[42119]: [uart]tx1[cmd 0x01 len=13]
[42254]: [uart]rx [cmd 0x02 len=37]
not much info in it,
UHOME_OVERSEAS_AC gives zero results when searching for it
maybe it is possible to send some command to it to log more like actual rx tx commands etc.
8090]: mine [8091 Co4]: nnecSert weird that it is Co … 4]: … nnect
maybe i still have wrong baudrate?
