thank you for your reply.
edit: I have only h0n devices with esphome and if this differs from the sample above, your example would be very nice. thanks
No problem, here is my h0n yaml with mqtt.
It also includes “display, beeper, cleaning” options of Haier AC as well. And “FanActive” entity needed for correct Homekit intagration.
Substitutions are bit mixed in my example because i’m running one esp32s2 for two uart devices at once.
substitutions:
esp_name: haier-presence-childroom # change this
esp_friendly: "Haier Presence Childroom" # change this
haier_name: "AC Childroom" # change this
haier_id: ac_childroom # change this
haier_uart: haier_uart
haier_topic_prefix: "haier/hon"
ipstatic: !!!YOUR_STATIC_IP_ADRESS!!! # change this
esphome:
friendly_name: ${esp_friendly}
esp32:
board: lolin_s2_mini
variant: esp32s2
logger:
level: WARN
baud_rate: 0 #Important. You can't use serial port
# hardware_uart: UART0
debug:
update_interval: 30s
wifi:
ssid: !secret wifi_ssid
reboot_timeout: 10min
#important, otherwise the IP could change and then the entity is unavailable from home assistant.
manual_ip:
static_ip: ${ipstatic}
gateway: !!!YOUR_GATEWAY!!!
subnet: 255.255.255.0
ap:
ssid: ${esp_friendly}
password: !secret ap_wifi_pass
captive_portal:
# Enable Home Assistant API
api:
encryption:
key: !secret api_key
ota:
# Web config
web_server:
include_internal: true
ota: false
mqtt:
# Haier
broker: !secret ha_mqtt_ip
username: !secret ha_mqtt_user
password: !secret ha_mqtt_pass
discovery: false
client_id: ${esp_name} # What you want to call your device in your MQTT broker
topic_prefix: ${haier_topic_prefix}/${haier_id}
uart:
# Haier
- id: ${haier_uart}
baud_rate: 9600
tx_pin: GPIO39
rx_pin: GPIO40
text_sensor:
# Haier
name: "AC cleaning status"
icon: mdi:spray-bottle
lambda: return id(${haier_id}).get_cleaning_status_text();
state_topic: ${haier_topic_prefix}/${haier_id}/self_clean/state
binary_sensor:
# Haier
name: "AC Fan Active"
icon: mdi:fan-alert
lambda: |-
if (id(${haier_id}).fan_mode != 2 ) {
return true;
} else {
return false;
device_class: power
state_topic: ${haier_topic_prefix}/${haier_id}/fan/active
switch:
# Haier
restore_mode: RESTORE_DEFAULT_ON
icon: mdi:led-on
entity_category: config
lambda: |-
return id(${haier_id}).get_display_state();
turn_on_action:
climate.haier.display_on: ${haier_id}
turn_off_action:
climate.haier.display_off: ${haier_id}
state_topic: ${haier_topic_prefix}/${haier_id}/display/state
command_topic: ${haier_topic_prefix}/${haier_id}/display/set
restore_mode: RESTORE_DEFAULT_OFF
icon: mdi:volume-high
lambda: |-
return id(${haier_id}).get_beeper_state();
turn_on_action:
climate.haier.beeper_on: ${haier_id}
turn_off_action:
climate.haier.beeper_off: ${haier_id}
state_topic: ${haier_topic_prefix}/${haier_id}/beeper/state
command_topic: ${haier_topic_prefix}/${haier_id}/beeper/set
name: "AC health mode"
icon: mdi:leaf
lambda: |-
return id(${haier_id}).get_health_mode();
turn_on_action:
climate.haier.health_on: ${haier_id}
turn_off_action:
climate.haier.health_off: ${haier_id}
state_topic: ${haier_topic_prefix}/${haier_id}/health_mode/state
command_topic: ${haier_topic_prefix}/${haier_id}/health_mode/set
# - platform: template
# id: ${device_id}_climate_power
# name: ${device_id} power on/off
# icon: mdi:power
# lambda: |-
# return id(${device_id}).mode != CLIMATE_MODE_OFF;
# turn_on_action:
# climate.haier.power_on: ${device_id}
# turn_off_action:
# climate.haier.power_off: ${device_id}
# state_topic: ${topic_prefix}/${device_name}/power/state
# command_topic: ${topic_prefix}/${device_name}/power/set
button:
# Haier
name: "AC start 56°C steri-cleaning"
on_press:
- climate.haier.start_steri_cleaning: ${haier_id}
command_topic: ${haier_topic_prefix}/${haier_id}/self_clean/set
name: "AC start self cleaning"
on_press:
- climate.haier.start_self_cleaning: ${haier_id}
##### Haier Climate hOn CONFIG
climate:
# Haier
- platform: haier
uart_id: ${haier_uart}
protocol: hOn
wifi_signal: true
beeper: false
supported_modes: # Optional, can be used to disable some modes if you don't need them
- 'OFF'
- HEAT_COOL
- COOL
- HEAT
- DRY
- FAN_ONLY
supported_swing_modes: # Optional, can be used to disable some swing modes if your AC does not support it
- 'OFF'
- VERTICAL
- HORIZONTAL
- BOTH
visual: # Optional, you can use it to limit min and max temperatures in UI (not working for remote!)
min_temperature: 16 °C
max_temperature: 30 °C
temperature_step: 1 °C
# MQTT topics
current_temperature_state_topic: ${haier_topic_prefix}/${haier_id}/cur_temp
mode_state_topic: ${haier_topic_prefix}/${haier_id}/mode/state
mode_command_topic: ${haier_topic_prefix}/${haier_id}/mode/set
fan_mode_state_topic: ${haier_topic_prefix}/${haier_id}/fan/state
fan_mode_command_topic: ${haier_topic_prefix}/${haier_id}/fan/set
target_temperature_state_topic: ${haier_topic_prefix}/${haier_id}/temp/state
target_temperature_command_topic: ${haier_topic_prefix}/${haier_id}/temp/set
swing_mode_state_topic: ${haier_topic_prefix}/${haier_id}/swing/state
swing_mode_command_topic: ${haier_topic_prefix}/${haier_id}/swing/set
preset_state_topic: ${haier_topic_prefix}/${haier_id}/preset/state
preset_command_topic: ${haier_topic_prefix}/${haier_id}/preset/set
@mot
First of all, keep in mind that opening AC will require you to have at least basic knowledge about electronics and promotions. Also, all you doing is at your own risk.
If you keep reading after warning and are willing to take risks you will need to disconnect power from your AC internal block. Open a panel from the photo I showed you (it should be just 1 screw) and very carefully pull the board behind it. You should find the connector which has +5v GND TXD and RXD pins. Usually, it is marked as CN34. It should be like this:
It is possible in your case that it is not available, in this case, you probably can’t control your AC. If you find it and it looks like mine (and that is what I expect) you can use a 4-pin connector like this: https://www.aliexpress.com/item/1005003374938897.html
to make a wire to connect your ESP
And like @OwlBawl said Wemos D1 mini is enough if you using it just for AC.
If it helps i can add that the full name of 4 pin connector used on board is Molex mini-SPOX (4 pin) code MX-5264-04 + 4 pins for welding code MX-5263-PBTL.
But if you can find and buy it with wires already like @paveldn proposed with Ali link it can be much easier (5264 terminal 4 pin with cables 150mm+ on Aliexpress)
on @paveldn github there is manual for stock esp32 firmware change if you are sure in your abilities and don’t afraid of bricking it.
Another way is to change it with wemos like board and leave this one as is for some cases.
@Hombard I agree with @OwlBawl Better keep your original module and use Wemos. I done a lot of experiments with my original Haier module and never had any problems. But some of new AC models have flash encrypted. If you try to use this module there is good chance you will brick it. So it you will decide to try first make a full flash backup. But if you will use Wemos you always can revert everything back.
You want to cut off the pin connector on the dongle side? Or you want to find the another cable that will fit this connector ? Can’t understand the request.
I want to cut the cables to connect the Wemos D1, at the same time, I would like to leave the possibility of connecting the original ESP32 in the future. Would I then have to extend the cables somehow?
that’s really strange question. If you cut it and then restore it (welding or smth) would this cable lose it’s cableness? the only thing is to correctly restore it.
substitutions:
device_name: Haier AC
device_id: haier_climate
uart_id: ac_port
send_wifi: "true"
api:
encryption:
key: "HIDDEN"
esphome:
name_add_mac_suffix: true
esp8266:
board: esp12e
wifi:
manual_ip:
# Set this to the IP of the ESP
static_ip: HIDDEN
# Set this to the IP address of the router. Often ends with .1
gateway: HIDDEN
# The subnet of the network. 255.255.255.0 works for most home networks.
ap:
ssid: "HIDDEN"
password: "HIDDEN"
uart:
- id: ${uart_id}
baud_rate: 9600
tx_pin: 1
rx_pin: 3
logger:
level: DEBUG
baud_rate: 0
web_server:
packages:
remote_package:
url: https://github.com/paveldn/haier-esphome
ref: master
files:
- .haier-smartair2-base.yaml
external_components:
- source: github://esphome/esphome@dev
components: [ haier ]
@homeassist2,
From what I see from your logs your AC should speak hOn, try to use: .haier-hon-base.yaml instead of .haier-smartair2-base.yaml it should help.
Hi all, i would ask if someone try to use ESP32 usb dongle development board https://vi.aliexpress.com/item/1005006123996200.html to flash there esphome. I found it on Aliexpress. No soldering, just plug and play. What do you think?
Do you want to use it with Haier AC? Just flashing ESPHome should be no problem at all but I doubt it would be possible to use with Haier AC. The thing is that Haier just uses a USB connector for the UART connection. So dev boards that use USB will not work.
