Looks like you’re in a boot loop. I’d disconnect any external wires other than power and see if it continues. If it does, then try installing a clean binary image to the device. If you post your code, we may be able to identify an issue there. Good luck.
Just ignore it because: 1) our display do not need this and 2) it isn’t wired anywhere.
Thank you all for your efforts in providing so many infos.
I think I miss something obvious but… When trying to install the yaml codes you have shared here over esphome in home assistant I get following error. I get this error with different yaml files.
What could be wrong? I am sure it something obvious but searching around for infos didn’t help me find sth…
Thx for the help
The error I get
INFO ESPHome 2023.12.9
INFO Reading configuration /config/esphome/esphome-web-1433f8.yaml...
WARNING GPIO2 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
INFO Generating C++ source...
File "/usr/local/bin/esphome", line 33, in <module>
sys.exit(load_entry_point('esphome', 'console_scripts', 'esphome')())
File "/esphome/esphome/__main__.py", line 1041, in main
return run_esphome(sys.argv)
File "/esphome/esphome/__main__.py", line 1028, in run_esphome
rc = POST_CONFIG_ACTIONS[args.command](args, config)
File "/esphome/esphome/__main__.py", line 407, in command_compile
exit_code = write_cpp(config)
File "/esphome/esphome/__main__.py", line 192, in write_cpp
generate_cpp_contents(config)
File "/esphome/esphome/__main__.py", line 204, in generate_cpp_contents
CORE.flush_tasks()
File "/esphome/esphome/core/__init__.py", line 679, in flush_tasks
self.event_loop.flush_tasks()
File "/esphome/esphome/coroutine.py", line 246, in flush_tasks
next(task.iterator)
File "/esphome/esphome/__main__.py", line 184, in wrapped
await coro(conf)
File "/data/external_components/1ffebe30/esphome/components/gc9a01/display.py", line 77, in to_code
await setup_gc9a01(var, config)
File "/data/external_components/1ffebe30/esphome/components/gc9a01/display.py", line 56, in setup_gc9a01
await display.register_display(var, config)
File "/esphome/esphome/components/display/__init__.py", line 119, in register_display
await cg.register_component(var, config)
File "/esphome/esphome/cpp_helpers.py", line 56, in register_component
raise ValueError(
ValueError: Component ID watchface was not declared to inherit from Component, or was registered twice. Please create a bug report with your configuration.
Example file from @zagnuts
substitutions:
devicename: wallwatch01
friendname: WallWatch01
board: esp32-c3-devkitm-1
repin: GPIO1
dcpin: GPIO2
bkpin: GPIO3
clpin: GPIO6
mopin: GPIO7
cspin: GPIO10
esphome:
friendly_name: $friendname
esp32:
board: $board
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "bmNSHIjcdzxFCivO4nUM55dDA4V4iajEM9+tO3o1S5k="
ota:
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esphome-Web-1433F8"
password: "Mc5mSHkTZf8p"
captive_portal:
time:
- platform: homeassistant
timezone: "Australia/Melbourne"
# Test - see if the thing picks up BLE info
#esp32_ble_tracker:
#nope - locks up
#SpokeTooSoon - actually does work, kinda. Slows down the startup significantly then claims to scan but nothing is found
#Either is not supported or antenna is really weak
- platform: uptime
- platform: wifi_signal
name: "$devicename WiFi Signal"
update_interval: 60s
entity_id: sensor.gw1000_v1_7_6_outdoor_temperature
external_components:
# - source: github://pr#3625
# components: [ gc9a01 ]
- source: github://4cello/esphome@gc9a01
components: ["gc9a01"]
# Arduino code shows screen is a GC9A01 with CST816D touch screen
spi:
mosi_pin: $mopin
clk_pin: $clpin
#mosi = Master Out Slave In
#miso = Master In Slave Out or fermented bean paste. In this case, most likely the former rather than the latter. Doesn't matter as not used.
# Need to turn on backlight as by default is not on
output:
- platform: ledc
pin: $bkpin
light:
- platform: monochromatic
output: gpio_3_backlight_pwm
name: "Display Backlight"
restore_mode: ALWAYS_ON
font:
- file: 'gfonts://Roboto'
color:
- id: my_red
red: 100%
green: 3%
blue: 5%
- id: my_green
red: 3%
green: 100%
blue: 5%
- id: my_blue
red: 3%
green: 5%
blue: 100%
display:
# - platform: ili9xxx
# model: gc9a01
# Above is for when or if this is merged into the ili9xxx platform
- platform: gc9a01
reset_pin: $repin
cs_pin: $cspin
dc_pin: $dcpin
# Rotate the screen so usb socket is pointing down
rotation: 90
# Print the date on one line in blue
# Print the current time on the next line, but in a bigger font but default white
# Print the outside temperature in green
# Surround the lot by a red circle with centre at 120, 120 and a radius of 115 because why not
lambda: |-
it.strftime(120,80, id(font_16), id(my_blue), TextAlign::CENTER, "%A %b %d", id(esptime).now());
it.strftime(120,120, id(font_32), TextAlign::CENTER, "%I:%M %p", id(esptime).now());
it.printf(120, 170, id(font_32), id(my_green), TextAlign::CENTER, "Now: %.1f°", id(outdoor_temperature).state);
it.circle(120, 120, 115, id(my_red));
There have been a few changes to HA & esphome since I last posted my code, and these can break things - in particular if you are living on the edge (so to speak) with a device that isn’t officially supported yet so is relying upon external libraries that aren’t necessarily updated as regularly.
I haven’t recompiled my code recently, but noticed above some suggestions on changes to address issues that I’d try first. eg:
- source: github://bearpawmaxim/esphome@pr3625fix
- source: github://GadgetFactory/[email protected]
FWIW Compiled and tested on esphome 2023.12.9 and HA 2024.1.6 just then.
Also I’d recommend not using any code word for word as mine, for example, refers to sensors that you almost certainly don’t have in your home! Basically yes use it as a template but cut out the stuff you don’t need and then slowly add things in - potentially using my code (and others who have uploaded their versions) to help you adapt yours to suite your requirements. Have fun!
Thank you very much for the quick reply.
Just googled a little bit more with the infos you provided and yes as you say there are also similar reports using other displays regarding the external_components part.
You are right, will proceed the way you proposed adding stuff slowly and share my progress in a repo.
Thx again for your efforts
This is what I use, no issues:
display:
- platform: gc9a01
eight_bit_color: false
#reset_pin: GPIO1
cs_pin: GPIO10
dc_pin: GPIO2
update_interval: 50ms
rotation: 270
Great works, thanks !
I successfully installed the stuff on my freshly received unit.
Reactivity is not as I would like on taps (the heater/ac/off toggle text on display for example sees some lags to be reflected on screen) - but maybe there’s a page refresh period to be set somewhere ?
… but at least, the display of HA sourced data works fine
Need to find out how a single press can toggle a script or automation on HA now.
Matt
The screen refreshes pretty quickly so suspect it’s not that. Keep in mind that any HA data shown on the screen needs to be pulled - not pushed - by the device. You can try reducing the update_interval for the sensor and see if that helps. Currently I set it to one second, so maybe initially try 500ms - just be aware that I have seen issues reported with sub second update_interval settings. Just thought - maybe can add code to force an update on changes… hmmm…
That’s easy. A little Rube Goldberg, but easy. You just have the device change a sensor state, and then have an automation monitor that and perform an action if the sensor value changes. For example, I have a sensor for my HVAC vents. With the touch screen I toggle a sensor between 1 and 0 to indicate on or off. I then use an automation to monitor that sensor state, and when it changes between 0 to 1 it opens or closes the vent. If you go to my very first post you will see a link to my HVAC project (that originally started this quest) with example code. It’s also in my ‘solved’ post #72.
You’re right. Changing the heater setting directly on HA interface make things more reactive from display side. So it seems that it’s the push (updated value to HA after tap) / pull (updated value from HA) thing that creates this delay.
The UI slowness feeling seems more to come from short press that does seem not all the time well detected, rather than the display refresh itself (long presses are not much of an issue)
So obvious ! I was trying to get too fast by direct execution, but definitely, state check is the way to go, thanks !
Yep. If you watch the actual state of something as you tap the device screen, you will see it changes almost instantly - the delay is the time it takes for the device to pull the new sensor state back down to display it. Unless someone beats me to it, I’ll see if I can add in a secondary ‘pull’ right after a tap. Could then increase the default update_intervals to maybe 60 seconds or more… saving load on the HA server and juice if the device is battery powered.
You can add an on_value trigger to whatever HA entity you’re monitoring, and it will trigger the refresh. I’ve added these to anything I’m interested in seeing - I add a condition so it’s only refreshing when it’s actually being displayed, but it updates immediately whenever the value changes in HA there is no delay
name: "Dimmer Light Brightness"
entity_id: light.great_room_dimmer_4
attribute: brightness
on_value:
- if:
condition:
- display.is_displaying_page: FirstPage
then:
- globals.set:
value: !lambda 'return map(x, 0, 254, 0, 100);'
- component.update: my_lcd
Ah yes - that may do the trick. Thanks!
I should point out for clarity that the relevant section is
Where my_lcd is the id of your display
Ah. I had a minor epiphany. The issue was the device itself was updating the screen after any change, but often that change on the HA side was slower than the screen. What that means is you would for example change the temperature on the device screen, home assistant would almost immediately update the remote sensor temperature setting but that change would happen a few milliseconds after the screen on the device had already updated so it would not change on the screen until the next time the screen updated a few seconds later. The solution is simply to add a small delay after the initial command before forcing a screen refresh. I’ve used 0.5 seconds which seems to be fine, but shorter would probably work as well.
eg:
- if:
condition:
and:
- text_sensor.state:
state: 'SWIPE DOWN'
- display.is_displaying_page: page1
then:
- logger.log: "Swiped down on page1"
- number.increment: thermostat_adjust
- delay: 0.5s
- component.update: watchface
I have updated my example code here
The improvements include:
- The screen refresh tweak noted above
- Changed the external components to allow for “breaking changes” to esphome core
- Some notes to why I’ve changed to using "long press’ to toggle things (the sensitivity on the device seems to vary, but longer actions like swiping seem pretty reliable)
- Added in an info screen
- Added an example for turning the screen on/off using the single click
Cheers
See my note above - the issue was the screen was too quick for HA. Just needed to put a delay in there.
Wow ! The latest update is a user experience game changer ! Thanks !
I love this little device - so many possible things with it !
Thanks & I know! The aim is to try to make it as user friendly as possible.
FWIW I just added some code in my example for a screensaver - basically after (say) ten minutes of inactivity the screen will blank out. The time is set in the substitutions section at the top of the example code. Touching/swiping the screen wakes it again. Saves battery, screen burn in etc, but more importantly it is a lot better in (for example) bedrooms where you don’t want the thing glowing all night like an evil eye. Another option (which I have tested) is using a separate motion sensor combined with an automation but I suspect this is a good alternative.
Oh - note that the screensaver script only becomes active after the first touch. If you want the screen to be off when the device first starts (for example after initially testing it), then just change the line that says “restore_mode: ALWAYS_ON” to “restore_mode: ALWAYS_OFF”. Then if the house power goes out & comes back on again, or after updating their firmware, all the controllers don’t stay permanently on until you go around and touch them all… I have added this to the substitutions list in my example code…
Quick question - have you (or anyone else) connected the battery directly up to the JST socket or are you just using the USB port? I’m trying to power the things through the JST socket and they just sit there laughing silently at me with scorn & derision. My power supply happily powers other things but not these.
I do note that according to the diagram:
from above, positive is the right hand pin furthest away from the USB socket, which when I connect my JST cable it makes it black just to confuse things slightly - although of course there is no real standard so it’s not too unusual. With it powered with USB it is showing DC coming out those wires with that top right pin being positive, so that’s… positive I guess. I’ve tried three so far with the same result, so it’s unlikely to be a hardware fault as such. Anyhow, any clues before I start going neanderthal on one of them on the bench? I tried a LiPo battery, and two AA batteries without luck.
