Not working, that so strange, it’s connecting only when trying flash through esphome.
If I flash with Arduino, it’s connecting instantly .
Maybe I need to configure something in my router for esphome? I’m also use duckdns
The log, post the log!
I’m flashing using espflasher and there is no log , I can attached the log when I compile the yaml file
It will still be logging to serial. But if you used esphome to flash this would be simpler.
Do you mean esphomeflahser?
