Esp32 cam ov2640
good evening I have a problem with an esp32 cam. the cam is an ov2640 module and the esp32-s but I can’t see anything if it hasn’t commanded the led. Does anyone have this cam module and can you give me an example of code?
Thank
Have you tried one of these?
ESP32 Camera Component — ESPHome
i have tried all the sample templates but none work
You don’t give much any information about which module that could be :man_shrugging:
So you are aware that there is a lot of different modules :thinking:
Maybe start reading here :point_down:
And then try to ask a good question with as much useful information you can deliver :ok_hand:
mine was just a question, I know very well that it is not a help desk. I have tried all the examples but none work I can only control the flash I have looked at there are many cam modules and all of the examples are different from mine. now I have ordered other modules when they arrive I do other tests. Thank you
Hi ,
I have the ov2640 Module in Use.
This is my yaml configuration:
esphome:
  friendly_name: espCam-Test1
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
  level: VERBOSE
  tx_buffer_size: 256
# Enable Home Assistant API
api:
  encryption:
    key: "xxx="
  services:  # change camera parameters on-the-fly
  - service: camera_set_param
    variables:
      value: int
    then:
      - lambda:
          bool state_return = false;
          if (("contrast" == name) && (value >= -2) && (value <= 2)) { id(espcam).set_contrast(value); state_return = true; }
          if (("brightness" == name) && (value >= -2) && (value <= 2)) { id(espcam).set_brightness(value); state_return = true; }
          if (("saturation" == name) && (value >= -2) && (value <= 2)) { id(espcam).set_saturation(value); state_return = true; }
          if (("special_effect" == name) && (value >= 0U) && (value <= 6U)) { id(espcam).set_special_effect((esphome::esp32_camera::ESP32SpecialEffect)value); state_return = true; }
          if (("aec_mode" == name) && (value >= 0U) && (value <= 1U)) { id(espcam).set_aec_mode((esphome::esp32_camera::ESP32GainControlMode)value); state_return = true; }
          if (("aec2" == name) && (value >= 0U) && (value <= 1U)) { id(espcam).set_aec2(value); state_return = true; }
          if (("ae_level" == name) && (value >= -2) && (value <= 2)) { id(espcam).set_ae_level(value); state_return = true; }
          if (("aec_value" == name) && (value >= 0U) && (value <= 1200U)) { id(espcam).set_aec_value(value); state_return = true; }
          if (("agc_mode" == name) && (value >= 0U) && (value <= 1U)) { id(espcam).set_agc_mode((esphome::esp32_camera::ESP32GainControlMode)value); state_return = true; }
          if (("agc_value" == name) && (value >= 0U) && (value <= 30U)) { id(espcam).set_agc_value(value); state_return = true; }
          if (("agc_gain_ceiling" == name) && (value >= 0U) && (value <= 6U)) { id(espcam).set_agc_gain_ceiling((esphome::esp32_camera::ESP32AgcGainCeiling)value); state_return = true; }
          if (("wb_mode" == name) && (value >= 0U) && (value <= 4U)) { id(espcam).set_wb_mode((esphome::esp32_camera::ESP32WhiteBalanceMode)value); state_return = true; }
          if (("test_pattern" == name) && (value >= 0U) && (value <= 1U)) { id(espcam).set_test_pattern(value); state_return = true; }
          if (true == state_return) {
            id(espcam).update_camera_parameters();
          else {
            ESP_LOGW("esp32_camera_set_param", "Error in name or data range");
ota:
  - platform: esphome
    password: "xxx"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Espcam Fallback Hotspot"
    password: "FL5VEdqFICLZ"
esp32_camera:
  external_clock:
    pin: GPIO0
    frequency: 10MHz
  i2c_pins:
    sda: GPIO26
    scl: GPIO27
  data_pins: [GPIO5, GPIO18, GPIO19, GPIO21, GPIO36, GPIO39, GPIO34, GPIO35]
  vsync_pin: GPIO25
  href_pin: GPIO23
  pixel_clock_pin: GPIO22
  power_down_pin: GPIO32
  resolution: 800x600
  jpeg_quality: 10  # max. 63
  max_framerate: 1.0fps
  idle_framerate: 0.2fps
  vertical_flip: true
  horizontal_mirror: false
  brightness: 2 # -2 to 2
  contrast: 1 # -2 to 2
  special_effect: none
  # exposure settings
  aec_mode: auto
  aec2: false
  ae_level: 0
  aec_value: 300
  # gain settings
  agc_mode: auto
  agc_gain_ceiling: 2x
  agc_value: 0
  # white balance setting
  wb_mode: auto
output:
# white LED
  - platform: ledc
    channel: 2
    pin: GPIO4
# red status light
  - platform: gpio
    pin:
      number: GPIO33
      inverted: True
light:
  - platform: monochromatic
    output: espCamLED
  - platform: binary
    output: gpio_33
switch:
  - platform: restart
binary_sensor:
  - platform: status
# http server setting
esp32_camera_web_server:
  - port: 8080
    mode: stream
  - port: 8081
    mode: snapshot
captive_portal:
.Hope, this is helpfull for you
We don’t even know which specific board or YAML you are using. Do you expect us to mind-read you?
Help us help you.
You can post the ESPHome logs. Also check that the camera cable is properly inserted into the module.
Hi, thanks for your reply.
I did not expect an answer.
I only wanted to answer to the inital post of Roberto, where a valid configuration for cam modul ov2640 was asked for.
On my side this module works with the esp home yaml file I have posted.
