Helllo everyone !
i have a problem that i could use some help with , i installed home assistant and using ESPHOME to control relays using my ESP32 , the relays code works very well , but then i decided to add a DHT11 sensor to my yaml and problems started showing :
INFO Uploading /data/bitanas/.pioenvs/bitanas/firmware.bin (890512 bytes)
Uploading: [============================================================] 100% Done...
INFO Waiting for result...
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from 192.168.1.200 using esphome API
INFO Connecting to 192.168.1.200:6053 (192.168.1.200)
WARNING Initial connection failed. The ESP might not be connected to WiFi yet (Error connecting to 192.168.1.200: timed out). Re-Trying in 1 seconds
WARNING Initial connection failed. The ESP might not be connected to WiFi yet (Error connecting to 192.168.1.200: [Errno 111] Connection refused). Re-Trying in 1 seconds
WARNING Initial connection failed. The ESP might not be connected to WiFi yet (Error connecting to 192.168.1.200: [Errno 111] Connection refused). Re-Trying in 2 seconds
WARNING Initial connection failed. The ESP might not be connected to WiFi yet (Error connecting to 192.168.1.200: [Errno 111] Connection refused). Re-Trying in 3 seconds
it gets stuck there , but once i remove the sensor code , everything goes back to normal and working.
i removed my relay code and left only the sensor code , the error shows up again.
i really wish i had more knowledge in order to fix this by my self but i’m stuck can anyone help me ?
Hello sorry for the late reply , i have spent the last several hours trying to figure out what is wrong , until i reached the point where it uploaded the firmware but it’s stuck in a loop that i can’t get out from , here is my output :
[23:01:15][I][logger:156]: Log initialized
[23:01:15][C][ota:364]: There have been 8 suspected unsuccessful boot attempts.
[23:01:15][I][app:028]: Running through setup()...
[23:01:15][C][dht:011]: Setting up DHT...
[23:01:15][C][wifi:033]: Setting up WiFi...
[23:01:15][D][wifi:304]: Starting scan...
[23:01:15][D][dht:048]: Got Temperature=19.0°C Humidity=55.0%
[23:01:15][D][sensor:092]: 'Temperature': Sending state 19.00000 °C with 1 decimals of accuracy
[23:01:15][D][sensor:092]: 'Humidity': Sending state 55.00000 % with 0 decimals of accuracy
[23:01:15]Guru Meditation Error: Core 1 panic'ed (Interrupt wdt timeout on CPU1)
[23:01:15]Core 1 register dump:
[23:01:15]PC : 0x4008b9a6 PS : 0x00060634 A0 : 0x4008b994 A1 : 0x3ffb1cf0
WARNING Decoded 0x4008b9a6: vPortYield at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/portasm.S:542
[23:01:15]A2 : 0x3ffb8058 A3 : 0x00000000 A4 : 0x3ffbdb4c A5 : 0x3ffbdb4c
[23:01:15]A6 : 0xfffbfff0 A7 : 0x3ffb8058 A8 : 0x8015c8fc A9 : 0x3ffb1cd0
[23:01:15]A10 : 0x3ffb8768 A11 : 0x000001f4 A12 : 0x80089f09 A13 : 0x3ffb1cc0
[23:01:15]A14 : 0x00000003 A15 : 0x00060623 SAR : 0x00000018 EXCCAUSE: 0x00000006
[23:01:15]EXCVADDR: 0x00000000 LBEG : 0x400014fd LEND : 0x4000150d LCOUNT : 0xffffffff
[23:01:15]
[23:01:15]Backtrace: 0x4008b9a6:0x3ffb1cf0 0x4008b991:0x3ffb1d10 0x400db6f5:0x3ffb1d30 0x400dd162:0x3ffb1d80 0x400e7833:0x3ffb1fb0 0x400890f5:0x3ffb1fd0
WARNING Found stack trace! Trying to decode it
WARNING Decoded 0x4008b991: vPortYield at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/portasm.S:533
WARNING Decoded 0x400db6f5: esphome::Application::setup() at /config/esphome/anas/src/esphome/core/application.cpp:54
WARNING Decoded 0x400dd162: setup() at /config/esphome/anas/src/main.cpp:151
WARNING Decoded 0x400e7833: loopTask(void*) at /root/.platformio/packages/framework-arduinoespressif32/cores/esp32/main.cpp:14
WARNING Decoded 0x400890f5: vPortTaskWrapper at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/port.c:355 (discriminator 1)
[23:01:16]
[23:01:16]Core 0 register dump:
[23:01:16]PC : 0x4015d0f2 PS : 0x00060d34 A0 : 0x800ea866 A1 : 0x3ffbc050
WARNING Decoded 0x4015d0f2: esp_pm_impl_waiti at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/esp32/pm_esp32.c:492
[23:01:16]A2 : 0x00000000 A3 : 0x00000001 A4 : 0x80089308 A5 : 0x3ffb5b30
[23:01:16]A6 : 0x00000000 A7 : 0x3ffbbd40 A8 : 0x800e97da A9 : 0x3ffbc020
[23:01:16]A10 : 0x00000000 A11 : 0x00000001 A12 : 0x80089308 A13 : 0x3ffbbf50
[23:01:16]A14 : 0x00000000 A15 : 0x3ffbbd40 SAR : 0x00000000 EXCCAUSE: 0x00000006
[23:01:16]EXCVADDR: 0x00000000 LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000
[23:01:16]
[23:01:16]Backtrace: 0x4015d0f2:0x3ffbc050 0x400ea863:0x3ffbc070 0x4008a8d9:0x3ffbc090 0x400890f5:0x3ffbc0b0
WARNING Decoded 0x400ea863: esp_vApplicationIdleHook at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/esp32/freertos_hooks.c:108
WARNING Decoded 0x4008a8d9: prvIdleTask at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/tasks.c:3507
[23:01:16]
[23:01:16]Rebooting...
[23:01:16]ets Jun 8 2016 00:22:57
[23:01:16]
[23:01:16]rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
[23:01:16]configsip: 0, SPIWP:0xee
[23:01:16]clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
[23:01:16]mode:DIO, clock div:2
[23:01:16]load:0x3fff0018,len:4
[23:01:16]load:0x3fff001c,len:1044
[23:01:16]load:0x40078000,len:8896
[23:01:16]load:0x40080400,len:5828
[23:01:16]entry 0x400806ac
[23:01:16][I][logger:156]: Log initialized
[23:01:16][C][ota:364]: There have been 9 suspected unsuccessful boot attempts.
[23:01:16][I][app:028]: Running through setup()...
[23:01:16][C][dht:011]: Setting up DHT...
[23:01:16][C][wifi:033]: Setting up WiFi...
[23:01:16][D][wifi:304]: Starting scan...
[23:01:16][W][dht:160]: Requesting data from DHT failed!
[23:01:16][W][dht:060]: Invalid readings! Please check your wiring (pull-up resistor, pin number).
[23:01:16][D][sensor:092]: 'Temperature': Sending state nan °C with 1 decimals of accuracy
[23:01:16][D][sensor:092]: 'Humidity': Sending state nan % with 0 decimals of accuracy
[23:01:16]Guru Meditation Error: Core 1 panic'ed (Interrupt wdt timeout on CPU1)
[23:01:16]Core 1 register dump:
[23:01:16]PC : 0x40081f68 PS : 0x00060234 A0 : 0x80082c5e A1 : 0x3ffb1b60
WARNING Decoded 0x40081f68: esp_timer_impl_get_time at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/esp32/esp_timer_esp32.c:340
[23:01:16]A2 : 0x025defff A3 : 0x00000000 A4 : 0x00000050 A5 : 0xefffffff
[23:01:16]A6 : 0x00000000 A7 : 0x00000000 A8 : 0x00000000 A9 : 0x3ffc1750
[23:01:16]A10 : 0x00000000 A11 : 0x00000004 A12 : 0x00000050 A13 : 0x3f404b52
[23:01:16]A14 : 0x00000000 A15 : 0x00000000 SAR : 0x0000000a EXCCAUSE: 0x00000006
[23:01:16]EXCVADDR: 0x00000000 LBEG : 0x400014fd LEND : 0x4000150d LCOUNT : 0xffffffff
[23:01:16]
[23:01:16]Backtrace: 0x40081f68:0x3ffb1b60 0x40082c5b:0x3ffb1b80 0x4008175b:0x3ffb1ba0 0x400d9539:0x3ffb1bc0 0x400d9b10:0x3ffb1cd0 0x4015c8f9:0x3ffb1cf0 0x4015c9c5:0x3ffb1d10 0x400db6c9:0x3ffb1d30 0x400dd162:0x3ffb1d80 0x400e7833:0x3ffb1fb0 0x400890f5:0x3ffb1fd0
WARNING Decoded 0x40082c5b: esp_timer_get_time at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/esp32/esp_timer.c:443
WARNING Decoded 0x4008175b: millis at /root/.platformio/packages/framework-arduinoespressif32/cores/esp32/esp32-hal-misc.c:170
WARNING Decoded 0x400d9539: esphome::wifi::WiFiComponent::check_scanning_finished() at /config/esphome/anas/src/esphome/components/wifi/wifi_component.cpp:579
WARNING Decoded 0x400d9b10: esphome::wifi::WiFiComponent::loop() at /config/esphome/anas/src/esphome/components/wifi/wifi_component.cpp:579
WARNING Decoded 0x4015c8f9: esphome::Component::call_loop() at /config/esphome/anas/src/esphome/core/component.cpp:111
WARNING Decoded 0x4015c9c5: esphome::Component::call() at /config/esphome/anas/src/esphome/core/component.cpp:111
WARNING Decoded 0x400db6c9: esphome::Application::setup() at /config/esphome/anas/src/esphome/core/application.cpp:49 (discriminator 2)
[23:01:17]
[23:01:17]Core 0 register dump:
[23:01:17]PC : 0x4015d0f2 PS : 0x00060f34 A0 : 0x800ea866 A1 : 0x3ffbc050
[23:01:17]A2 : 0x00000000 A3 : 0x00000001 A4 : 0x80089308 A5 : 0x3ffb5b30
[23:01:17]A6 : 0x00000000 A7 : 0x3ffbbd40 A8 : 0x800e97da A9 : 0x3ffbc020
[23:01:17]A10 : 0x00000000 A11 : 0x00000001 A12 : 0x80089308 A13 : 0x3ffbbf50
[23:01:17]A14 : 0x00000000 A15 : 0x3ffbbd40 SAR : 0x00000000 EXCCAUSE: 0x00000006
[23:01:17]EXCVADDR: 0x00000000 LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000
[23:01:17]
[23:01:17]Backtrace: 0x4015d0f2:0x3ffbc050 0x400ea863:0x3ffbc070 0x4008a8d9:0x3ffbc090 0x400890f5:0x3ffbc0b0
[23:01:17]
[23:01:17]Rebooting...
[23:01:17]ets Jun 8 2016 00:22:57
[23:01:17]
[23:01:17]rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
[23:01:17]configsip: 0, SPIWP:0xee
[23:01:17]clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
[23:01:17]mode:DIO, clock div:2
[23:01:17]load:0x3fff0018,len:4
[23:01:17]load:0x3fff001c,len:1044
[23:01:17]load:0x40078000,len:8896
[23:01:17]load:0x40080400,len:5828
[23:01:17]entry 0x400806ac
[23:01:17][I][logger:156]: Log initialized
[23:01:17][C][ota:364]: There have been 10 suspected unsuccessful boot attempts.
[23:01:17][E][ota:369]: Boot loop detected. Proceeding to safe mode.
[23:01:17][I][app:028]: Running through setup()...
[23:01:17][C][wifi:033]: Setting up WiFi...
[23:01:17][D][wifi:304]: Starting scan...
[23:01:17][D][wifi:319]: Found networks:
[23:01:17][I][wifi:365]: - 'TOPNET_AA58' [redacted]▂▄▆█
[23:01:17][D][wifi:366]: Channel: 11
[23:01:17][D][wifi:367]: RSSI: -73 dB
[23:01:17][D][wifi:369]: - [redacted] [redacted]▂▄▆█
[23:01:17][I][wifi:193]: WiFi Connecting to 'TOPNET_AA58'...
[23:01:19][W][wifi_esp32:336]: Event: Disconnected ssid='TOPNET_AA58' bssid=[redacted] reason='Auth Expired'
[23:01:19][W][wifi:451]: Error while connecting to network.
[23:01:19][W][wifi:488]: Restarting WiFi adapter...
[23:01:19][I][wifi:193]: WiFi Connecting to 'TOPNET_AA58'...
[23:01:20][W][wifi_esp32:336]: Event: Disconnected ssid='TOPNET_AA58' bssid=[redacted] reason='Auth Expired'
[23:01:20][W][wifi:451]: Error while connecting to network.
[23:01:20][W][wifi:488]: Restarting WiFi adapter...
[23:01:25][D][wifi:304]: Starting scan...
[23:01:27][D][wifi:319]: Found networks:
[23:01:27][I][wifi:365]: - 'TOPNET_AA58' [redacted]▂▄▆█
[23:01:27][D][wifi:366]: Channel: 11
[23:01:27][D][wifi:367]: RSSI: -75 dB
[23:01:27][D][wifi:369]: - [redacted] [redacted]▂▄▆█
[23:01:27][I][wifi:193]: WiFi Connecting to 'TOPNET_AA58'...
[23:01:28][W][wifi_esp32:336]: Event: Disconnected ssid='TOPNET_AA58' bssid=[redacted] reason='Auth Expired'
[23:01:28][W][wifi:451]: Error while connecting to network.
[23:01:28][W][wifi:488]: Restarting WiFi adapter...
[23:01:28][I][wifi:193]: WiFi Connecting to 'TOPNET_AA58'...
[23:01:29][W][wifi_esp32:336]: Event: Disconnected ssid='TOPNET_AA58' bssid=[redacted] reason='Auth Expired'
[23:01:29][W][wifi:451]: Error while connecting to network.
[23:01:29][W][wifi:488]: Restarting WiFi adapter...
[23:01:34][D][wifi:304]: Starting scan...
[23:01:36][D][wifi:319]: Found networks:
[23:01:36][I][wifi:365]: - 'TOPNET_AA58' [redacted]▂▄▆█
[23:01:36][D][wifi:366]: Channel: 11
[23:01:36][D][wifi:367]: RSSI: -76 dB
[23:01:36][D][wifi:369]: - [redacted] [redacted]▂▄▆█
[23:01:36][I][wifi:193]: WiFi Connecting to 'TOPNET_AA58'...
[23:01:37][W][wifi_esp32:336]: Event: Disconnected ssid='TOPNET_AA58' bssid=[redacted] reason='Auth Expired'
[23:01:37][W][wifi:451]: Error while connecting to network.
[23:01:37][W][wifi:488]: Restarting WiFi adapter...
[23:01:37][I][wifi:193]: WiFi Connecting to 'TOPNET_AA58'...
[23:01:39][W][wifi_esp32:336]: Event: Disconnected ssid='TOPNET_AA58' bssid=[redacted] reason='Auth Expired'
[23:01:39][W][wifi:451]: Error while connecting to network.
[23:01:39][W][wifi:488]: Restarting WiFi adapter...
i’m sorry if it’s too long but i couldn’t be more confused … i’m losing hope to fix this
Well from what I see it looks like it booted, did the first read of the temp and humidity from the dht which was successful, and then is trying to talk to a sensor which barfs. Guess I would need to see the sensor code.
I had the exact problem with a ESP32 DEVKIT V1, DHT11, SR501. As soon as I switched to the 1.15 DEV it worked. I had been working on this for over a week. Thanks for the information.
