ESP32 - PWM relay/heater control
Could you upload your code please?
For the GIF shown above, I only built a microcontroller with ESPHome on a phase angle dimmer. With the light function I could control the phase angle (=power). I haven’t had time for automation yet. My plan is for the future when I have replaced my heating rods with a heat pump. To control the power of the heat pump with the pwm signal of the microcontroller.
Just re-found my post here - but my question still remains: is it possible to achieve efficient (i.e. proportional) use of solar surplus with a simple on-off pulsing switch? I still don’t think so - some kind of phase-angle device must be needed at the hardware level for the utility meter to not “see” any positive import pulses?
I want to set up a zero export with my heater-rod, but can’t get it working.
Any help appreciated!
I want (0 up to 1) values out of sensor.power_export to control the power level.
#Powerfactor - Leistungsberechnung
    unit_of_measurement: '%'
    accuracy_decimals: 0
    lambda: |-
      float allowed_power = id(pwrfactor).state/100.0;
      float temp_pwr = 0.0;
      float max_pwr = 1000;
        id(KemoM240).set_level(allowed_power);
        return allowed_power*100;
    update_interval: 5s
#PV Überschuss von Homeassistant
  - platform: homeassistant
    entity_id: sensor.power_export
    internal: false
    unit_of_measurement: W
    on_value:
      then:
        - component.update: pwrfactor
Hi, I’m interested in use my solar surplus in a radiator heater.
My approach is using esp32 , state solid relay with zero cross integrated in it. , and pzem004.
The esphome esp32 gets the surplus in watt from home assistant. I have Huawei inverter. And the consumption of the heater with the pzem004
The idea is adjusting the pwm make the surplus equal to 0.
Not yet I have the components, I will post de progress.
Before you buy randomly components, may I suggest you to do research how your electricity meter is sampling and measuring the consumption. That tells you what hardware you need.
Hi, Finally I did some test and it works fine!
This project uses 240V, so take care! And because to adjust consumption it trims the electricity wave, it can be only used for pure resistive loads
For this project I’m using
  • ESP32
  • robotdyn pwm triac module
  • PZEM004T(only for monitoring)
  • RGB led (because I have an spare one)
The original Triac is a BTA16-600B, for a 2000W heater is too small, you can replace for an BTA41-700B. This triac is bigger, so yo need to extend with wires (The wires must be as short as possible and 2.5mm thick). Also you need an aluminium heatsink of sufficient size.
BTAxx-xxxB → for this project any like this reference is fine.
esphome:
  friendly_name: Excedent Solar PID
esp32:
  board: esp32dev
  framework:
    type: arduino
logger:
  level: INFO
api:
  encryption:
    key: "xxxxx"
ota:
  platform: esphome
  password: "xxxxxx"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Excedent-Solar-TRIAC"
captive_portal:
# Globals per al nivell (amb suavitzat)
globals:
  - id: nivell_target
    type: float
    initial_value: "0.0"
  - id: nivell_suau
    type: float
  - id: pas_ajust
    type: float
    initial_value: "0.02"   # 2% per lectura HA (suau)
# UART PZEM
uart:
  tx_pin: 17
  rx_pin: 16
  baud_rate: 9600
# Sortida TRIAC (RobotDyn AC Dimmer)
output:
  - platform: ac_dimmer
    gate_pin: 23
    zero_cross_pin:
      number: 22
      mode:
        input: true
        pullup: true
    min_power: 0%
    max_power: 100%
# Suavitzat cap al nivell target (rampa suau)
interval:
  - interval: 500ms
    then:
      - lambda: |-
          float dif = id(nivell_target) - id(nivell_suau);
          id(nivell_suau) += dif * 0.4f;  // 40% cada 0.5s ≈ constant i suau
          if (id(nivell_suau) < 0.0f) id(nivell_suau) = 0.0f;
          if (id(nivell_suau) > 1.0f) id(nivell_suau) = 1.0f;
          if (id(control_auto).state) {
            id(ac_dimmer_resistencia).set_level(id(nivell_suau));
          } else {
            id(ac_dimmer_resistencia).set_level(0.0f);
          ESP_LOGI("control", "TRIAC: target %.0f%% → suau %.0f%%",
                   id(nivell_target)*100.0f, id(nivell_suau)*100.0f);
  - interval: 10s
    then:
      - lambda: |-
          float n = id(nivell_suau);
          float r, g, b;
          if (n <= 0.0f) { r=0; g=0; b=80; }
          else if (n < 0.5f) { float f=n/0.5f; r=255*f; g=255; b=0; }
          else { float f=(n-0.5f)/0.5f; r=255; g=255-(255*f); b=0; }
          auto call = id(led_excedent).turn_on();
          call.set_rgb(r/255.0f, g/255.0f, b/255.0f);
          call.set_transition_length(1000);
          call.perform();
# Sensors
  # PZEM: potència càrrega (informatiu)
  - platform: pzem004t
    power:
      name: "Potència Càrrega Resistiva"
      unit_of_measurement: "W"
  # Huawei: excedent (+) / compra (−)
    name: "Potència Injectada (Huawei)"
    entity_id: sensor.huawei_huawei_meter_active_power
    on_value:
      then:
        - lambda: |-
            float v = x * 1000.0f;
            if (v > -50.0f && v < 50.0f) return;
            float niv = id(nivell_target);
            // Ajust proporcional al desfasament (més ràpid si hi ha molt excedent)
            float delta = v / 2000.0f;  // divideix pel marge desitjat (2 kW = canvi total)
            niv += delta;
            if (niv > 1.0f) niv = 1.0f;
            if (niv < 0.0f) niv = 0.0f;
            id(nivell_target) = niv;
            ESP_LOGI("excedent", "Huawei: %.1f W → target %.0f%%", v, niv*100);
  # WiFi RSSI
  - platform: wifi_signal
    name: "Intensitat WiFi ESP32"
    update_interval: 60s
  # Percentatge actual TRIAC (per HA)
    unit_of_measurement: "%"
    update_interval: 5s
    lambda: |-
      return id(nivell_suau) * 100.0f;
# Switch de control automàtic
switch:
    name: "Control Automàtic Excedent"
    optimistic: true
    restore_mode: RESTORE_DEFAULT_ON
# LED RGB indicador (WS2812B)
light:
  - platform: fastled_clockless
    name: "Indicador Excedent"
    internal: true
    chipset: WS2812B
    pin: 25
    num_leds: 1
    rgb_order: GRB
# Color LED segons nivell (cada 10 s)
Robotdyn has also module with BTA24.
Be aware that the formula used in ac_dimmer library is an approximation. There is noticeable error when close to min and max power.
He made no such thing! Why would lie to my friends on here about that? ; ) jk man.
Just saying Hey and Hope all is well.
