ESP32-S3 4.3inch Capacitive Touch Display from - waveshare
Check the device logs to see if the action is being sent; check the HA logs to see if there are any errors there. Does the button change state when you switch the light from elsewhere?
Holy crap! I left it unplugged for a couple hours, then I plugged it back in just now to see if it would change state when I turned the light on, and the dang thing is working. But apparently blue is off and red is on, which I guess makes sense. But I literally made no changes to my code.
Okay, and now I’m noticing something else. It’s really flaky. I’ll let the screen go to sleep for a minute or so, when it wakes the screen comes up blank before refreshing the button and I can click the button a few times (and it will change state on the screen) while nothing happens to the light. Then all of a sudden it will start working again. But if I let it go to sleep and then immediately wake it back up, the screen comes up with the button on it and it still remains functional. Any idea what that might be about?
Well, I refer you to my previous answer about checking logs. But it sounds like you have some flakey communications.
A couple of unrelated things - you don’t need the on_boot action to show the main page, that happens by default (and you only have one page anyway.) Instead of using the global variable and an interval to control the backlight, use the LVGL on_idle trigger - see the cookbook for examples.
Okay, yeah, I was just taking the code from above for the blanking. But following your suggestion, I dug into the LVGL tips and tricks and moved to that method. That seems to be working well. I AM having some sort of communications issues though, but I’m unsure of how to move forward with the troubleshooting…
my new yaml:
esphome:
  friendly_name: Waveshare-ESP32-S3-Touch
  platformio_options:
    build_flags: "-DBOARD_HAS_PSRAM"
    board_build.arduino.memory_type: qio_opi
    board_build.flash_mode: dio
    board_upload.maximum_ram_size: 524288
esp32:
  board: esp32-s3-devkitc-1
  variant: esp32s3
  framework:
    type: esp-idf
    sdkconfig_options:
      CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: y
      CONFIG_ESP32S3_DATA_CACHE_64KB: y
      CONFIG_SPIRAM_FETCH_INSTRUCTIONS: y
      CONFIG_SPIRAM_RODATA: y
# Enable logging
logger:
  level: DEBUG
# Enable Home Assistant API
api:
  encryption:
    key: "<secret>"
ota:
  - platform: esphome
    password: "<secret>"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Waveshare-Esp32-S3-Touch"
ch422g:
  - id: ch422g_hub
psram:
  mode: octal
  speed: 80MHz
i2c:
  sda: 8
  scl: 9
  scan: true
  frequency: 400kHz
# Switch to turn backlight back on
switch:
  - platform: gpio
    pin:
      ch422g: ch422g_hub
      number: 2
      mode:
        output: true
      inverted: False
    restore_mode: ALWAYS_ON
# Antiburn Switch
    icon: mdi:television-shimmer
    optimistic: true
    entity_category: "config"
    turn_on_action:
      - logger.log: "Starting Antiburn"
      - if:
          condition: lvgl.is_paused
          then:
            - lvgl.resume:
            - lvgl.widget.redraw:
      - lvgl.pause:
          show_snow: true
    turn_off_action:
      - logger.log: "Stopping Antiburn"
      - if:
          then:
            - lvgl.resume:
# Timer for Antiburn
time:
  - platform: homeassistant
    on_time:
      - hours: 2,3,4,5
        minutes: 5
        seconds: 0
        then:
          - switch.turn_on: switch_antiburn
      - hours: 2,3,4,5
        minutes: 35
        seconds: 0
        then:
          - switch.turn_off: switch_antiburn
# Number to track backlight timeout
number:
    name: LVGL Screen timeout
    optimistic: true
    unit_of_measurement: "s"
    initial_value: 45
    restore_value: true
    min_value: 10
    max_value: 180
    step: 5
    mode: box
touchscreen:
  - platform: gt911
    interrupt_pin: 4
    reset_pin:
      ch422g:
      number: 1
    on_release:
      - if:
          then:
            - logger.log: "LVGL resuming"
            - lvgl.resume:
            - switch.turn_on: display_backlight
display:
  - platform: rpi_dpi_rgb
#    update_interval: never
    auto_clear_enabled: false
    color_order: RGB
    pclk_frequency: 16MHz
    dimensions:
      width: 800
      height: 480
    reset_pin:
      ch422g:
      number: 3
    enable_pin:
      ch422g:
      number: 2
    de_pin:
      number: 5
    hsync_pin:
      number: 46
      ignore_strapping_warning: true
    vsync_pin:
      number: 3
    pclk_pin: 7
    hsync_back_porch: 30
    hsync_front_porch: 210
    hsync_pulse_width: 30
    vsync_back_porch: 4
    vsync_front_porch: 4
    vsync_pulse_width: 4
    data_pins:
      red: [1, 2, 42, 41, 40]
      blue: [14, 38, 18, 17, 10]
      green: [39, 0, 45, 48, 47, 21]
# Draw the dashboard
lvgl:
  displays:
    - rpi_disp
  touchscreens:
    - my_touchscreen
  on_idle:
    timeout: !lambda "return (id(display_timeout).state * 1000);"
    then:
      - logger.log: "LVGL is idle"
      - switch.turn_off: display_backlight
      - lvgl.pause:
  pages:
    - id: main_page
      width: 100%
      bg_color: 0x000000
      bg_opa: cover
      widgets:
        - button:
            align: CENTER
            width: 150
            height: 70
            checkable: true
            widgets:
              - label:
                  align: CENTER
                  text: 'Office Corner Lights'
            on_click:
              - logger.log: "Toggle Button Pressed"
              - homeassistant.action:
                  action: light.toggle
                    entity_id: light.lifx_bulb
I was preparing to paste a ton of logs in here when I stumbled upon this in the homeassistant logs:
Can't connect to ESPHome API for waveshare-esp32-s3-touch @ 192.168.0.132: waveshare-esp32-s3-touch @ 192.168.0.132: The connection dropped immediately after encrypted hello; Try enabling encryption on the device or turning off encryption on the client (Home Assistant 2025.3.2). (HandshakeAPIError)
So… any idea where I fix that? I can only assume that the waveshare is connecting to homeassistant through my apache reverse proxy, which is totally fine with me, but since it’s not leaving the house, I can just as easily connect directly to it if I know where to configure that :confused:
No idea, and it’s not a display issue, personally I would start by deleting the device in HA and adding it again.
So that’s exactly what I did. Deleted it all, went and re-initialized it through web.esphome.io and then re-added to home assistant and re-installed my yaml. Seems to work until it doesn’t. But as you said, doesn’t seem to be a display issue. I’ll have to make a new post outlining what’s going on, because there’s something fishy going on, and it seems like the whole device is going to sleep instead of just the screen, and then when it wakes up it struggles to connect or something. Thanks for all the help though, at least I’ve gotten it to a point where it seems like my yaml is working. That was a huge step forward!
With this code
esphome:
  friendly_name: ESP Display
  platformio_options:
esp32:
  variant: esp32s3
  framework:
    type: esp-idf
    sdkconfig_options:
# Enable logging
logger:
  level: DEBUG
api:
  encryption:
    key: "KEY"
ota:
  - platform: esphome
    password: "PASSWORD"
wifi:
  ap:
    ssid: "Esp-Display Fallback Hotspot"
ch422g:
  - id: ch422g_hub
psram:
  mode: octal
  speed: 80MHz
i2c:
  sda: 8
  scl: 9
  scan: true
  frequency: 400kHz
switch:
  - platform: gpio
    pin:
      ch422g: ch422g_hub
      number: 2
      mode:
        output: true
      inverted: False
# Antiburn Switch
    optimistic: true
    turn_on_action:
      - if:
          then:
            - lvgl.resume:
      - lvgl.pause:
          show_snow: true
    turn_off_action:
      - if:
          then:
            - lvgl.resume:
time:
    on_time:
      - hours: 2,3,4,5
        minutes: 5
        seconds: 0
        then:
      - hours: 2,3,4,5
        minutes: 35
        seconds: 0
        then:
number:
    optimistic: true
    initial_value: 45
    restore_value: true
    min_value: 10
    max_value: 180
    step: 5
    mode: box
touchscreen:
  - platform: gt911
    interrupt_pin: GPIO4
    reset_pin:
      ch422g:
      number: 1
    on_touch:
      - lambda: |-
        ESP_LOGI("Touch", "Touch detected at x=%d, y=%d", touch.x, touch.y);
    on_release:
      - if:
          then:
            - lvgl.resume:
display:
    color_order: RGB
    dimensions:
      width: 800
      height: 480
    reset_pin:
      ch422g:
      number: 3
    enable_pin:
      ch422g:
      number: 2
    de_pin:
      number: 5
    hsync_pin:
      number: 46
    vsync_pin:
      number: 3
    pclk_pin: 7
    vsync_back_porch: 4
    data_pins:
lvgl:
  displays:
    - rpi_disp
  touchscreens:
    - my_touchscreen
  on_idle:
    then:
      - lvgl.pause:
  pages:
    - id: main_page
      width: 100%
      bg_color: 0x000000
      bg_opa: cover
      widgets:
        - button:
            align: CENTER
            width: 200
            height: 100
            checkable: true
            widgets:
              - label:
                  align: CENTER
                  text: 'Office Light'
            on_click:
                    entity_id: light.office_light
text_sensor:
  - platform: wifi_info
    ip_address:
    ssid:
    bssid:
    mac_address:
      name: Mac Wifi Address
    scan_results:
      name: Latest Scan Results
  - platform: wifi_signal
    name: "WiFi Signal Sensor"
    update_interval: 60s
  - platform: wifi_signal # Reports the WiFi signal strength/RSSI in dB
    name: "WiFi Signal dB"
    entity_category: "diagnostic"
Everything is working but after the screen wakes up it take 5-10 seconds before the button will do anything. Any ideas how to speed that up?
Does anyone happen to have a basic working ESPHome example for the Waveshare 4.3" Touch Display? I’ve tried multiple selections from above but after flashing I’m getting nothing and HA is not recognizing my diplay.
This works for the 7" version. Is that what you have?
I have the 4.3" version.
try this one
substitutions:
  friendly_name: Waveshare S3 4.3
esphome:
  platformio_options:
esp32:
  variant: esp32s3
  framework:
    type: esp-idf
    sdkconfig_options:
      CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
      CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
logger:
ch422g:
psram:
  mode: octal
  speed: 80MHz
i2c:
  sda: 8
  scl: 9
  scan: true
  frequency: 400kHz
touchscreen:
  - platform: gt911
    interrupt_pin: 4
    reset_pin:
      ch422g:
      number: 1
display:
    color_order: RGB
    dimensions:
      width: 800
      height: 480
    reset_pin:
      ch422g:
      number: 3
    enable_pin:
      ch422g:
      number: 2
    de_pin:
      number: 5
    hsync_pin:
      number: 46
    vsync_pin:
      number: 3
    pclk_pin: 7
    vsync_back_porch: 4
    data_pins:
lvgl:
I’ve flashed it and I see nothing.
Just want to make sure I’m flashing correctly. I’m holding down the boot button while powering up and then flashing with ESPHome Flasher 1.4 (I’m old fashioned and like using it). Afterwards, I’m moving the USB C cable to the USB port to power it on.
When doing so, I hear the PC I’m plugged into continually beep over and over again like the diplay is restarting.
I see nothing on the display but I can see the two red LEDs on the back and the backlight appears to be on.
Maybe I’m not following the correct flash/power on procedure?
You don’t have enough power to power it.
Get a USB brick
Yeah, I’m using a 20W USB block. Still nothing…
Turns out you can’t use ESPHome Flasher to flash these devices…it needs to be flashed via ESPHome Web.
Thank you so much.Good.
I am trying to configure my Waveshare ESP32-S3 3.4inch capacitive display (which works fine in other scenarios) to start with as a simple display (for example to display a value from a temperature gauge elsewhere on my ESPHome system).
Here is my YAML code:
esphome:
friendly_name: ESP_Display_4_3
esp32:
board: esp32s3box
framework:
type: esp-idf
Enable logging
logger:
api:
encryption:
key: ā€œā€
ota:
  • platform: esphome
    password: ā€œā€
wifi:
Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: ā€œEsp-Display-4-3 Fallback Hotspotā€
password: ā€œā€
captive_portal:
display:
  • platform: rpi_dpi_rgb
    color_order: RGB
    dimensions:
    width: 800
    height: 480
    de_pin:
    number: 5
    hsync_pin:
    number: 46
    vsync_pin:
    number: 3
    pclk_pin: 7
    vsync_back_porch: 4
    data_pins:
    red:
    - 1 #r3
    - 2 #r4
    - 42 #r5
    - 41 #r6
    - 40 #r7
    blue:
    - 14 #b3
    - 38 #b4
    - 18 #b5
    - 17 #b6
    - 10 #b7
    green:
    - 39 #g2
    - 0 #g3
    - 45 #g4
    - 48 #g5
    - 47 #g6
    - 21 #g7
    lambda: |-
    it.print(0, 0, id(roboto), ā€œHello World!ā€);
font:
  • file: ā€œgfonts://Robotoā€
Everything seems to work: it compiles and uploads the code, initially via USB cable. I can then ping the device even when only on WiFi but the display remains steadfastly black.
Can anyone help/advise?
esphome:
esp32:
  board: esp32s3box
  framework:
    type: esp-idf
# Enable logging
logger:
api:
  encryption:
    key: "Za7Or6x3kP/DknOF6uT7IFr3tLQbmdOuFtl1dAvfxEI="
ota:
  - platform: esphome
    password: "7c9f894bc1e58f621bdaad35a3a2ae68"
wifi:
  ap:
    ssid: "Esp-Display-4-3 Fallback Hotspot"
    password: "GcQJoVjqjPrM"
captive_portal:
display:
    color_order: RGB
    dimensions:
      width: 800
      height: 480
    de_pin:
      number: 5
    hsync_pin:
      number: 46
    vsync_pin:
      number: 3
    pclk_pin: 7
    vsync_back_porch: 4
    data_pins:
      red:
        - 1         #r3
        - 2         #r4
        - 42        #r5
        - 41        #r6
        - 40        #r7
      blue:
        - 14        #b3
        - 38        #b4
        - 18        #b5
        - 17        #b6
        - 10        #b7
      green:
        - 39        #g2
        - 0         #g3
        - 45        #g4
        - 48        #g5
        - 47        #g6
        - 21        #g7
    lambda: |-
      it.print(0, 0, id(roboto), "Hello World!");
font:
  - file: "gfonts://Roboto"
The resulting logs:
[17:02:04]I (314) cpu_start: Starting app cpu, en\xc4\xf8ESP-ROM:esp32s3-20210327
[17:02:04]Build:Mar 27 2021
[17:02:04]rst:0x3 (RTC_SW_SYS_RST),boot:0x8 (SPI_FAST_FLASH_BOOT)
[17:02:04]Saved PC:0x403764fb
WARNING Decoded 0x403764fb: esp_restart_noos_dig at /data/cache/platformio/packages/framework-espidf/components/esp_system/port/esp_system_chip.c:57 (discriminator 1)
[17:02:04]SPIWP:0xee
[17:02:04]mode:DIO, clock div:1
[17:02:04]load:0x3fce3818,len:0x1750
[17:02:04]load:0x403c9700,len:0x4
[17:02:04]load:0x403c9704,len:0xbe4
[17:02:04]load:0x403cc700,len:0x2d34
[17:02:04]entry 0x403c9908
[17:02:04]I (31) boot: ESP-IDF 5.1.5 2nd stage bootloader
[17:02:04]I (31) boot: compile time May  4 2025 22:16:30
[17:02:04]I (31) boot: Multicore bootloader
[17:02:04]I (34) boot: chip revision: v0.2
[17:02:04]I (38) boot.esp32s3: Boot SPI Speed : 80MHz
[17:02:04]I (43) boot.esp32s3: SPI Mode       : DIO
[17:02:04]I (48) boot.esp32s3: SPI Flash Size : 8MB
[17:02:04]I (52) boot: Enabling RNG early entropy source...
[17:02:04]I (58) boot: Partition Table:
[17:02:04]I (61) boot: ## Label            Usage          Type ST Offset   Length
[17:02:04]I (69) boot:  0 otadata          OTA data         01 00 00009000 00002000
[17:02:04]I (76) boot:  1 phy_init         RF data          01 01 0000b000 00001000
[17:02:04]I (83) boot:  2 app0             OTA app          00 10 00010000 001c0000
[17:02:04]I (91) boot:  3 app1             OTA app          00 11 001d0000 001c0000
[17:02:04]I (98) boot:  4 nvs              WiFi data        01 02 00390000 0006d000
[17:02:04]I (106) boot: End of partition table
[17:02:04]I (110) esp_image: segment 0: paddr=001d0020 vaddr=3c0b0020 size=317fch (202748) map
[17:02:04]I (155) esp_image: segment 1: paddr=00201824 vaddr=3fc98200 size=045c4h ( 17860) load
[17:02:04]I (159) esp_image: segment 2: paddr=00205df0 vaddr=40374000 size=0a228h ( 41512) load
[17:02:04]I (170) esp_image: segment 3: paddr=00210020 vaddr=42000020 size=a0628h (656936) map
[17:02:04]I (288) esp_image: segment 4: paddr=002b0650 vaddr=4037e228 size=09f54h ( 40788) load
[17:02:04]I (306) boot: Loaded app from partition at offset 0x1d0000
[17:02:04]I (306) boot: Disabling RNG early entropy source...
[17:02:04]I (307) cpu_start: Multicore app
[17:02:04]I (311) cpu_start: Pro cpu up.
Start with a known good config from earlier in this thread. Yours appears to be missing important things like psram and a backlight, and you are using the wrong serial connector (use the one marked USB)
