ESP32-S3-Zero turn LED Different Colors
Disregard, a little messing around in ChatGPT and I got it working. I tried for hours last night and wasn’t able to. Not sure what was different about the prompts I gave it today, but at any rate here is the working yaml.
esphome:
  friendly_name: Screen Time Indicator Light
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "*****"
ota:
  - platform: esphome
    password: "*****"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Screen-Time-Indicator-Light"
    password: "*****"
captive_portal:
light:
  - platform: neopixelbus
    type: RGB
    variant: WS2812
    pin: GPIO21
    num_leds: 1
    name: "Screen Time RGB"
    restore_mode: ALWAYS_OFF
select:
    name: "Screen Time Indicator State"
    optimistic: true
    options:
      - "Off"
      - "Red"
      - "Green"
    initial_option: "Off"
    on_value:
      then:
        - if:
              lambda: 'return x == "Red";'
            then:
              - light.turn_on:
                  red: 1.0
                  green: 0.0
                  blue: 0.0
        - if:
              lambda: 'return x == "Green";'
            then:
              - light.turn_on:
                  red: 0.0
                  green: 1.0
                  blue: 0.0
        - if:
              lambda: 'return x == "Off";'
            then:
              - light.turn_off: rgb_light
