Thanks, did that for test, but it seems that this sensor causes module to reset every minute or so… strange. When i removed it module stopped resetting. Maybe too much data…? IT did show connected BLE’s though.
I have finally got mine working - removed all my BLE devices I had intergraded prior > turned off all other Bluetooth integrations > device started showing up!
The text sensor and the verbose logs only show (address, rssi and name)
turned on
logger:
default: info
logs:
homeassistant.components.bluetooth: debug
in configuration.yaml and can confirm advertised device data is reaching home assistant
2022-10-23 18:53:21.210 DEBUG (MainThread) [homeassistant.components.bluetooth.manager] gl-s10-bt-proxy-1: xx:xx:xx:xx:xx:xx AdvertisementData(local_name='ATC_4BAHSN', service_data={'0000181a-0000-1000-8000-00805f9b34fb': b'\xa4\xc18K\xbd\x1f\x00\xe8@2\nfA'}) connectable: False match: set() rssi: -80
hm…
you got me here for a while…
i inserted above lines in ESPHome, but got a bunch of errors. ESPHome won’t accept individual logs to be set higher than general, only lower, and also option" default: logger" is not known to ESPHome’s compiler.
Well, after reading again i see that you inserted these lines in Home Assistant, not ESPHome… now it works, yes. However, it’s not seen which proxy device received and sent BLE module to HA, i can only see that it does come into HA. Also, it’s interesting that some modules have “False match” and some “True match”… whatever this means.
But, do you know where to look these logs other than in Studio Code Server (file home-assistant.log)? I can’t find it in HA’s interface…
Yeah sorry, configuration.yaml in ha!
Only other place would be in ha settings under logs (HA core) then look at the full logs there.
It seems this intergration needs to mature a bit.(which is understandable) In regards to user visibility of the source transmission of data (ie proxy delivering the data) which would ensure we are not all thinking that things are not working, when indeed they are!
I tried to create the bluetooth gateway today via the ESPhome website.
I see the device in my home assistant but it doesn’t detect any bluetooth devices.
Home assistant is on 2022.12
ESP32 wemos d1 mini with fresh install from the esphome website.
My openmqtt gateway detects the bluetooth devices immediately. The mqtt gateway is not active during the tests but I can’t see devices.
How can in troubleshoot this ?
Config file
substitutions:
device_description: "Bluetooth proxy"
packages:
esphome.bluetooth-proxy: github://esphome/bluetooth-proxies/esp32-generic.yaml@main
esphome:
comment: ${device_description}
name_add_mac_suffix: false
esp32:
board: wemos_d1_mini32
framework:
type: esp-idf
version: latest
# Enable logging
logger:
level: DEBUG
wifi:
ssid: !secret wifi_ssid
How do you know that it doesn’t detect nothing? Through esp’s log output? Default log won’t say anything about BT, you must set log to verbose, only then you’ll see if any BT devices are proxying to HA.
I don’t see devices in HA so yes I’m not sure if the gateway works and that it is maybe the connection to HA.
Will test verbose.
Tested the verbose setting and it looks the gateway works but not the integration to HA
[09:27:27][V][esp32_ble_tracker:781]: Unhandled type: advType: 0x1b
[09:27:27][V][bluetooth_proxy:020]: Proxying packet from [LG] webOS TV OLED65CX6LA - 58:88:27:56:DE:65. RSSI: -93 dB
[09:27:27][V][bluetooth_proxy:020]: Proxying packet from Raspberry Pi 3 Model B Plus R - 43:45:C0:00:1F:AC. RSSI: -94 dB
[09:27:27][V][bluetooth_proxy:020]: Proxying packet from ATC_D9F1B4 - A4:C1:38:D9:F1:B4. RSSI: -70 dB
[09:27:27][V][bluetooth_proxy:020]: Proxying packet from Raspberry Pi 3 Model B Plus R - 43:45:C0:00:1F:AC. RSSI: -91 dB
[09:27:28][V][bluetooth_proxy:020]: Proxying packet from Raspberry Pi 3 Model B Plus R - 43:45:C0:00:1F:AC. RSSI: -91 dB
[09:27:28][V][esp32_ble_tracker:781]: Unhandled type: advType: 0x1b
[09:27:28][V][bluetooth_proxy:020]: Proxying packet from [LG] webOS TV OLED65CX6LA - 58:88:27:56:DE:65. RSSI: -95 dB
[09:27:28][V][bluetooth_proxy:020]: Proxying packet from ClearGrass Temp & RH - 58:2D:34:10:B5:E3. RSSI: -73 dB
Then you must install/find appropriate integration. An example: xiaomi thermo/hygrometer: you need BTHome integration. etc… and if you have custom FW (ATC, PVVX) you need to configure “bthome” in fw’s configuration, otherwise it won’t be selfdiscoverable.
I guess that ESP module is proxying all it can find, but not all is perhaps discoverable by HA (at least automatically). At least now you know that proxy is working.
Tried to add the bthome integration but it says “no devices found on the network”. It doesn’t installas far as I see.
I use the Xiaomi device that I added long before HA had a Bluetooth proxy. I don’t know what I need to change in the custom firmware to make it discoverable by my new proxies?
It finally looks to have found my cleargrass sensor but it doesn’t detect the flashed LYWSD03MMC sensors. so one step closer but not there yet
For LYWSD03MMC with custom fw: I’m not sure if atc firmware has this option, i know that latest pvvx fw has it: goto Telink flasher, then find your xiaomi, connect to it and select advertising type “bthome”.
If atc doesn’t have this option then change fw to pvvx (it’s just somewhat modified atc). If you have an old pvvx fw it also doesn’t have this option, then update your fw.
jumping from one problem to another.
Flashed the pvvx but the sensor doesn’t want to open the config. In very rare situations it succeeds but disconnects shortly after. When connecting the display flashes very fast and for a long time and now and then crashes. Get a large number on the screen en lo where the humidity percentage normally is.
When I try to reflash it i get the error “update: error: NotSupportedError: GATT Error:unknown”
Just found the problem. When connecting to the pvvx flashed devices, the battery % drops from 43% to 0% making the connection disconnect, unstable and even does the device to crash.
After some new batteries, I can connect to the device and chante the advertising to bthome and yes as soon as I disconnect the programmer, the devices pops up in home assistant.
So many thanks for helping me out. Your suggestion was the solution.
I’m glad that you sorted out!
Yes, flashing and configuring are quite battery intense things so you need a good battery, and a good quality one, too. Cheap no-name ones tend to drop voltage too low brand new…
Make sure you are using 2022.12.0b2 esphome or later as it has some important stability fixes
Also if you can switch to esp-idf framework to save 50k of ram
Hi All
One thing to remember
For reliable connection and refirmware on LYWSD03MMC, the battery level must be more than 40%. This is a design feature - a cheaper version of the hardware.
In version 3.9 they have changed the battery readings %
Changed the calculation of battery readings in %, optimization of consumption for the solar battery when the voltage drops below 2V (deep-sleep), added option to invert event for reed switch, small optimizations.
The battery readings we receive is really just a guide (some what accurate) so even though your reading was 43% it is on edge of being able to re-flash.
Also using BTHome may reduce your battery’s. I use MIJIA and have had no problems.
BTHome uses bluez and active scanning.
Due to the active mode, the batteries in the devices run out faster and there is a lot of writing to the disk.
Switch to passive mode.
One more update on the ESPHome proxies:
If you flashed your ESPHome proxy before 7:00AM UTC on Tuesday, December 13, 2022, please flash again as it should improve the connection times.
Please use the web flash tool below or ESPHome addon 2022.12.0b5 or later as the main line ESPHome addon does not yet have the connection time improvements or aarch64 flashing fix:
https://esphome.github.io/bluetooth-proxies/
If you use the ESPHome addon you MUST connect the device via serial to flash it or you will not see the performance improvements with active connections.
