Thanks for your patience… this is really frustrating as I made several steps back as it seems and can’t figure out why.
Nothing works properly at the moment, so I put the display aside now.
For the platform you suggested a webpage that links to platformio.org, but I’m stuck here. I bought this device: FREI D1 Mini - kompatibles ESP8266 Board, v2.0 | Einplatinen-Mikrocontroller günstig kaufen | reichelt elektronik
Esphome says:
if unsure choose a generic board from Espressif such as esp01_1m.
So I did that and tried a minimal yaml and used esphome from my laptop to flash the device (esphome run minimal.yaml --device /dev/ttyUSB0):
esphome:
friendly_name: wemosmin
esp8266:
board: esp01_1m
# Enable logging
logger:
level: DEBUG
api:
ota:
platform: esphome
wifi:
ssid: "FRITZ!Box 2000"
password: "mypassword"
ap:
captive_portal:
This already doesn’t work properly, flashing seems to work but then no wifi connection:
INFO Successfully uploaded program.
INFO Starting log output from /dev/ttyUSB0 with baud rate 115200
[21:32:41]\xd8g s\x8fo
ld\xe0
;\x9c\x9c\xc0\xF1\xc7c\xC2g
`g`gs\x8fg
c\x8c`\x9bn
b\xC2`
\x8f\x87\x9c\x87`n\x9c\x8c\xe4g\xe4\x93{\x82g
d
\x84
`#\xdfr\x9bd\xe0l\xF1\xdbl\x84x8c
[I][logger:034]: Log initialized
[21:32:41][C][safe_mode:079]: There have been 1 suspected unsuccessful boot attempts
[21:32:41][I][app:029]: Running through setup()...
[21:32:41][C][wifi:048]: Setting up WiFi...
[21:32:41][C][wifi:061]: Starting WiFi...
[21:32:41][C][wifi:062]: Local MAC: FC:F5:C2:A2:FA:A9
[21:32:42][D][wifi:482]: Starting scan...
[21:32:42][W][component:167]: Component wifi set Warning flag: scanning for networks
[21:32:AA][D][wifi:497]: Found networks:
[21:32:AA][I][wifi:540]: - 'FRITZ!Box 2000' (B0:F2:3C:C7:F1:AC) ▂▄▆█
[21:32:AA][D][wifi:542]: Channel: 11
[21:32:AA][D][wifi:543]: RSSI: -69 dB
[21:32:AA][I][wifi:540]: - 'FRITZ!Box 2000' (50:E6:36:F2:B8:E7) ▂▄▆█
[21:32:AA][D][wifi:543]: RSSI: -85 dB
[21:32:AA][D][wifi:545]: - 'HejaComo' (B2:F2:3C:C7:F1:AC) ▂▄▆█
[21:32:AA][D][wifi:545]: - 'UPC253525F' (AC:22:05:F8:21:77) ▂▄▆█
[21:32:AA][D][wifi:545]: - 'Vodafone-F314' (D4:3F:CB:91:57:BB) ▂▄▆█
[21:32:48][D][wifi:545]: - 'HejaComo' (F2:5D:35:E6:4D:F2) ▂▄▆█
[21:32:48][I][wifi:313]: WiFi Connecting to 'FRITZ!Box 2000'...
[21:32:50][W][wifi_esp8266:513]: Event: Disconnected ssid='FRITZ!Box 2000' bssid=B0:F2:3C:C7:F1:AC reason='Auth Expired'
[21:32:50][W][wifi:653]: Error while connecting to network.
[21:32:50][D][wifi:697]: Retrying with hidden networks...
[21:32:50][I][wifi:313]: WiFi Connecting to 'FRITZ!Box 2000'...
[21:32:52][W][wifi_esp8266:513]: Event: Disconnected ssid='FRITZ!Box 2000' bssid=B0:F2:3C:C7:F1:AC reason='Auth Expired'
[21:32:52][W][wifi:653]: Error while connecting to network.
[21:32:52][D][wifi:697]: Retrying with hidden networks...
[21:32:57][I][wifi:313]: WiFi Connecting to 'FRITZ!Box 2000'...
[21:33:05][W][wifi_esp8266:513]: Event: Disconnected ssid='FRITZ!Box 2000' bssid=B0:F2:3C:C7:F1:AC reason='Auth Expired'
[21:33:05][W][wifi:653]: Error while connecting to network.
[21:33:05][D][wifi:697]: Retrying with hidden networks...
[21:33:05][I][wifi:313]: WiFi Connecting to 'FRITZ!Box 2000'...
[21:33:07][W][wifi_esp8266:513]: Event: Disconnected ssid='FRITZ!Box 2000' bssid=B0:F2:3C:C7:F1:AC reason='Auth Expired'
[21:33:07][W][wifi:653]: Error while connecting to network.
[21:33:07][D][wifi:697]: Retrying with hidden networks...
[21:33:12][I][wifi:313]: WiFi Connecting to 'FRITZ!Box 2000'...
[21:33:20][W][wifi_esp8266:513]: Event: Disconnected ssid='FRITZ!Box 2000' bssid=B0:F2:3C:C7:F1:AC reason='Auth Expired'
[21:33:20][W][wifi:653]: Error while connecting to network.
[21:33:20][D][wifi:697]: Retrying with hidden networks...
[21:33:20][I][wifi:313]: WiFi Connecting to 'FRITZ!Box 2000'...
[21:33:22][W][wifi_esp8266:513]: Event: Disconnected ssid='FRITZ!Box 2000' bssid=B0:F2:3C:C7:F1:AC reason='Auth Expired'
[21:33:22][W][wifi:653]: Error while connecting to network.
[21:33:22][D][wifi:697]: Retrying with hidden networks...
[21:33:27][I][wifi:313]: WiFi Connecting to 'FRITZ!Box 2000'...
I really don’t get it. This was definitely working a couple of days ago when I was trying to debug the display.
The wifi isn’t hidden and I didn’t change anything here.
I tried all solutions posted in this thread (including fast_connect): ESPHome - Wifi - Auth Expired … negative.
I am using Wifi channel 11 and I read somewhere that this might be problematic. However, since I’m running Zigbee on channel 11 this was a conscious decision given the surrounding networks I have and cannot influence. Furthermore WiFi 6 with 2,4 and 5 GHz, but would like to stick with these settings as downgrading seems to be a bad option. (and 1m distance to the AP to get connected is also not ideal)
I can reconfirm the same behaviour for another wemos d1 mini. (Almost feels like the displays destroyed the wemos, although this is probably very unlikely)
Really not sure, where to go from here, so I’m happy about your suggestions.
Edit: Tried nodemcu with slight adjustment of the yaml: same result.
