Thank you.
Looking forward to 2023.3.5.
Me too, but there is a problem with the 8x32 version and esp8266 boards. I think its a problem with RAM. I have to figure out before the release.
Wemos D1 mini here so let me know if I can help doing some beta testing.
I saw 2023.3.5 is available.
Downloaded and testing.
May I suggest you add to changelog and readme that now services use âlifetimeâ instead of âdurationâ?
And it looks âalarm: trueâ or âalarm: falseâ is also mandatory.
Thanks!
Youâre right, the naming an documentation is a mess. I will streamline it in the 2023.4.0 version. Which will cause a lot of breaking changes. But i thing it is worth it.
Hi!
I just noticed âshow_secondsâ is a service and not a variable you set under âehmtâ section in yaml. I thought it might be worth to say as I initially tried the variable way.
I have also tried to test 8x32 icons with âforce_screenâ service but it didnât work. Nevertheless, âadd_screenâ works if you place a blank space in âtextâ field.
Any suggestion to make âforce_screenâ work?
Thanks!
Hi!
i know the documentation and the code is a big patchwork. So i started to clean everything up. In the upcoming release 2023.4.0 there will be a better documentation and a more structured naming scheme.
You can read the documention here: GitHub - lubeda/EsphoMaTrix at 2023.4.0
There is an update section for all users of the actual version till 2023.3.5
or try the new branch â2023.4.0â
The brave and fearless users can try it now.
I like it! Going to wait until I get a new 3-d printer though, my current one is an entry level machine, what i like about the kit is it also comes with the black acrylic, and since I donât own a laser cutter this is a nice add-on.
You sir are a scholar and a gentleman
I bought one of these pre-made kits off AliExpress and the results are great!
https://www.aliexpress.us/item/3256802826131110.html
Smart Pixel Clock Awtrix Pro Maker Creative Color LED Complete set of finished shell product size 328x88x50mm
The kit comes with a nice PCB, touch sensors, ESP8266 and 8x32 LED matrix and a USB power supply and cord. I already had the matrix so I just bought the shell option which doesnât include the ESP or LEDs.
One fun feature is the DFPlayer Mini MP3 player which enables limitless possibilities for sound notifications. I tested it and it works great! Here is a mostly complete config for this kit. I donât yet have the luminosity sensor working, and I didnât put in a battery or temp/humidity sensor either.
Here is the code in case anyone else gets one of these kits. The build quality is really good, it would be difficult to build this yourself cheaper than what the vendor charges:
esphome:
friendly_name: ESPHoMaTrix
on_boot:
priority: -100
then:
# - lambda: !lambda |-
# id(rgb8x32)->show_all_icons();
- ehmtx.text.color:
red: !lambda return 200;
blue: !lambda return 170;
- ehmtx.today.color:
red: !lambda return 10;
green: !lambda return 250;
- ehmtx.clock.color:
red: !lambda return 50;
green: !lambda return 150;
blue: !lambda return 230;
- ehmtx.weekday.color:
green: !lambda return 200;
blue: !lambda return 200;
substitutions:
devicename: ehmtx8266
ledpin: GPIO4
left_button_pin: GPIO16
mid_button_pin: GPIO2
right_button_pin: GPIO15
dfplayer_tx_pin: GPIO14
dfplayer_rx_pin: GPIO13
ldr_pin: A0
board: esp01_1m
loglevel: DEBUG
esp8266:
board: $board
# Enable logging
logger:
# DFPlayer Mini
uart:
tx_pin: $dfplayer_tx_pin
rx_pin: $dfplayer_rx_pin
baud_rate: 9600
dfplayer:
on_finished_playback:
then:
logger.log: 'Playback finished event'
# Enable Home Assistant API
api:
encryption:
key: "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"
services:
- service: alarm
variables:
icon_name: string
text: string
then:
lambda: |-
id(rgb8x32)->add_screen(icon_name,text,7,20,true);
id(rgb8x32)->force_screen(icon_name);
- service: screen
variables:
icon_name: string
text: string
then:
- ehmtx.add.screen:
text: !lambda return text;
icon_name: !lambda return icon_name;
alarm: false
- service: brightness
variables:
brightness: int
then:
lambda: |-
id(rgb8x32)->set_brightness(brightness);
- service: status
then:
lambda: |-
id(rgb8x32)->get_status();
- service: dfplayer_next
then:
- dfplayer.play_next:
- service: dfplayer_previous
then:
- dfplayer.play_previous:
- service: dfplayer_play
variables:
file: int
then:
- dfplayer.play: !lambda 'return file;'
- service: dfplayer_play_loop
variables:
file: int
loop_: bool
then:
- dfplayer.play:
file: !lambda 'return file;'
loop: !lambda 'return loop_;'
- service: dfplayer_play_folder
variables:
folder: int
file: int
then:
- dfplayer.play_folder:
folder: !lambda 'return folder;'
- service: dfplayer_play_loop_folder
variables:
folder: int
then:
loop: true
- service: dfplayer_set_device_tf
then:
- dfplayer.set_device: TF_CARD
- service: dfplayer_set_device_usb
then:
- dfplayer.set_device: USB
- service: dfplayer_set_volume
variables:
volume: int
then:
- dfplayer.set_volume: !lambda 'return volume;'
- service: dfplayer_set_eq
variables:
preset: int
then:
- dfplayer.set_eq: !lambda 'return static_cast<dfplayer::EqPreset>(preset);'
- service: dfplayer_sleep
then:
- dfplayer.sleep
- service: dfplayer_reset
then:
- dfplayer.reset
- service: dfplayer_start
then:
- dfplayer.start
- service: dfplayer_pause
then:
- dfplayer.pause
- service: dfplayer_stop
then:
- dfplayer.stop
- service: dfplayer_random
then:
- dfplayer.random
- service: dfplayer_volume_up
then:
- dfplayer.volume_up
- service: dfplayer_volume_down
then:
- dfplayer.volume_down
ota:
password: "XXXXXXXXXXXXXXXXXXXX"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esphomatrix Fallback Hotspot"
password: "XXXXXXXXXXX"
web_server:
port: 80
captive_portal:
external_components:
- source:
type: git
url: https://github.com/lubeda/EsphoMaTrix
binary_sensor:
- platform: status
- platform: gpio
pin:
number: $left_button_pin
mode:
input: true
name: "$devicename left button"
- platform: gpio
pin:
number: $mid_button_pin
mode:
input: true
inverted: true
name: "$devicename middle button"
- platform: gpio
pin:
number: $right_button_pin
mode:
input: true
name: "$devicename right button"
- platform: adc
name: "$devicename Illuminance"
pin: $ldr_pin
update_interval: 10s
unit_of_measurement: lx
accuracy_decimals: 0
filters:
- lambda: |-
return (x / 10000.0) * 2000000.0 - 15 ;
font:
- file: _fonts/MatrixClock-Light6.bdf
glyphs: |
!?"%()+*=,-_.:°0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZ abcdefghijklmnĂĂĂĂ¶Ă€ĂŒopqrstuvwxyz$@<>/
light:
- platform: neopixelbus
type: GRB
variant: WS2812
pin: $ledpin
num_leds: 256
color_correct: [75%, 75%, 75%]
restore_mode: ALWAYS_OFF
on_turn_on:
lambda: |-
id(ehmtx_display)->set_enabled(false);
on_turn_off:
lambda: |-
id(ehmtx_display)->set_enabled(true);
effects:
- addressable_random_twinkle:
number:
name: "LED brightness"
min_value: 0
max_value: 255
step: 1
lambda: |-
return id(rgb8x32)->get_brightness();
set_action:
lambda: |-
id(rgb8x32)->set_brightness(x);
switch:
icon: "mdi:power"
restore_mode: ALWAYS_ON
lambda: |-
return id(rgb8x32)->show_display;
turn_on_action:
lambda: |-
id(rgb8x32)->set_display_on();
turn_off_action:
lambda: |-
id(rgb8x32)->set_display_off();
time:
- platform: homeassistant
display:
- platform: addressable_light
addressable_light_id: ehmtx_light
width: 32
height: 8
pixel_mapper: |-
if (x % 2 == 0) {
return (x * 8) + y;
return (x * 8) + (7 - y);
rotation: 0°
update_interval: 16ms
auto_clear_enabled: true
lambda: |-
id(rgb8x32)->tick();
id(rgb8x32)->draw();
ehmtx:
time_component: ehmtx_time
matrix_component: ehmtx_display
yoffset: 7
xoffset: 1
clock_time: 20 # seconds
screen_time: 30 # seconds
font_id: ehmtx_font
show_dow: true # day of week
show_date: true # also show the date
icons2html: true # generate html with con overview
brightness: 80 # percent
time_format: "%H:%M"
date_format: "%m.%d."
week_start_monday: false # false equals sunday
scroll_count: 2 # scroll long text at least two times
scroll_interval: 80 # milliseconds
frame_interval: 192 # milliseconds
icons:
# UI Elements and Events
- url: https://developer.lametric.com/content/apps/icon_thumbs/4786
- url: https://developer.lametric.com/content/apps/icon_thumbs/59
- url: https://developer.lametric.com/content/apps/icon_thumbs/270
Here is how you play MP3s. The folders and file names all have to be numbers so you might want to keep a spreadsheet to keep track of what your sounds are:
Hi, the dfplayer is nice, but with an I2S audio adapter you can play what everyou want, even tts, with your device. By the way, the like does not work in germany.
Greetings.
Thanks @lubeda. Sorry the link doesnât work in Germany. I canât get to de.aliexpress.com because it forwards me back to the US site. Here is the vendorâs name and description if you want to try searching:
Iâm not sure this device could be altered to support I2S since all the pins are already set on the PCB. You could of course build it without the PCB but it makes setup really easy!
Hey,
Has anyone had an issue with EspHoMaTriX bricking the Ulanzi clock.
I flashed and installed on one clock, worked perfectly for 12 hours, then the clock froze and dropped off my network. No response to any button presses until I held the left and right to turn it off. Then wouldnât turn back on at all. Put it down to hardware failure and ordered another only for exactly the same thing to happen on the replacement clock.
Neither now recognised as serial port on plugging in. Disassembled one to disconnect the battery and power cycle but didnât help.
Is the power control not the same in the flashed firmware such that it is irretrievably turned off once you power down?
Is there a different way to turn it back on post flashing?
Canât see otherwise why I would have bricked 2 after they had been working fine.
Thanks!
i donât think that any esphome code is able to brick an ulanzi. With my ulanzi I sometimes have the feeling that there are problems with the ram or flash. Iâve also heard from ulanzis that were defective upon delivery. At the end i flashed my ulanzi more then a hundred times and it is still working.
Iâve had no such issues. But @blakadder also mentioned the quality of the usb cable. He used another one when flashing.
Hey. Is anyone able to advise me how we can change the colour of the displayed text? Iâm using the Ulanzi TC001 but i canât see a way to change colours.
GitHub - lubeda/EspHoMaTriXv2: A simple DIY status display with a 8x32 RGB LED matrix, implemented with esphome.io and Home Assistant. this is the new âwork in progressâ version. You can even use text with a rainbow effect. See the GitHub page for details.
Let me first say that this is a fantastic project. You clearly have put a lot of effort into this, so thank you very much.
Iâve just started working with this on a Ulanzi clock in hopes that I could make it into a âcontinuous displayâ for my daughterâs blood glucose monitor. Iâve had to trouble getting the basic data to display, but I was wondering if a couple of potential âenhancementsâ to my particular use are possible.
- Is there any way to add a second icon after the Text? Idealy, Iâd like to have an illustration icon | her reading | a directional arrow for trend
- Is there anyway to have an icon wider that 8x8? 8x12 would allow for some nicer looking icons for her.
Again, these are just ânice to haveâ requests. Iâm very happy with the results regardless. Thanks again.
a second icon on the right is a very special request, but what about a font with an up and down arrow? Or in the upcoming version there are two âindicatorsâ on the right side. see image
I will think about other ways to help.
Thanks for the quick response. I had looked at using alt codes, but I couldnât find angled icons to indicate the slightly increasing or decreasing trends from her monitor.
Again, donât worry to much about it. For now I have it as the main icon that sometimes gets replaced by event icons. This really meets 95% of our needs. Thanks for looking at it though.
