Hi again.
Did anybody found out right config for ESPHome to this plug?
Best,
chrisjan
Hi again.
Best,
chrisjan
Pretty easy to figure out from the tasmota config.
I just setup the device and have the exact same problem.
Voltage is always around 120V instead of 240V and Watt is also halvedā¦
Setup sensor filter to multiply by 2
The issue with the too low readings of voltage and power is that esphome assumes that the devices use the default setup of voltage divider resistor and current resistor.
The default is 1M Ohm for voltage divider. The 2xx Volt variants of the SPH5 and Gosund SP112 are using 1906 kOhm. You can configure those values for other power meassurement chips but not the CSE7766. (also see: https://github.com/esphome/feature-requests/issues/736)
In theory it should be āmultiply by 1.906ā . With 2 you will get values too high.
Hey, I was going to use @depen config from above for my Gosund 112, but it turns out Iāve got Version 3.4 (https://templates.blakadder.com/gosund_SP112_v3_4.html).
Iāve got it somehow working, but before I can calibrate it I need values for:
current_resistor: ???
voltage_divider: ???
So I did it myself and calibrated the values for current_resistor
and voltage_divider
with another power meter.
Here is my config and hope it will help someone later:
esphome:
platform: ESP8266
board: esp8285
on_boot:
priority: -10
# Turn on switch during startup
then:
- switch.turn_on: relay
wifi:
ssid: 'ssid'
password: 'password'
api:
logger:
level: none
baud_rate: 0
ota:
substitutions:
# Unique device ID
device_id: "gosund_sp112_1"
device_name: "Gosund SP112 1"
uart:
rx_pin: RX
baud_rate: 4800
time:
- platform: homeassistant
- platform: wifi_signal
filters:
- delta: 2.0
# Power sensor
- platform: hlw8012
sel_pin:
number: GPIO12
inverted: true
cf_pin: GPIO05
cf1_pin: GPIO04
current_resistor: 0.0022
voltage_divider: 720
change_mode_every: 5
update_interval: 5s
# Current sensor
current:
icon: mdi:current-ac
unit_of_measurement: A
accuracy_decimals: 2
filters:
- delta: 0.02
- multiply: 1.81
# Voltage sensor
voltage:
icon: mdi:poll
unit_of_measurement: V
accuracy_decimals: 1
filters:
- delta: 0.5
# Power sensor
power:
icon: mdi:flash-outline
unit_of_measurement: W
accuracy_decimals: 0
filters:
- delta: 1.5
# Total daily energy sensor
- platform: total_daily_energy
name: ${device_name} Daily Energy
power_id: power
filters:
# Multiplication factor from W to kW is 0.001
- multiply: 0.001
unit_of_measurement: kWh
- platform: adc
internal: true
pin: GPIO17
update_interval: 5s
filters:
delta: 0.4
on_value:
then:
- if:
condition:
# Should return either true or false
lambda: |-
return id(source_sensor).state <= 0.3;
then:
- switch.toggle: relay
switch:
# Switch to toggle the relay (Power output)
- platform: gpio
icon: mdi:power-socket-eu
#restore_mode: ALWAYS_ON
pin: GPIO14
on_turn_on:
- light.turn_on: led
on_turn_off:
- light.turn_off: led
# Switch to toggle the relay (USB output)
- platform: gpio
icon: mdi:usb
pin:
number: GPIO13
inverted: true
on_turn_on:
on_turn_off:
output:
# Relay state led
- platform: esp8266_pwm
pin:
number: GPIO02
inverted: true
light:
# Relay state light
- platform: monochromatic
output: state_led
# Uses the red LED as a status indicator
status_led:
pin:
number: GPIO00
inverted: true
Does this also measure the consumption of the USB ports?
It only has 1 general consumption indicator
Ok, so if i connect something in the USB ports it will show the consumption, right?
Not sure. Based on the information in the link below, it would seem that the USB power consumption is not measured: https://github.com/arendst/Tasmota/issues/5756#issuecomment-500026002
Hello all,
I have the same SHP5 plug and because i just do not know, i have to solder and upload a Tasmota firmware in order to have it in HA or can be done with other way?
Thank you in advance for your help.
Hi!
I just tried this config but for me no sensing works at all. Did you experience this too?
Voltage, Daily, Power and Current all stay at 0. Switches and RSSI works.
EDIT:
Figured it out. Your setup works on the newer style with different sensor. changed up the code a little to use the old sensor and all working now!
@ GravitySandwich: Can you share config? My Voltage and Power is also 0. What did you change?
i have a gosund sp112 and i also donĀ“t get power values
