Esphome automation help re: on_value_range
Hello again all,
I have found esphome and have built some great sensors and updated a few of my tasmota devices as well.
Going good with the basic coding but just cant get my head around the automations, i have been working on building the sensor as stated in the esphome automations sensor https://esphome.io/guides/automations.html .
I have the humidity sensor working with a value range as per the above site address eg.
on_value range
- platform: dht
  humidity:
	name: "Living Room Humidity"
	on_value_range:
	  - above: 65.0
	      then:
	        - switch.turn_on: dehumidifier1
	  - below: 50.0
	      then:
	        - switch.turn_off: dehumidifier1
	temperature:
      name: "Living Room Temperature"
What im trying to do is set the above and below values to a home assistant sensor
that can adjust the humidity level with an input_slider`
Untitled%20picture
Ive
built the slider on my home assistant and have the values showing on the
esphome web server interface,
Untitled%20picture
Just stuck with getting this value into
esphome.yaml. Below is what im looking to do
humidity:
on_value_range:
  - above: 65.0  { i want this to be the home assistant sensor with id "humidity_set"}
      then:
        - switch.turn_on: dehumid_switch
  - below: 50.0  { i want this to be the home assistant sensor with id "humidity_set"}
      then:
        - switch.turn_off: dehumid_switch
update_interval: 10s
OR
If humidity rises above my slider value then turn on my dehumidifier, and when the humidity drops below my slider value then turn off my dehumidifier
Please any help would be very greatful, and thankyou in advance
Heres my yaml.
esphome:
  platform: ESP32
  board: nodemcu-32s
wifi:
  ssid: "CRGSECRET"
  password: "yeahright"
logger:
api:
text_sensor:
  - platform: wifi_info
    ip_address:
      name: ESP IP Address
    ssid:
      name: ESP Connected SSID
    bssid:
      name: ESP Connected BSSID
ota:
web_server:
  port: 80
switch:
  - platform: gpio
    pin: GPIO17
    inverted: yes
  - platform: gpio
    pin: GPIO16
    inverted: yes
  - platform: dht
    pin: GPIO23
    model: DHT11
    temperature:
    humidity:
	  on_value_range:
        - above: 65.0
          then:
        - below: 50.0
          then:
  - platform: homeassistant
    name: "Temp Set Point"
    entity_id: input_number.desired_temperature
    name: "Humidity Set Point"
    entity_id: input_number.desired_humidity
Why not do all the automation in home assistant?
want it obsolete from any server only ha control will be the slider value, plus version 2.0 will use a rotary encoder to set humidity,
im making IOT Device with my ESP-32 and would like it to function as a stand alone device as i believe its best for HA failure or any other reason to add a dial or switch that connects directly to HA but can also work in conditions by itsself, just sounds logical to make the device communicate with itself first before needing to send data to my HA Setup
There are arguments both ways - ideally home assistant should know everything and all automations should be done there. Then everything is centralised.
Not really helping my issue nickrout.
so whats tour way of doing this then could you provide me with some automations in HA as well as anyone else with some proactive advice would be appreciated
I have been just refreshing my memory of the esphome docs so I could help you. I think you want this to import a value set by a home-assistant entity. https://esphome.io/components/sensor/homeassistant.html
So to rephrase my question
im making IOT Device with my ESP-32 that i would like to get sensor value from my ha to perform a basic automation to turn a relay on all values will be provided to and from both HA and my Iot device. need help with some basic coding please see my first post any help with coding my espyaml
im getting this value already from HA but thanks for the input
Unti11tled
Untitled
Is it working?
I think that you might need a lambda, just looking at this example: https://esphome.io/guides/automations.html#templates-lambdas
just working on that now
  - platform: dht
    pin: GPIO23
    model: DHT11
    temperature:
    humidity:
      on_value:
        then:
	  - if:
	        lambda: 'return id(sensor.humid).state > return id(humidity_set);'
	then:
	   - logger.log: "The Dehumidifier has switched on!"
           - delay: 2s
	else:
	   - logger.log: "The Dehumidifier has reached the Setpoint!"
	   - light.turn_off: dehumid_switch
oops ill edit that text
still no good i have updated to reflect my changes but no success yet
newest code
  - platform: dht
    pin: GPIO23
    model: DHT11
    temperature:
    humidity:
    on_...:
      then:
        - if:
                then:
                  - delay: 2s
      else:
My first guess would be your formating is wrong. look at the example:
> on_...:
>   then:
>     - if:
>         condition:
>           lambda: 'return id(some_sensor).state < 30;'
>         then:
>           - logger.log: "The sensor value is below 30!"
>           - light.turn_on: my_light
>           - delay: 5s
>         else:
>           - logger.log: "The sensor value is above 30!"
>     - light.turn_off: my_light
Further include the on_…: should probably be on_value:
ill have another look thanks for the help
to date
  - platform: dht
    pin: GPIO23
    model: DHT11
    temperature:
    humidity:
      on_value:
      then:
        - if:
              lambda: return id(sensor_humid).state > id(humidity_set.state);
            then:
              - delay: 2s
            else:
              - logger.log: "The Dehumidifier is under the Setpoint. Now off!"
ok solved here is the way i did it
  - platform: dht
    pin: GPIO23
    model: DHT11
    temperature:
    humidity:
      on_value:
        then:
          - if:
                lambda: 'return id(sensor_humid).state > id(humidity_set).state;'
              then:
                - switch.turn_on: dehumidifier_switch
                - delay: 2s
              else:
                - switch.turn_off: dehumidifier_switch
Full yaml ( my bad)
esphome:
  platform: ESP32
  board: nodemcu-32s
wifi:
  ssid: "CRGSECRET"
logger:
api:
text_sensor:
    ip_address:
    ssid:
    bssid:
ota:
web_server:
  port: 80
switch:
  - platform: gpio
    pin: GPIO17
    inverted: yes
  - platform: gpio
    pin: GPIO16
    inverted: yes
  - platform: dht
    pin: GPIO23
    model: DHT11
    temperature:
    humidity:
      on_value:
        then:
          - if:
              then:
                - delay: 2s
              else:
Hi, could you help me? I would like to add to my cover in esphome a slider that marks the position of the curtain. My code is currently:
binary_sensor:
- platform: gpio
  pin:
    number: GPIO02
    mode: INPUT_PULLUP
    inverted: True
  on_press:
  - cover.open: my_cover
  on_release:
  - cover.stop: my_cover
- platform: gpio
  pin:
    number: GPIO03
    mode: INPUT_PULLUP
    inverted: True
  on_press:
  - cover.close: my_cover
  on_release:
switch:
- platform: gpio
  pin: GPIO04
  interlock: &interlock [open_cover, close_cover]
- platform: gpio
  pin: GPIO05
  interlock: *interlock
cover:
- platform: time_based
  open_action:
    - switch.turn_on: open_cover
  open_duration: 4s
  close_action:
    - switch.turn_on: close_cover
  close_duration: 4s
  stop_action:
    - switch.turn_off: open_cover
    - switch.turn_off: close_cover
what do I have to add to see also the position slider besides the forward, back and stop buttons?
Thank you!!!
