But that (BT) shouldn’t be a problem when doing OTA, since then esp is in programming mode and it doesn’t execute regular program, consequently it doesn’t use BT… right?
Made no difference on the two devices I used it on. According to the ESP docs, all ESP 8xxx chips default to Safe Mode. I couldn’t find about ESP32, but I have very few of them here.
Apparently, I am the only one here who has a number of ESP devices that will not connect to WiFi since updating to ESPHome 2024.1. (Or later. I test every new release of ESPHome to see if the issue is fixed). If I compile the device with ESPHome version 2023.9, WiFi works just fine.
So, I repeat my last question on this subject. Am I the only one seeing this issue?
Or just install it on another machine (windows, linux or mac or docker):
Note that this requires a physical connection to your ESP device, at least the first time.
Another option is to use you RP to generate a minimal config with just web/ota, and install the locally compiled binaries from there using the web interface:
I hadn’t thought of that, but wouldn’t the application on the PC (installed by pip3 install -U esphome) be the same as installed as the add-on? How would that make any difference about connecting by WiFi?
But, I will pursue that.
BTW, slightly off-topic- when I run the dashboard (esphome dashboard \), none of the devices present as “online”. Any idea why?
It is the DHCP server in your network that hands out DNS server details and this DNS server deals with (local) domain-names (which is most likely dealt with in your router).
I also hand out fixed IP’s ( due to address reservation), meaning I can reach all my local devices by using their <reservation-name>.domain.mine
The latter is not required, as the DHCP server should normally hand out the domain suffix to be added (which wouldn’t work when using static IP’s, hence you can add it manually too)
Which results on my W11 machine using ipconfig /all as:
Windows IP Configuration
Host Name . . . . . . . . . . . . : IA-CMQ4337N1Z
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : domain.mine
