Thank you! The template was the part I was missing to get the second value to report to HA!
To be honest I have kind of migrated away from my original scheme and now use the PZEM-004 t
https://www.aliexpress.com/item/4000558302474.html?spm=a2g0o.productlist.0.0.795aea91zbaLDd&algo_pvid=f52d6305-6444-48ca-9848-c744910591af&algo_expid=f52d6305-6444-48ca-9848-c744910591af-3&btsid=0bb0624516214117394447424ef192&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
Far more accurate and very easy to communicate with.
I don’t modify my PZEM like some do, I just use a level shifter.
my code
# WeMos D1 Mini PZEM 004T V3 #
# Substitutions
substitutions:
# Device Names
device_name: "pzem_004t_v3_d1_mini"
friendly_name: "PZEM 004T V3 D1 Mini"
esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid: "XXXX"
password: "xxxxxx"
power_save_mode: none
manual_ip:
static_ip: 192.168.0.104
gateway: 192.168.0.2
subnet: 255.255.255.0
ap:
ssid: "PZEM004T V3 D1 Fallback Hotspot"
password: "A1i5751c9OoJ"
captive_portal:
# Enable logging
logger:
level: DEBUG
baud_rate: 0
# Enable Home Assistant API
api:
ota:
# Enable Web server.
web_server:
port: 80
text_sensor:
- platform: version
name: "ESPHome Version ${friendly_name}"
# Example configuration entry
- platform: wifi_info
ip_address:
name: ESP IP Address ${friendly_name}
ssid:
name: ESP Connected ${friendly_name}
bssid:
time:
- platform: homeassistant
# LCD Display
i2c:
sda: D2
scl: D1
scan: True
display:
- platform: lcd_pcf8574
dimensions: 20x4
address: 0x27
lambda: |-
it.printf(0, 0, "DAILY ENERGY:%.1f kWh", id(${device_name}_daily_energy_total).state);
it.printf(0, 1, "POW:%.1f W", id(${device_name}_power).state);
it.printf(10, 1, "AMPS:%.1f A", id(${device_name}_current).state);
it.printf(0, 2, "%.1fV", id(${device_name}_voltage).state);
it.printf(8, 2, "%.1fPF", id(${device_name}_power_factor).state);
it.printf(14, 2, "%.1fHz", id(${device_name}_frequency).state);
it.strftime(0, 3,"%H:%M %d.%m", id(homeassistant_time).now());
it.printf(12, 3, "%.1f db", id(${device_name}_wifi_signal).state);
uart:
rx_pin: GPIO3
tx_pin: GPIO1
baud_rate: 9600
stop_bits: 1
- platform: pzemac
current:
name: "${friendly_name} V3 Current"
voltage:
name: "${friendly_name} V3 Voltage"
energy:
name: "${friendly_name} V3 Energy"
power:
name: "${friendly_name} V3 Power"
frequency:
name: "${friendly_name} Frequency"
power_factor:
name: "${friendly_name} V3 Power Factor"
unit_of_measurement: pf
update_interval: 2s
- platform: total_daily_energy
name: "${friendly_name} Total Daily Energy"
power_id: ${device_name}_power
filters:
# Multiplication factor from W to kW is 0.001
- multiply: 0.001
unit_of_measurement: kWh
icon: mdi:counter
- platform: integration
name: "${friendly_name} Energy Meter"
sensor: ${device_name}_power
time_unit: h
filters:
- multiply: 0.001
icon: mdi:counter
# Sensors with general information.
# Uptime sensor.
- platform: uptime
name: ${friendly_name} V3 Uptime
# WiFi Signal sensor.
- platform: wifi_signal
name: ${friendly_name} V3 WiFi Signal
update_interval: 60s
binary_sensor:
- platform: status
name: "${friendly_name} V3 Status"
status_led:
pin:
number: D4
inverted: false
Regards,
Do you wire the board as the schematic on aliexpress shows and put mains power to the board?
Yes mains and the CT to the PZEM.
I also added
to power the LCD and with a diode in series on the 5VCC on the D1 mini.
Interface between the PZEM and D1 with a level shifter.
Works a charm and very accurate.
Gives you
Power (W)
Volts
amps
PF
Frequency
KWh totals
Where can I get one of this to buy in the USA?
Hi, I am trying to do the same as you but I am not sure that I understand how
Is this schematic correct?
Edit
I’ve just read this:
And according to the formula on that site I need a 23.335 Ohm resistor so I am using 2 47Ohm resistors in parallel
The SCT-013-xxx CT Clamp does not need the burden resistor (shown in your diagram as “66”), The CT Clamp has this in it already. Other than that your diagram is correct. But one thing, there is an issue with these cheap clamps. The shielding may be connected to the ring, causing interference. Suggested to cut the plug off and hard wire.
Wonder if anyone can help with calibrating my readings. Using a SCT-013 clamp and this SCT013 board (ESP8266 Mains Current Sensor - Wemos - Current transformer - SCT013 - 100A/50mA | eBay) with a D1 mini board. Using the below values for calibration results in negative values for current and watts. These values at @240v
filters:
- calibrate_linear:
- 0 -> 0
- 0.01780 -> 4.72 # 1134w microwave (700w)
- 0.03571 -> 11.26 # 2702w kettle (2520-3000w)
I believe you are missing a time component.
Either use
time:
- platform: sntp
or
time:
It was perfect. I would like to add it in the Energy integration. How would I convert it to kWh? Sorry for the bother
Change "unit_of_measurement: ‘kW’ " for KWh, I don’t know if it’s right, but it appeared to me to integrate it in Energy
I’m not sure what you mean, there is an example of how to change W the kW in the post you referenced, kWh is a measurement of power used over a period of time.
I think in order for this integration to be added to the Energy Dashboard, you have to add it to the Recorder. Again, I’m not sure, but I think I’m right.
I don’t know if I did the right thing when converting from kw to kwh, but I wanted to do it to put it here
Looking at my ESP energy meter, I have the following.
total:
name: 'Full House Energy Meter Total'
unit_of_measurement: 'kWh'
icon: mdi:circle-slice-3
state_class: total_increasing
device_class: energy
accuracy_decimals: 3
filters:
- lambda: return x * (1.0 / 1000);
If this is incorrect, I’m leaving the conversation for now, it’s late and I’m a little drunk
I have connected a SCT-013-xxx (20A) CT Clamp exactly as described above, but I am not getting any readings via esphome. As soon as the sensor is connected: NaN. Without the sensor, the values fluctuate.
I have already cut off the connector and soldered it, no improvement. The contacts are correct, I have checked them several times. Even with a load of almost 9A: no measurement. I have already replaced the sensor and don’t know what to do. The capacitor points with negative to GND, doesn’t it?
It should not be due to the calibration, I have already tested the most different variants. The same with the ‘internal’ option.
Does anyone have any ideas? 🤷
with SCT013, it´s possbile to measure bidirecional current ?
