1- Fix your mDNS in your router…
2- Use a fixed IP
3- Add your local domain name to both your router and esphome device
domain (Optional, string): Set the domain of the node hostname used for uploading. For example, if it’s set to
.local, all uploads will be sent to<HOSTNAME>.local. Defaults to.local.
Apparently, your router added the domain name inverellit.local somewhere along the line.
my first try would be to add
domain: .inverellit.local
to the wifi section in your esphome yaml.
ps: the esphome addon has nothing to do with an esphome functioning within HA; it is only used for programming the device, and not used anymore after that
